Introduction: Arduino: HC-SR04 Ultrasonic Sensor
Picture of Arduino: HC-SR04 Ultrasonic Sensor
Objective:
Utilize an HC-SR04 ultrasonic sensor with an Arduino to measure the distance of any object.
The basic idea behind an ultrasonic sensor:
An ultrasonic sensor triggers a signal that travels in a straight path, and then if the triggered signal encounters an object, it will be reflected and the echo pin will detect it.
Parts Needed:
1. Arduino Uno microcontroller.
2. Arduino software IDE (I used the 1.6.8 version)
Note: Arduino IDE can be downloaded for free from Arduino software.
3. HC-SR04 ultrasonic sensor.
4. Breadboard.
5. Wires as needed.
Step 1: Schematics
Picture of Schematics
The HC-SR04 has 4 pins: Vcc, trig, echo, GND.
Vcc: input voltage, connect it to +5V.
trig: trigger pin, connect it to any digital pin.
echo: echo pin, connect it to any digital pin.
GND: ground, connect it to GND on the Arduino.
Note: the attached figure shows the schematics for this project.
Step 2: Code
Picture of Code
The attached figure shows the code needed. Also, the attached file contains the code used.
After writing the code, you have to:
1. Verify it.
2. Upload it to the board.
3. Open the serial monitor. (Cltr + Shift + M)
Step 3: Results
The embedded YouTube video shows the functionality of the ultrasonic sensor, where it was used to measure the distance of an object.
Ajnii (author)2016-12-30
I keep getting a zero distance reading.
Any ideas?
TalalKhalil (author)Ajnii2017-01-08
You might need to check the GPIO pins you are using.
The provided code in this instructable uses pins number 11 & 12.
Hope this helps.
CipectorF (author)2016-09-05
nice and easy ;-) just testing new sensor thx
wold630 (author)2016-03-30
FYI...Your video is sideways!
About This Instructable
1,383views
23favorites
License:
Bio: The DIY Pioneer
More by TalalKhalil:Python Programming - Basics Python Programming - Environment SetupArduino: HC-SR04 Ultrasonic Sensor
Add instructable to:
