Introduction: Arduino IR Home Automation V1.0
IR Remote is a Controller is a wireless controller in some electronics such as TV, DVD Player and other home appliances.
IR Remote send digitally-coded pulses of infrared radiation to control functions such as power, volume, tuning, temperature set point, fan speed, or other features. but in this project i am going to use IR Remote to control any appliances :)
BTW. this is my first Instructable project :)
Step 1: COMPONENTS
TV Remote = 1
IR Receiver = 1
Arduino Uno = 1
Arduino Nano = 1 (Optional)
Breadboard = 1
Jumper Cables = 20 or more
330 ohms Resistor = 8
10k ohms Resistor = 2
single pin header female = 4
PCB = 1
Relay = 2 or more
Push Button = 2
Step 2: DECODING
In order to decode the signal from the remote you need to connect the IR Receiver to the arduino.
IR Receiver PIN: (check your IR Receiver PIN).
1 Signal = Arduino PIN 11
2 Vcc = Arduino PIN 5v
3 GND = Arduino PIN GND
Arduino Code: (Upload this Code to your Arduino).
_____________________________________________________________
#include
int IRpin = 11;
IRrecv irrecv(IRpin);
decode_results results;
void setup()
{ Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop()
if (irrecv.decode(&results))
{ Serial.println(results.value, DEC);
// Print the Serial 'results.value'
irrecv.resume(); // Receive the next value
____________________________________________________________________
Serial Monitor: Plug in your Arduino to your Computer then open the Serial Monitor
Then point your TV Remote to the IR Receiver then press any button you want to decode after that you will get some Numbers like this:
Relay 1 = 16779273 = NUM 1
Relay 2 = 16812169 = NUM 2
Relay 3 = 16795721 = NUM 3
Relay 4 = 16828617 = NUM 4
Relay 5 = 16787497 = NUM 5
Relay 6 = 16820393 = NUM 6
Relay 7 = 16803945 = NUM 7
Relay 8 = 16836841 = NUM 8
Step 3: SCHEMATIC
BUTTON: Connect the two button to PIN 10 and 11
Push Button = 2
10K Ohms Resistor = 2
IR Receiver: Connect IR GND to Arduino GND, Vcc to Arduino 5v, and IR Signal to Arduino Pin 12
IR Receiver = 1
Relay and Led: Connect led with 330 ohms resistor to the arduino
LED 1 = PIN 2 LED 5 = PIN 6
LED 2 = PIN 3 LED 6 = PIN 7
LED 3 = PIN 4 LED 7 = PIN 8
LED 4 = PIN 5 LED 8 = PIN 9
RELAY 1 = PIN 2 RELAY 5 = PIN 6
RELAY 2 = PIN 3 RELAY 6 = PIN 7
RELAY 3 = PIN 4 RELAY 7 = PIN 8
RELAY 4 = PIN 5 RELAY 8 = PIN 9
RELAY Vcc = Arduino 5v
Relay GND = Arduino GND
Step 4: CODING
Upload this Code to your Arduino:
IMPORTANT:
//Relay 1
if (results.value == 16779273)
Change this value to match your Remote
to get the value you must decode the remote first then copy the result.
Step 5: CONNECTING ALL THE COMPONENTS TOGETHER
connect all the parts together.
make your own case for your project :)
you can use old shoe box or something that can hold all the components.
in my case i use some used plywood.
TEST 1
Step 6: CONTROLLING BRIGHT LED WITH RELAY
Step 7: FINAL TEST!!!
as you can see in the video i use only 12v super bright led
you can also use any appliances with project :)
Second Prize in the
Sensors Contest 2016
Automation Contest 2016
Beyond the Comfort Zone Contest
First Time Author Contest 2016
