Arduino Infrared RC Car
9,554
141
9
Posted
Introduction: Arduino Infrared RC Car
Hello. Despite numerous other RC Car Instructables, I wanted to add my own because I believe it is built in a decent way and can help others in builidng their own. So lets start with the parts you need in My version.
Step 1: Step 1: Parts
Step 2: Step 2: Assembling the Body
For assembling the body, you can watch this video
Step 3: Step 3: Mounting the Parts
You may have to drill some new holes in the board to fit the H-bridge or the battery holder that comes with the body. The screws might be a bit too short too, but then just go to your local store and buy some longer M3 screws.
In the beginning I ducktaped the entire construction until I saw it was working properly, then I for example, removed the sheet from the back of the breadboard and attached the breadboard to the body. I also drilled some 2.5mm holes for the infra red sensor so it all fits nicely. You can get a better look of how I did it all in the picture attached here.
WARNING!!
If you order the infrared sensor from the same link I ordered, be wary because someone who made the little PCB the sensor is on, crisscrossed some of the connections and if you follow this datasheet
http://www.elecrow.com/download/Infrared%20receive...
and connect the sensor to the Nano like that, you'll short the sensor and burn it. So when you get the sensor, turn it around and take a closer look to the connections on the back of the board. Look at the datasheet above and follow the lines to the output pins so you get the VCC, GND and signal properly connected.
Step 4: Step 4: the Connection Scheme and How It All Works
As you can see on the Fritzing scheme, the connection is not very hard. I connected the infrared to pin 11 and the 6 connections from the H-bridge can be connected whatever you like, just be sure that the leftmost pin and the rightmost pin are connected to PWM outputs on Nano. I used 5 and 10. Nice tutorial on controlling the DC motors with this module can be found here
https://www.instructables.com/id/Control-DC-and-ste...
I will provide the code later. For now be sure to connect the GND and the 5V from Nano to the proper longitudinal lines on the board, and to connect the ground from Nano and the H-bridge, like shown on the schematic.
So how it all works. After you upload your program to Nano(while you are doing that, I prefer that the power supply is not connected to the board), put your power supply on the board and check that the jumpers are on 5V. When you push that little white button, the power supply should light up and if your Nano connection from 5V to + on the board remained, the Nano will flash once signaling he is now getting powered from the Power Supply. You also now power the infrared with your power supply. Connect the wires from the 4AA battery holder (be wary they DONT touch) to the 12V and ground of the H-bridge. The H-bridge should light up and is now getting the 6V from the batteries. If you are using the rechargeable batteries, atleast in my country, they provide only 1.2V each, so when the voltage drops in the H-bridge due to its internal connections, you wont get enough voltage to power the motors. So I suggest the regular ones, 1.5V each.
Step 5: Step 5: the Code
The code is here just for the suggestion of how to do it, you can also use different remote codes for controlling your car. You will have to download and install the IR library.
Step 6: Step 6: Finish
So thats it, hope you all liked it. Here is the picture of my beast again!
If you want to, you can upgrade your little RC car in many ways, like autonomous driving, obstacle avoiding and so much more. Cheers!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
8 Comments
What is the inferred part. Does it follow inferred?
good job thinks
Now I love you.
I'm just starting with all this things of arduinos and electronics, I know just the most basic things, and I'm waiting the postam delivery of most of the parts for this. I'll try and let you know. This post has made me soooooo happpyyyyy !
I am glad :)
Can you use an uno? Also could you use 12v motors?
Ofcourse you could use Uno, but i think nano is more practical as its basically the same thing as Uno, just smaller and more compact. These motors that come in the package can be used up to 12 volts I think :)
awesome
but improve it's coding
