Arduino L293D Obstacle Avoiding Robot
14,318
170
26
Published
Introduction: Arduino L293D Obstacle Avoiding Robot
About: Robots are better than People
What you need to make it is.
1. Arduino uno.
2. Chassis kit of some sort.
3. L293D Motor driving chip.
4. power supple i used 0.5 mah li-po battery at 7.4v
5. lots of wires
6. ultra sonic distance sensor
7. potentiometer
when you put the code in the robot it will go forward, when the ultra sonic sensor senses something it will reverse and turn left.
Step 1: Wiring
i made this robot with a thin peace of wood 11cm x 11cm
Step 2: Code
int pwm_speed
//trig of ultrasonic sensor
int trig = 12;
//echo of ultrasonic sensor
int echo = 13;
//int red = 2;
//int blue = 4;
//int green = 7;
int potpin = A0;
void setup() {
//pins for motor controller
pinMode(11, OUTPUT);
pinMode(10, OUTPUT);
pinMode(9, OUTPUT);
pinMode(6, OUTPUT);//pinMode(red,OUTPUT);
//pinMode(blue,OUTPUT);
//pinMode(green,OUTPUT);//set trig as output and echo as input for ultrasonic sensor
pinMode(trig, OUTPUT);
pinMode(echo,INPUT);
}void loop() {
pwm_speed = analogRead(potpin);
pwm_speed = map(pwm_speed, 0, 1028, 0, 225);scan();int duration = pulseIn(echo, HIGH);
int distance = duration / 29 / 2;if(distance > 15){
   forward(100);
}else if(distance < 15){
  backward(700);
  left(500);
}}// function for driving straight
void forward(int delay_time){
  analogWrite(11, pwm_speed);
  analogWrite(10, 0);
  analogWrite(9, 0);
  analogWrite(6, pwm_speed);
  delay(delay_time);
}//function for reversing
void backward(int delay_time){
  analogWrite(11, 0);
  analogWrite(10, pwm_speed);
  analogWrite(9, pwm_speed);
  analogWrite(6, 0);
  delay(delay_time);
}//function for turning left
void left(int delay_time){
  analogWrite(11, 0);
  analogWrite(9, 0);
  delay(delay_time);
}//function for turning right
void right(int delay_time){
  analogWrite(10, 0);
  analogWrite(6, 0);
  delay(delay_time);
}//function for stopping motors
void motors_stop(int delay_time){
  analogWrite(11, 0);
  analogWrite(10, 0);
  analogWrite(9, 0);
  analogWrite(6, 0);
  delay(delay_time);
void scan(){
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(5);
}</p>
Step 3: Touble Shooting
If the robot goes the wrong way swap the motor wires around.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    26 Discussions
    pravi1
    1 year ago
    Hey Robert the code that you have given i the instruction have some errors. pls rectify the errors and post it. Thank you.
    if you use this code it should work but you'll need to change the motor driver wires to pin 6 int 1 pin 9 int 2 pin 10 int 3 pin 11 int 4 int on the motor driver board and you can use a RGB led with this code and the pot for speed is A0 so the same
    int trig = 12;
    int echo = 13;
    int red = 2;
    int blue = 4;
    int green = 7;
    int val=200;
    int potpin = A0;
    void setup() {
    pinMode(9, OUTPUT);
    pinMode(6, OUTPUT);
    void loop() {
    val = analogRead(potpin);
    val = map(val, 0, 1028, 0, 225);
    if(distance > 15){
    digitalWrite(blue,0);
    digitalWrite(red,1);
    forward(50);
    digitalWrite(red,0);
    digitalWrite(blue,1);
    backward(600);
    digitalWrite(green,0);
    left(700);
    digitalWrite(green,1);
    analogWrite(11, val);
    digitalWrite(10, LOW);
    analogWrite(9, val);
    digitalWrite(6, LOW);
    delay(delay_time);
    digitalWrite(11, LOW);
    analogWrite(10, val);
    digitalWrite(9, LOW);
    analogWrite(6, val);
    delay(delay_time);
    delay(delay_time);
    delay(delay_time);
    digitalWrite(9,LOW);
    delay(delay_time);
    this codes are having error can u have another codes
    problem with the code :(
    sketch_may08a.ino:5:16: error: expected unqualified-id before '<' token
    sketch_may08a.ino:10:8: error: expected constructor, destructor, or type conversion before '(' token
    sketch_may08a.ino:11:8: error: expected constructor, destructor, or type conversion before '(' token
    sketch_may08a.ino:12:8: error: expected constructor, destructor, or type conversion before '(' token
    Hello about the L293D motor IC what are the other replacement for it.? I mean, there is no available stock of the said IC and im going to use it im project arduino and bluetooth car. So, is there other value of IC as replacement for it.?
    Any help would be greatly appreciated, thank you.
    Try this from Sparkfun, the SN754410 Quad Half H-Bridge. https://www.sparkfun.com/products/315
    We have a problem. We can't find the name of the supersonic sensor . Can you give us name or can we use another one?
    If you Google HC-SR04, you will find an ample list of retailers/supply - especially eBay
    Exop
    2 years ago
    Great project! I have to ask if it is possible to use these sensors underwater? If you waterproof them of course.
    we can use another type of distance sensor?or the same ...for example sharp distance sensor?/
    Please tell me about the code change if I want to stop it, not to divert its path
    AbD3
    2 years ago
    i don't wanna divert the path.. I just want to stop it when any obstacles detect.. So what should be changed in the code.. and
    what is the unit of distance in : }else if(distance < 15){
    If you want a cheap chassis kit go on ebay and seach arduino smart car kit or you can make your own with cardboard ,wood or plastis.
