Introduction: Arduino + L298 Motor Driver Integrated
Picture of Arduino + L298 Motor Driver Integrated
A motor controller is a device that serves to govern in some predetermined manner the performance of an electric motor. A motor controller might include a manual or automatic means for starting and stopping the motor, selecting forward or reverse rotation, regulating the speed and torque, and protecting against overloads and faults.
This Dual Motor Controller is easy to use, thank's to the L298 motor driver chip. This chip allows for direct drive of two bi-directional DC motors, and incorporates high-speed short diodes for protection. Drive current up to 2A per motor output. The driver uses a broad-brush design to reduce wire resistance.
Materyal list:
- 1 x Arduino uno
- 2 x DC motors
- 1 x L298 motor driver integrated
- 1 x 9 - 12V Battery
Step 1: L298 Dual H-Bridge DC Motor Controller
Picture of L298 Dual H-Bridge DC Motor Controller
L298 Dual H-Bridge
• Based on popular L298 Dual H-Bridge Motor Driver Integrated Circuit
• Motor supply: 7 to 24 VDC
• Control logic: Standard TTL logic level
• 4 Direction LED indicators
The L298 Dual H-Bridge DC Motor Controller will allow you to easily and independently control two motors of up to 2A each in both directions.It is ideal for robotic applications and well suited for connectionto a microcontroller requiring just a couple of control lines per motor.It can also be interfaced with simple manual switches, TTL logic gates,relays, etc
Step 2: Circuit Design
Picture of Circuit Design
So the circuit connection is shown in the appendix.
Each motor is controlled by two pins on the motor controller:
OUTA and OUTB connect MOTOR1
OUTC and OUTD connect MOTOR2
INTA ------ pin 6 on Arduino for control MOTOR1
INTB ------ pin 5 on Arduino for control MOTOR1
INTC ------ pin 4 on Arduino for control MOTOR2
INTD ------ pin 3 on Arduino for control MOTOR2
VCC ---- between 4,8V and 48V
GND ---- Common Ground
+5 ---- +5V from Arduino
Step 3: Software and Video
first the motors will rotate in the forward then all motors stop next the motors will rotate in the back.
// Software
int input1 = 3; // Arduino'nun 3. digital pinine bağlanmıştır.
int input2 = 4; // Arduino'nun 4. digital pinine bağlanmıştır.
int input3 = 5; // Arduino'nun 5. digital pinine bağlanmıştır.
int input4 = 6; // Arduino'nun 6. digital pinine bağlanmıştır.
void setup() { // Serial.begin (9600);
//Motorları sürmek için input pinleri çıkış olarak ayarlandı.
//Motors have been set up to drive the input to the output pins.
pinMode(input1,OUTPUT);
pinMode(input2,OUTPUT);
pinMode(input3,OUTPUT);
pinMode(input4,OUTPUT);
void loop() { //MOtorlar İleri //forward digitalWrite(input1,HIGH); digitalWrite(input2,LOW); digitalWrite(input3,HIGH); digitalWrite(input4,LOW); delay(1000); //1 saniye bekle //1 second wait
// Motorlar DURSUN // stop digitalWrite(input1,LOW); digitalWrite(input2,LOW); digitalWrite(input3,LOW); digitalWrite(input4,LOW); delay(500); //0,5 saniye bekle //0,5 second wait
//Motorlar Geri // back digitalWrite(input1,LOW); digitalWrite(input2,HIGH); digitalWrite(input3,LOW); digitalWrite(input4,HIGH); delay(1000); //1 saniye bekle // 1 second wait
Thanks everybody.
antros888 (author)2017-10-09
Excelente explicacion y documentacion de este integrado L298N.
Gracias!.
DIY Robotics (author)2016-04-10
Nice! Awesome and Clear Tutorial!
About This Instructable
9,026views
27favorites
License:
Bio: I am electronic engineering.
More by MustafaT2:Arduino + L298 motor driver integratedarduino+RF moduls
Add instructable to:
