Arduino LCD 16x2. Turn Single Screen Into Multiple Screens.
10,360
49
22
Posted
Introduction: Arduino LCD 16x2. Turn Single Screen Into Multiple Screens.
Hi! Do you think your lcd is not bigger enough for your project? What if i tell you maybe you are wrong and with a simple code trick and two buttons you can enlarge your lcd and create sub screens to show more data or messages, and with an extra button we can create an eficient interface to navigate beetwen pages and change states and setpoints.
Also, this tutorial is useful if you have reduced space for your project.
I have divided this tutorial into 5 progresive steps to understand the code better.From simple menus to nice functions like auto return , auto scroll, backlight auto off and a functional interface. Also, i have included fritzing schematics and a video!.
Maybe the codes seems complex, but are just a few instructions repeated several times for the different items.
Materials
-Arduino UNO
-Lcd 16x2
-10K trimpot
-Push buttons x3
-10K resistor x3
-RGB led (I am using a common cathode module)
-Led
-220 ohm resistor
-Breadboard,jumpers,wires, etc.
Step 1: Basic Multiple Screen
I will assume you are familiar with lcd 16x2 and his functions. First, mount the circuit.
To get multiple screens we will create a variable called "page_counter" and the default value is 1 (first page or home page).
int page_counter=1 ; //To move beetwen pages
With the buttons we add or subtract 1 and move the counter from 1 to 3 (total of pages). I have used the next function to use push buttons (worked for me for years) they are configured as pull down, that means the pin are always conected to gnd by 10K resistor (LOW) and when you press the button will be conected to 5v (HIGH). Let´s take the pin8 (up button) as example:
1)_Declare pin 8 .Normally, i put the same name of what will do, in this case "up".Will be called later by a custom function
int up = 8; //Up button
2)_Create and store the states (last and current) as boolean. I use the name of function as prefix "_up" to don´t mess the code.
boolean current_up = LOW;
boolean last_up=LOW;
3)_Create a custom function to read pins and "watch" if the state of pins has changed (from low to high) and return what pin state has changed. As i have said, this is a custom function and is not inside void setup or void loop and works for all buttons , so you don´t need to repeat.
//---- De-bouncing function for all buttons----//
boolean debounce(boolean last, int pin) {
boolean current = digitalRead(pin);
if (last != current) {
delay(5);
return current;
4)_Inside void loop. Create the de-bounce function to call custom function
current_up = debounce(last_up, up); //Debounce for Up button
5)_Inside void loop. Use the function!!
if (last_up== LOW && current_up == HIGH){
...Do what you want...
last_up=current_up //store the last state of button
In this case, will add 1 if is lower than 3, if the page is higher than 3 (else function) you will stay on page 3 (last page). If you want to go from page 3 to home page 1 (cyclic), change
page_counter=1; You will see that on the auto scroll step.
//Page Up
if (last_up== LOW && current_up == HIGH){ //When up button is pressed
lcd.clear(); //When page is changed, lcd clear to print new page
if(page_counter <3){ //Page counter never higher than 3(total of pages)
page_counter= page_counter +1; //Page up
else{ // If page higher than 3 , stay on page 3
page_counter= 3;
last_up = current_up;
Note that the first action when you press the button is lcd.clear(),so when you press a button the lcd is clear to print the new page. At the end, always store the last state of buttons! (last_up=current_up)
The real trick here is to asign an entire page to the "counter_page" number. For that, we will use the Switch function.
So we start by declaring switch variable is page_counter and will have the value 1, 2 or 3 (number of pages). I am making this tutorial with 3 pages, but you can add as many pages as you want (well....as the memory want). The diferent screens will show you a message,but here you can display your messages , values of sensors, etc. Use every "case" as normally use a single lcd.
switch (page_counter) {
case 1:{ //Design of home page 1
lcd.setCursor(5,0);
lcd.print("This is");
lcd.setCursor(5,1);
lcd.print(" Home Page");
break;
case 2: { //Design of page 2
lcd.setCursor(5,0);
lcd.setCursor(4,1);
lcd.print("Page 2");
break;
case 3: { //Design of page 3
lcd.setCursor(1,0);
lcd.print("You are now on");
lcd.setCursor(4,1);
lcd.print("Page 3");
} break;
}//switch end
}//loop end
Watch the video!!
Step 2: Auto Scroll Function
This is another simple trick. Will change the page without press any button at the time interval you want.Very useful to show the info of diferent screens.Here we introduce the use of millis . Millis are very useful and let you take some actions at specific time without stop the program, a very good alternative instead the use of delay. You can always use the buttons, but if there is no action (button pressed) the counter will start and when the interval time is reached , will go to the next page an so on. If you press any button the counter will be reset. The counter is displayed on left bottom corner and let you see the counter status.
The code has some modifications.
1)_ Introduce the following variables to establish the first state of millis(0) and the desired wait time (interval).
//Variables for auto scroll
unsigned long previousMillis = 0;
unsigned long interval = 10000; //Desired wait time 10 seconds
2)_ Now when use the up button and the counter is 3 (last page) it will go to page 1 and when use the down button and the counter is 1 (first home page) it will go to page 3. This allow to rotate from 1 to 3 and return to 1 and vice versa ( code line 64 and 78)
3)_Inside void loop. We take the current millis. This is like to watch your clock and know what time is.The first state is 0 (unsigned long previousMillis = 0;) and will run untill the diference is equal to interval time(10000) When interval is reached , add 1 to page_counter and change page. Remember that 10000 millis are 10 seconds. Then the previousMillis variable will be replaced by the last millis and so on. As the clock example, if you need to do something every 10 minutes and start from 12 o´clock, You watch your clock and wait to 12:10 and do something, then 12:10 is your new start point and wait to 12:20 and so on...
unsigned long currentMillis = millis(); //call current millis
lcd.setCursor(0,1); // Show millis counter status
lcd.print((currentMillis-previousMillis)/1000);
if (currentMillis - previousMillis > interval) { //If interval is reached, scroll page
previousMillis = currentMillis; //replace previous millis by current millis as new start point
lcd.clear(); //lcd clear if page is changed.
if (page_counter <3){ //Page counter never higher than 3 (total of pages)
page_counter = page_counter +1; //Go to next page
else{
page_counter=1; //if counter higher than 3 (last page) return to page 1
4)_ If any button is pressed the counter is reset. In other words,previous millis will be replaced by current millis
if (digitalRead(8) == HIGH || digitalRead(10)==HIGH){ // Reset millis counter If any button is pressed
You can use longer time interval if you want.
Step 3: Auto Return Function
This function is based on the previous step and when time interval is reached, will return to home page.
The code works the same as auto scroll, but instead to add 1 to page_counter , will set page_counter to 1 (home page) and the same, if any button is pressed , the counter will be reset.
//-----------Auto return function---------------//
if (currentMillis - previousMillis > interval) { //If interval is reached, return to home page 1
lcd.clear();
page_counter = 1;
Step 4: Making a Sub Menu Interface
At this point, we only show messages on the lcd. Let´s make something functional. Now we can control/show more variables than with a single lcd. For this example, we will control a rgb led and the brightness of a single led. Here i introduce a thirth button (select) to move the submenus, works increasing the sub page counter and changing the position of a cursor beetwen items.
In order to use only 3 buttons, we need to disable up and down buttons to make them work on sub menus. For that, an "if" statement is set: up/down buttons only work if sub page counters are 0 ,so when select button is pressed, sub page counter will be increased and will disable up/down buttons and now they can be used on submenus, to activate or increase values on submenus items.
Based on the multiple screens code, we add variables for submenus (page 2 and 3).
int subpage_counter=0; //To move submenu 1 RGB
int subpage2_counter=0; //To move submenu 2 Led
-Declare all pins we will use. Pin 11 will be used on "led brightness" because is pwm. Pin A5 (analog) configured as output to control blue led.
//-------Pins-----//
int up = 8; //Up/Yes button
int sel = 9; //Select button
int down = 10; //Down/No button
int led = 11; //Led (pwm output)
int red = 13; //red color
int green =12; //green color
int blue = 19; //blue color (A5 as output)
-Add select button state
boolean current_sel = LOW;
boolean last_sel = LOW;
-Declare inititial state of leds.
//--------Led states-----------//
boolean red_state = LOW;
boolean green_state = LOW;
boolean blue_state = LOW;
int led_lum =00;
-Two custom characters has been created :arrow , to indicate the position of what we want to change. Back, to indicate submenu exit.
Characters was created here:
https://omerk.github.io/lcdchargen/
-Inside void setup, we declare pin modes and custom characters.
void setup() {
// Declare pin modes
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue,OUTPUT);
pinMode(led,OUTPUT);
lcd.begin(16,2);
lcd.createChar(1, back);
lcd.createChar(2, arrow);
Void loop
-"If" statement for up/down buttons
if(subpage_counter==0 && subpage2_counter==0){ // up/down buttons enabled if subcounters are 0,Disabled if 1,2..etc to work on submenus
...Up function...
...Down function...
Switch
- Case 1: show "Led Control" as home page(no actions here)
- Case 2: We start with the static objects.Then, select button will go from 0 to 4 (R, G, B, Back) when pressed and will set the cursor in front of items. At the same time, that position let us take some actions(turn on leds and exit submenu). Note that when we change position, the first action is delete the last position of cursor (lcd.print(" "); //Delete last arrow position) just writing nothing. If you press "yes" the code change the led state(LOW to HIGH) , "N" to "Y" and led will turn on (change led state ), and the oposite if you press "no". This function is repeated for all leds or subpage_counter 1,2,3. If you press "yes" when cursor is in front of "back" character (subpage_counter=4), subpage_counter will be 0 and exit the submenu and the Up/Down buttons are now enabled to move the pages. if you press "no" subpage_counter will be 1 to start again.
-Case 3:Works almost the same as the previous function, with two positions(subpage2_ counter=1 or 2). Here we move led_lum variable from 0 to 10. Then we compare led_lum with pwm function, where 0 is analogWrite=0, 1 is analogWrite=25,........10 is analogWrite=225.
After Switch function, we check the led states(R,G;B) and turn on or turn off.
Sub_counter page status are displayed on the top left corner.
Watch the video to see how it works!
Now, you can apply and improve the code, to be be used on your projects and turn on devices or change setpoints,etc.
Step 5: Backlight Auto Off and Contrast Control
We know how to use millis and control led brightness. Why don´t we use it on lcd backlight or contrast ?. Useful if you want to save power or make your project look nice.
Here you have 3 codes:
1-Backlight auto off. If you are not using the lcd, the millis counter function will turn off the lcd backlight and will turn on if you press any button.Use "Backlight control" schematic
2-Backlight fade. The same previous function, but this time if "backlight" is low, will decrease the output of pwm pin 11 from 255 to 0. If you press any button, the pwm output will be increased fom 0 to 255. Use "Backlight control" schematic.
3-Backlight or contrast control. Using the same code on step 4 , connect VO (contrast) or A (lcd anode) to pin 11 (pwm) and adjust the contrast with the led brightness function. If you want to use this function, try not to start from 0 , use 5 as medium initial value (led_lum)
I hope this tutorial helps you!!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    2 Questions
    very nice write up! any easy way to make this work with a joystick module instead of push buttons?
    Hi! Thanks for the comment! I Just tried the code with a rotary encoder, do you want this for a project?
    hi I'm totally new to programming and Arduino that said I've got stuck now at the following project
    I want to build a temperature and time controlled oven so I've used your code because this is the only one I can make a bit work. so I've changed your code a bit (names and values ) also I add a temperature module. so at this state it starts up gives me the beginning screen I can scroll through certain screens but when I come to my temperature screen it sticks there for few sec and it's really hard to get back. I've used your brightness control to set my temp. that works ok i guess because my relay switches on and off at set temp. it looks likes 2 screens are printed over each other. i also want an adjustable timer that master controls the relay so when the time expired the heating will stop.
    sorry for my lack of experience i hope you can help me out and learn me some more, please :)
    greetings from Holland :D
    // NJarpa
    // Led Control using multiple screens and submenus
    #include
    #include
    #include
    #include
    #include
    #include
    //aangeven welk scherm er gebruikt wordt?
    LiquidCrystal_I2C lcd (0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
    //Counters to change positions of pages and sub-menus
    float R1 = 10000;
    float logR2, R2, T;
    float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
    int TempAsk = 0;
    int Vo;
    int ThermistorPin = 0;
    //---------Storage states of buttons for debounce function-----//
    boolean last_down = LOW;
    boolean current_down = LOW;
    int led_lum =00;
    //Custom return char
    byte back[8] = {
    0b00100,
    0b01000,
    0b11111,
    0b01001,
    0b00101,
    0b00001,
    0b00001,
    0b11111
    //Custom arrow char
    byte arrow[8] = {
    0b01000,
    0b00100,
    0b00010,
    0b11111,
    0b00010,
    0b00100,
    0b01000,
    0b00000
    void setup() {
    lcd.begin(16,2);
    delay(5);
    return current;
    void loop() {
    current_sel = debounce(last_sel, sel); //Debounce for Select button
    current_down = debounce(last_down, down); //Debounce for Down button
    //----Page counter function to move pages----//
    //Page Up
    if (last_up== LOW && current_up == HIGH){ //Up button pressed
    lcd.clear(); //Clear lcd if page is changed to print new one
    else{
    page_counter= 1; //If higher than 3 (last page) stay on page 3(change to 1 if you want to rotate)
    last_up = current_up; //Save up button last state
    //Page Down
    if (last_down== LOW && current_down == HIGH){//Down button pressed
    if(page_counter >1){ //Page counter never lower than 1 (total of pages)
    page_counter= page_counter -1; //Page down
    else{
    page_counter= 1; //If lower than 1(first page) stay on page 1(change to 3 if you want to rotate)
    last_down = current_down; //Save down button last state
    //------- Switch function to write and show what you want---//
    lcd.setCursor(2,0);
    lcd.print("Heat-O-Matic");
    lcd.setCursor(2,1);
    lcd.print("Ver. 1.0");
    }//case1 end
    break;
    //Static objects
    Vo = analogRead(ThermistorPin);
    R2 = R1 * (1023.0 / (float)Vo - 1.0);
    logR2 = log(R2);
    T = (1.0 / (c1 + c2*logR2 + c3*logR2*logR2*logR2));
    T = T - 273.15;
    //T = (T * 9.0)/ 5.0 + 32.0;
    lcd.setCursor(0, 0);
    lcd.print("SET TEMP=");
    lcd.print(led_lum);
    lcd.print(char(223));//print the unit" ℃ "
    lcd.print('C');
    lcd.setCursor(0, 1);
    lcd.print("Temp= ");
    lcd.setCursor(5, 1);
    lcd.print(T);
    lcd.print("C");
    delay(200);
    if (T < led_lum)
    digitalWrite(red, HIGH); //open the relay
    delay(1000); //wait for 1 second
    } else
    digitalWrite(red, LOW); //Close the relay
    lcd.setCursor(15,1);
    lcd.write(byte(1)); //Return custom char
    /* case 2: { //Design of page 2 RGB control
    //Static objects
    lcd.setCursor(1,0);
    lcd.print("Programma's");
    lcd.setCursor(1,1);
    lcd.print("Heat");
    lcd.setCursor(6,1);
    /* lcd.print("G");
    lcd.setCursor(11,1);
    lcd.print("B");
    *//*lcd.setCursor(15,1);
    //Functions
    // Sub counter control
    if (last_sel== LOW && current_sel == HIGH){ //select button pressed
    if(subpage_counter <2){ // subpage counter never higher than 2 (total of items)
    subpage_counter ++; //subcounter to move beetwen submenu
    else{ //If subpage higher than 4 (total of items) return to first item
    subpage_counter=1;
    last_sel=current_sel; //Save last state of select button
    //First item control(subpage_counter =1) red led
    if(subpage_counter==1){
    lcd.setCursor(14,1);
    lcd.setCursor(0,1);
    lcd.write(byte(2));
    if (last_up== LOW && current_up == HIGH){ //Up, red led on
    red_state=HIGH;
    last_up=current_up;
    if(last_down== LOW && current_down == HIGH){//Down, red led off
    red_state=LOW;
    last_down=current_down;
    if(red_state==LOW){
    lcd.setCursor(5,1);
    lcd.print("N");
    else{
    lcd.setCursor(5,1);
    lcd.print("Y");
    /* //Second item control (subpage_counter=2) green led
    if(subpage_counter==2){
    lcd.setCursor(0,1);
    lcd.setCursor(5,1); //Place the arrow
    lcd.write(byte(2));
    green_state=HIGH;
    last_up=current_up;
    green_state=LOW;
    if(green_state==LOW){
    lcd.setCursor(8,1);
    lcd.print("N");
    else{
    lcd.setCursor(8,1);
    lcd.print("Y");
    //Thirth item control (subpage_counter=3) blue led
    if(subpage_counter==3){
    lcd.setCursor(5,1);
    lcd.setCursor(10,1); //Place the arrow
    lcd.write(byte(2));
    blue_state=HIGH;
    last_up=current_up;
    blue_state=LOW;
    if(blue_state==LOW){
    lcd.setCursor(13,1);
    lcd.print("N");
    else{
    lcd.print("Y");
    /*//Fourth item control (subpage_counter=4) back
    lcd.setCursor(14,1); //Place the arrow
    lcd.write(byte(2));
    if (last_up== LOW && current_up == HIGH){ //Yes button pressed
    lcd.print(" "); //Delete arrow
    subpage_counter=0; //if sub page 0, exit sub menu, up/down pages enabled
    last_up=current_up;
    if(last_down== LOW && current_down == HIGH){//No button pressed
    subpage_counter=1; //Stay on sub menu, return to R
    }//case2 end
    break;
    //Static objects
    lcd.setCursor(2,0);
    lcd.print("Set-Temprature");
    lcd.setCursor(7,1);
    if(led_lum <10){ //To avoid "0" of number 10
    lcd.setCursor(7,1);
    lcd.print("0");
    lcd.print(led_lum);
    // Sub counter 2 control
    if(subpage2_counter <2){ // subpage counter never higher than 2(total of items)
    subpage2_counter ++; //subcounter to move beetwen submenu
    else{ //If subpage higher than 2 (total of items) return to first item
    subpage2_counter=1;
    subpage2_counter=1;
    //First item control(subpage2_counter =1) Set temprature
    if(subpage2_counter==1){
    lcd.setCursor(6,1);
    lcd.write(byte(2));
    //Control led_lum variable
    if (last_up== LOW && current_up == HIGH){ //Up bright +
    if(led_lum < 65){ //led_lum never higher than 65 (max value)
    led_lum ++ ;
    else{
    led_lum = 0; //If led_lum higher than 10, return to 0
    last_up=current_up;
    if(last_down== LOW && current_down == HIGH){ //Down bright -
    if(led_lum >0){ //led_lum never lower than 0
    led_lum --;
    else{
    led_lum = 0;
    //PWM Control (pwm output 0 to 255 divided by 10 ,pin 11)
    if(led_lum==0){
    analogWrite(led,0);
    if(led_lum==1){
    analogWrite(led,25);
    if(led_lum==2){
    analogWrite(led,50);
    if(led_lum==3){
    analogWrite(led,75);
    if(led_lum==4){
    analogWrite(led,100);
    if(led_lum==5){
    analogWrite(led,125);
    if(led_lum==6){
    analogWrite(led,150);
    if(led_lum==7){
    analogWrite(led,175);
    if(led_lum==8){
    analogWrite(led,200);
    if(led_lum==9){
    analogWrite(led,225);
    if(led_lum==10){
    analogWrite(led,255);
    //Second item control (subpage2_counter==2) back
    if(subpage2_counter==2){
    lcd.setCursor(6,1);
    lcd.write(byte(2));
    subpage2_counter=0; //Exit submenu, up/down pages enabled
    lcd.print(" ");
    last_up=current_up;
    subpage2_counter=1; //Stay on sub menu, return to led_lum control
    }//case3 end
    break;
    }//switch end
    //------------Change led states---------//
    if(red_state==HIGH){
    digitalWrite(red,HIGH);
    if(red_state==LOW){
    digitalWrite(red,LOW);
    if(green_state==HIGH){
    digitalWrite(green,HIGH);
    digitalWrite(green,LOW);
    if(blue_state==HIGH){
    digitalWrite(blue,HIGH);
    digitalWrite(blue,LOW);
    //Show sub counters status,delete or comment if not needed
    lcd.setCursor(0,0);
    lcd.print(subpage_counter);
    lcd.setCursor(1,0);
    lcd.print(subpage2_counter);
    //loop end
    Check your inbox
    11 Comments
    i tinkered around with the coding and just got it working!! I must of looked at 15 menu tutorials trying to get this aquarium system up an running on a 20x4 LCD, mega2560 and yours is by far the easiest to understand and modify. thank you once again for this write up!
    last_up = current_up; why use this. I don,t get it . So,please explain.(I am a Learner).
    Hi! remember you have an "if" statement :if (last_up== LOW && current_up == HIGH){
    Follow the code , at the begining you have:
    boolean last_up = LOW
    boolean current_up=LOW
    So ,if no button is pressed, the "if" statement is false (last_up and current_up are LOW)
    If you press the button(up) current_up=HIGH and the"if" statement is true and add page
    Now, remember arduino can do a lot of things in 1 second so , for you is just a touch of the button,but for arduino can be thousand of times.
    Think in milli seconds, you are pressing the button,so current_up=HIGH.
    You store that on last_up=current_up ,that means last_up=HIGH
    The code is running fast and you keep pressing the button,so
    if (last_up== LOW && current_up == HIGH) is false because last_up=HIGH
    THis function allows you to store the last state of the button.So ,you need to release the button (last_up will be LOW again) to add, or do something again.If not the add function will be as fast as the micro is running.Try to comment that line ( //last_up=current_up) and you will see what i'm talking about.Regards!
    Thanks, Bravo
    At the end of the steps, press "download"....
    Hello Nicolas
    Wonderful explanation and work. I have in plan to create the stand alone power press feeder, with stepper motor and LCD. The push buttons are needed to modificate the feeding lenght. The problem is that I am not too much familiary with arduino. Can you help to me to implement the push buttons into main program?
    Arpad
    Hi! If you want to move a variable or setpoint, the "light brightness" example shows you how. I think that you can find a more specific tutorial about what you want on the web.
    hi,
    nice one, will this work using I2C LCD
    thanks
    Hi!
    Yes, just include the libraries and code needed and use every "case" as single lcd.
