Arduino - LDR With LED
45,639
81
6
Published
Introduction: Arduino - LDR With LED
About: For more project and tutorial visit my YouTube channel Mert Arduino and Raspberry Pi
This is simple arduino project; turn on LED when it's dark and turn off when is light.
Step 1: Hardware Required :
  • Arduino Uno
  • LED
  • LDR (photoresistor)
  • 220 and 10k ohm resistors
  • Wires
  • Breadboard
Step 2: LED Connection
  1. LED attach to board
  2. Resistor (220 ohm) one leg attach to LED long leg
  3. The green wire attach to resistor's empty leg
  4. The brown wire attach o LED short leg
Step 3: LDR Connection
  1. LDR attach to board
  2. Resistor (10k ohm) attach to LDR one leg
  3. The purple wire attach to LDR other (empty) leg
  4. The yellow wire attach to LDR and resistor same column
  5. The white wire attach to resistor empty leg
Step 4: Arduino Connections
  1. The green wire connect to digital 13 from resistor leg
  2. The brown wire connect to GND from LED short leg
  3. The purple wire connect to +5V from LDR
  4. The yellow wire connect to A0
  5. The white wire connect to GND
Step 5: Code
const int ledPin = 13;
const int ldrPin = A0;
void setup() {
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
pinMode(ldrPin, INPUT);
void loop() {
int ldrStatus = analogRead(ldrPin);
if (ldrStatus <=300) {
digitalWrite(ledPin, HIGH);
Serial.println("LDR is DARK, LED is ON");
else {
digitalWrite(ledPin, LOW);
Serial.println("---------------");
Step 6: If It Helps, Please Subscribe
First of all, I would like to thank you for reading this guide ! I hope it helps you.
If you want to support me, you can subscribe my channel and watch my videos.
Mert Arduino Tutorial & Projects
2 People Made This Project!
  • Clocks Contest
    Clocks Contest
  • Make it Move Contest
  • Planter Challenge
    Planter Challenge
2 Questions
in ldrStatus
what is 300?
6 Comments
I tried this and the LED light stays on despite what the input from the LDR says. The LED light on the Arduino board responds to the LDR but the LED doesn't.
What's wrong???
Can somebody please explain what is the purpose of the resistor next to the LDR?
That is the only part that i do not understand.
10k resistor along with the LDR to create a voltage divider circuit. The varying resistance of the LDR is converted to a varying voltage that the analog pin of the Arduino will then be using in its logic.
The 10k resistor creates a voltage divider circuit. The varying resistance of the ldr is converted to a varying voltage that the analog pin of the Uno can use.
This is a very nice tutorial if you want to extend the circuit to more complex functions afterwards. Will for sure be useful to many tinkers. For a basic circuit like this no Arduino is needed, there are instructables on this.
