Arduino Laser Alarm
Published
Introduction: Arduino Laser Alarm
Parts:
  • 1X 5v Buzzer
  • 1X 3v LED (Any colour)
  • 1X 10K resitor
  • 1X 1k resitor
  • 1X photoresistor
  • 1X laser
  • 1X Arduino (any board)
  • 1X breadboard
  • 1+ jumper wires
Things you may want to add:
  • siren light
  • relay to control any thing
  • mirrors
Step 1: Breadboard:
First make sure your Arduino is turned OFF.
Plug two jumper wires into the power row on the breadboard, plug one end of the Buzzer into GND and the other into Pin 7.
The led is plugged into GND and Pin 13 with a 1K resistor and the Photoresistor into GND and the other end has a 10K resistor is plugged into 5v.
Then plug in a jumper wire from the same pin were the Photoresistor and 10K resistor meet into Pin AO.
Step 2: Upload Code to Arduino
Plug your board into your computer and upload.
You may need to adjust the code to work with your lighting.
Step 3: Things You May Want to Add
Siren light:
Take your light apart and remove all unneeded things inside and glue an LED in and plug the wires into were it was before.
______________________________________________________________________________________________
Relay:
Plug your relay into GND, 5v and Pin12
The code for relay and a servo is above
Mirrors:
Place the laser some were then place a mirror were the laser shines and do this till you like it, But make sure to aim it at the Photoresistor at the end.
Step 4: Setup
Place the laser some were and aim it at the Photoresistor.
Turn one your Arduino and your done!
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    9 Comments
    https://www.instructables.com/id/IR-laser-person-counter/
    Yes, the relay(s), mirror(s) and light(s) are optional
    Try copying & pasting this:
    //Laser Tripwire sketch
    #include <Servo.h>
    Servo myservo;
    int Servoval;
    #define LED 13 //LED is connected to pin 13
    #define Buzzer 7 //Buzzer is connected to pin 7
    #define Sensor 0 //Photoresistor is connected to pin 0
    int val = 0; //val is used to store state of input pin
    void setup() {
    myservo.attach(9);// plug the servo into digital 9
    pinMode(LED, OUTPUT); //sets digital pin as output
    pinMode(Buzzer, OUTPUT); //sets digital pin as output
    pinMode(Sensor, INPUT); //sets analog pin as input
    void loop() {
    val = analogRead(Sensor); //read input value of sensor and store it
    if (val<5) // if the sensor goes below 100...
    digitalWrite(LED, LOW); //turn off LED
    myservo.write(0);
    digitalWrite(Buzzer, LOW); //turn off buzzer
    else if (val>10)
    myservo.write(0);
    digitalWrite(LED, HIGH); //else, keep LED on
    digitalWrite(Buzzer, LOW); //else, keep Buzzer on
    delay(100);
    digitalWrite(Buzzer, HIGH);
    delay(50);
    delay(500);
    myservo.write(180);
    delay(700);
    The code is an Arduino file on step 2
    I love this idea! Thanks for sharing! Anything with lasers is awesome!
