Also - checkout the LaserTweet Instructable to make this project display data from Twitter:
http://www.instructables.com/id/LaserTweet-Twitter-Projecting-Laser-Show/
This project uses an Arduino and some cheap audio speakers to create a real laser show with full X and Y axis control.
The included source code lets you easily draw text and even simple pictures!
View the demo video to get an idea of what this project can do.
You should be able to get most components locally (besides the Arduino).
Assuming you already have an Arduino - expect to spend roughly $35 on this project.
If you can upload a program to an Arduino and solder - you can probably build this project in an afternoon.
Users who have built this project:
mattbeowulf - http://www.youtube.com/watch?v=AnIoWZpEWk8
minhenes (using "real" galvos) - http://www.youtube.com/watch?v=BmYg3O4hlMg
hydronics - http://www.youtube.com/watch?v=5Q3nJLA2t18
http://www.instructables.com/id/Guerilla-Laser/
benhgd - http://www.youtube.com/watch?v=K23-ThlCZEc
(Post a comment with your link - and I'll add yours to this list)
Step 1: A Bit About Laser Shows
Galvonometers are electromechanical devices that rotate to different angles based on how much voltage they are provided.
A minimum of two galvos are used - one for "X" (horizontal) control and one for "Y" (vertical control).
The laser show's controlling electronics quickly adjusts galvo voltages, and turns the laser on and off - moving it around so quickly that it appears to create a persistent image.
Commercially available galvos can move to up to 50,000 different points each second.
Galvos tend to be expensive - so we'll be making our own out of audio speakers!
Step 2: Stuff You'll Need - Electronics
This project has been tested on an Arduino Duemilanove (Atmega 328). Other 16MHZ Arduino boards with an Atmega 328 (such as the Uno) should work fine.
An Arduino with an Atmega 168 should work - but be aware the project barely fits into its memory - so you may hit issues adding your own functionality.
It's assumed you have a programming cable, a computer with the Arduino environment installed, etc.
Red Pocket Laser Pointer
Look for one powered by three 1.5v coin cell batteries.
If you're having trouble finding one at your favorite super store - check the pet toys section.
12v 3 Amp Power Supply
Voltage can be a bit higher or lower but needs to provide at least 3 amps of current.
You might find an old laptop power adapter at a thrift store with these specs.
Alternately - you can modify a PC ATX power supply.
Radio Shack Catalog # 22-507 would work fine - but is too expensive for what it is.
If you can't find a usable power supply locally - you can get one on eBay for about $15.
2 x 8-Ohm, 20-watt Non-Inductive Resistors
Available at Radio Shack - Catalog # 271-120
(alternatively - 2 x 6A, 50V Rectifier Diodes Radio Shack #276-1661 - see step 17 for details)
2 x 100-Ohm Resistors
Doesn't need to be exact value / wattage doesn't matter.
Available at Radio Shack - Catalog # 271-1311
2 x TIP120 Darlington Transistors
Available at Radio Shack - Catalog #: 276-2068
2 x TO-220 Heat Sinks (for Transistors)
These are required! Without them the transistors will quickly overheat!
Available at Radio Shack - Catalog #: 276-1363
2 x 470uF 35V Radial-lead Electrolytic Capacitor
Available at Radio Shack - Catalog #: 272-1030
2 x Alligator Clips
These make connecting to the laser pointer's battery leads easier.
Variety of options available at Radio Shack.
22 Gauge Solid Core Hookup Wire
This wire easily fits into Arduino headers. Not needed if you have a better solution.
Available at Radio Shack - Catalog # 278-1221
20 Gauge or Thicker Hookup Wire
For power connections - "speaker wire" should work fine.
Green Laser Parts (Optional)
If you plan on using a green laser - check out step 32 - there are few extra parts you'll need.
Step 3: Stuff You'll Need - Speakers
Speaker quality does make a difference in performance.
I've found speakers with large magnets and power ratings of 80 watts or more tend to work best.
Look for something that might be capable of producing some bass. You should be able to easily push the speaker cone in by about a 1/4" if you press on it.
Using a speaker larger than 6" will not necessarily help (and might hurt) performance.
The speakers do not have to match.
I extracted the pictured speakers from a set of 120 watt bookshelf-sized speakers I bought for $8 at a local thrift store.
They measure approximately 5 1/2" across and are rated at 6ohm.
Advanced Technical Stuff Below (Optional Reading)
There are at least two technical variables that effect how well a speaker driver will work for the laser show.
Resonant Frequency: The frequency the speaker will vibrate at most easily on its own.
Qts or Q: This number describes how the speaker's frequency response varies around the resonant frequency.
The pictured speakers had a resonant frequency of 63hz and a Qts of .55. They worked quite well.
I also had good luck with speakers having a resonant frequency of 81hz and a Qts of .96.
I have also tested a set of speakers with a resonant frequency of 120hz and Qts of 1.4 - which resulted in poor results.
My suggestion would be to look for a driver with a Qts between .5 and 1 with a resonant frequency between 50hz and 85hz.
Other speaker parameters (like Vas) may or may not effect project performance.
If purchasing speakers from a website like http://www.parts-express.com/ - you'll be able to select from a wide variety of speakers that provide these specifications.
Look for close-outs / deals. As of last check, these drivers: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-065 looked quite promising for only $5 each.
If you want to try testing your own speakers - take a look at this site: http://www.bcae1.com/spboxad3.htm
Step 4: Stuff You'll Need - Mounting Hardware
While this isn't a high-precision operation - it can be a little tricky.
The right tools for the job will depend on the exact size and shape of your speakers.
If you don't already have the items below - look in your toolbox and junk drawer and improvise!
A Variety of C-clamps
4 clamps sized 2 1/2 to 4 inches should work for most speakers.
Spring Clamp
Used to point the laser.
Optional: 18" x 24" Plywood Project Board
This project has a fair number of pieces to it. Keeping everything on a project board can help keep it from getting out of control.
After you get everything working - you may want to replace the C-clamps with some kind of mounting solution that can be more permanently attached to the board (like brackets).
Step 5: Stuff You'll Need - Tools and Misc.
About $2.50 at your local sporting goods store.
2 x #6 Bolts and Nuts
For mounting heat sinks to transistors / length doesn't matter.
2 x Wood Skewers
Like for cooking Shish Kabobs.
Scotch Tape
Or any kind of tape.
4 x 2x4 Lego Blocks
These are just used as spacers. You can substitute anything of similar shape / size.
Soldering Iron
And solder - gauge doesn't matter.
Hot Glue Gun
And hot glue - attempt other adhesive techniques at your own risk.
Bandsaw or Hacksaw
Used to cut the acrylic mirror. A rotary tool with a cutoff wheel should also work.
Step 6: Cutting the Mirrors
Cut out the mirror squares using a band saw, hacksaw or rotary tool.
If using a band saw - cut face-down with a paper towel between the saw table and mirror to prevent scratching.
Be careful not to peel off the mirror's shiny backing.
Step 7: Install the Pivot Mounts
The top of the Legos should be about 1/4" above the foam surround of the speakers. If they are not - hot glue another object of appropriate thickness on top to achieve the needed height.
Step 8: Install the Mirror Pivot
The skewer will act as a pivot for the mirror.
After the glue cools, trim off the protruding end of the skewer with your cutting instrument of choice.
Step 9: Hot Glue the Mirror
Attach the mirror to the pivot and speaker using a small drop of hot glue at each of its corners.
Step 10: Make the Y Galvo and Label
Now it's time to make the Y galvo.
The Y galvo is exactly identical to the X galvo.
Repeat steps 7 through 9 to make it.
Label one galvo X and the other galvo Y using the method of your choice.
Step 11: Schematic
No need to memorize this - we'll be going over every connection in detail!
(step 17 describes a minor variation on these plans - replacing the resistors with diodes for slightly improved efficiency)
Step 12: Tape Laser Pointer Into On Position
Wrap it around tightly several times to assure it stays in place.
Step 13: Remove Laser Pointer End Cap
Examine inside - most laser pointers will have a spring that is the negative battery terminal.
Step 14: Connect Power Leads to Laser
Connect the other alligator clip to the threading at the end of the case (positive).
Assure the clips don't short each other.
Note: Some laser pointers may be constructed slightly differently - so adjust / improvise as needed.
Step 15: Connect Laser Power Leads to Arduino
Connect the positive laser power lead to Pin 12 on your Arduino.
Cut a short piece of 22 gauge solid core wire and strip both ends.
Insert one end into Pin 12 on your Arduino board. Clip the alligator clip from the positive lead to the other.
Connect the negative laser power lead to a Ground Pin on your Arduino using the same method.
Step 16: Mount Heatsinks to Transistors and Label
Attach them tightly - it should be difficult to move the transistors.
The heat sinks must be installed . The transistors will quickly overheat otherwise.
Label one transistor X and the other transistor Y.
The transistors will act as switches - turning the small electrical signal the Arduino produces into a large electrical signal that can move the galvos.
Note: This part will get hot in normal use. Do not touch it when powered.
Step 17: Connect Resistors to Galvos
Use several inches of wire for these connections - so they won't limit your ability to position the galvos later.
Repeat this step for the Y galvo.
Note on Purpose of Resistors (optional reading)
As several users have noted - the purpose of the resistors seems to be to (inefficiently) eliminate back EMF generated by the speakers.
The resistors can alternately be replaced by diodes (such as http://www.radioshack.com/product/index.jsp?productId=2062591). This will result in somewhat decreased power consumption
The diodes should be connected so that the cathode (the side with the bar) is on the side of the speaker connecting to +12v.
This alteration may require tweaking the Arduino code to get good results (try increasing the x_min_value and y_min_value variables to about 20).
Step 18: Connect Galvos to Positive Power
Connect the negative speaker terminal (indicated with a "-") of the X galvo to the positive lead on your 12v power supply using 20 gauge hookup wire and your soldering iron.
Yes - to confirm -- we're connecting +12v to the negative speaker terminal .
Use ample wire for this connection (12 inches or more) - to assure you can position the galvos as needed later.
Run a separate lead from each galvo back to the 12v power supply. Do not "chain" the connection between the two galvos.
Step 19: Connect Galvos to Transistor Collectors
The collector is the middle lead on the transistor.
Again - use a fairly long length of wire.
Tip: Applying a thin coat of solder to the tips of the connecting wires can help prevent them from unraveling and causing shorts.
Repeat this step for the Y transistor and Y galvo.
Step 20: Connect Transistor Emitters to Ground
The emitter is the right most lead on the transistor as pictured.
Again - use a fairly long length of wire to accommodate moving things around later.
Repeat this step for the Y transistor.
Run a separate lead from each transistor back to ground. Do not "chain" the connection between the two transistors.
Step 21: Connect Power Filtering Caps
Connect the negative lead of a 470uF 35V electrolytic capacitor to the "emitter" lead of the X transistor as pictured.
The negative lead of the capacitor is on the side with the black stripe and "-" symbols.
Don't get this connection backwards - or you'll see smoke!
Connect the other end of the capacitor to the positive terminal of your 12v power supply using 20 gauge wire.
Repeat this step using the second capacitor and the Y transistor.
Step 22: Create Arduino to Transistor Leads
Solder a 100 ohm resistor to the end of each wire.
These resistors help keep the amount of current that flows between the transistors and Arduino to a safe level.
Step 23: Solder Leads to Transistor Bases
The base lead is the one furthest to the left.
Step 24: Connect Leads to Arduino
Insert the bare end of the Y transistor lead into Arduino Pin 6.
Step 25: Connect Arduino to Ground
Step 26: Download Code and Upload it to Arduino
Plug the programming cable into the Arduino.
Download lasershow.zip (attached to this step) - and upload it to your Arduino.
Once the program is loaded - you should see the laser pulsing!
If you don't see the laser pulsing - skip ahead to the step titled "Troubleshooting".
Note: This code was updated on 4/10/11 to address a problem where it might not fit on an Arduino using an Atmega 168.
lasershow.zip5 KBStep 27: Aim Laser and Galvos
This is one of those cases where a picture really is worth a thousand words - especially when taken using a fog machine.
The rundown:
The Y galvo should be positioned with its mirror pivot running horizontally, and the mirror oriented down.
The X galvo should be positioned with its mirror pivot running vertically, and the mirror oriented towards your left.
The laser should be pointed at the mirror of the Y galvo.
The Y galvo should be angled so the laser bounces of its mirror onto the X galvo's mirror.
The X galvo's mirror should be pointed toward where you want the laser show to project.
Step 28: Fire it up!
Leave your USB programming cable connected - as it's needed to power the Arduino (more on this later).
You should be presented with a cacophonous symphony of sound from the speakers - along with an actual working laser show.
You may find you need to slightly re-aim the laser once the speakers move a little.
If things aren't working right - unplug your power supply and proceed to the next step.
Step 29: Troubleshooting / Tweaks
The transistors getting too warm are a common cause of image quality issues. Even if things are generally working - you may be able to further improve quality with better cooling.
Make sure the transistor heat sinks are well installed. Using larger heat sinks, thermal paste, or even adding fan(s) may help.
Check all your wiring. An intermittent connection may be the culprit.
Towards the top of the code - look for the line:
float exp_move = (some number)
The larger this value is - the slower the laser will draw (improving accuracy). Try increasing it to 4.5 or higher.
There are also other variables you can adjust to help quality - see the code comments for details. Experiment!
Speaker quality seems to be the biggest factor in determining how well the laser show works. If you're getting results that look a lot worse than the demo video - you may want to try using another pair of speakers.
Laser isn't on
Check the alligator clip connections going to the laser power lead and case.
Make sure the tape is really holding the laser's power button down.
Laser is dim
I have encountered a few laser pointers that are just dim or don't focus. Try buying another one.
One or both galvos aren't moving / making noise
Disconnect power and check your wiring.
Image is rotated 90 degrees
Try swapping the connections to Pin 5 and Pin 6 on your Arduino.
Image is mirrored horizontally or vertically
This can be fixed either of two ways:
Swap the wires going to the positive and negative connections of the galvo with the inverted axis.
Physically rotate the galvo of the inverted axis by 180 degrees (this may not be practical for the Y galvo).
Image is skewed at an angle
Try rotating either galvo slightly to correct this.
This can also be caused by aiming the laser at a surface that it's not perpendicular to.
Image size
The farther away you aim the laser - the larger the image will be. Typical projection area is about 2 feet by 2 feet at a distance of 25 feet.
The higher voltage power supply you use - the larger the image will be (until of course, something burns up - then you get no image at all...). This project has been tested extensively at 12v - but can probably go a bit higher.
Problems using an Arduino with an Atmega 168
This project -barely- fits in an Atmega 168's ROM and RAM. If you see odd results - it may be that code you've added has "pushed things over the edge." There might be cases where this does not generate a compiler error - making it hard to troubleshoot. Removing the "demo()" function may help free up resources.
Step 30: Change the Code!
Note: If you made it to this step without downloading the source code - it's in a zip file attached to Step 26.
Here's a few of the included routines:
laser_on()
Turns laser on.
laser_off()
Turns laser off.
sendto (X,Y)
Sends laser to X and Y coordinates. The coordinate system is 256 x 256 - but the real resolution is lower (maybe half) that.
draw_string("STRING", X, Y, COUNT)
Draws a text string at X,Y for COUNT times. Uppercase characters, numbers and some punctuation is supported (see code).
move_scale = X
Sets scaling (font size) used by draw_string. Setting it to 2.8 provides enough room for 5 characters.
marquee("HELLO WORLD", CHARACTERS)
Draws a scrolling marquee CHARACTERS long - text is autoscaled to fit (4 to 7 characters long works best).
Now for a little tutorial - look for this code at around line 90:
//put your laser control code here!
void loop()
//run the default laser show demo
demo();
The Arduino runs any code in this section over and over again. Try changing it to:
void loop()
move_scale = 2.8; //sets text size
draw_string("LASER", 1, 1, 10);
draw_string("TEST", 1, 1, 10);
marquee("LET'S DRAW A STAR!!!", 5) ;
//draw a star 15 times
for (int loop = 0; loop < 15; loop ++)
laser_off();
sendto (85,10);
laser_on();
sendto (150,130);
sendto (0,40);
sendto (170,40);
sendto (20,130);
sendto (85,10);
There are a bunch of variables you can tweak and a few more routines documented in the code.
Dig in and have fun! If you mess things up - you can always re-download the code and start over.
Step 31: Some Technical Notes
You might wonder why I didn't include a step to connect the 12v power supply directly to the Arduino board - so the laser show can be used without USB power from the computer.
Most Arduino boards have a maximum recommended input voltage of 12v.
Some "12v" power supplies actually put out 13.8v - and perhaps even higher when not under load. You may want to test your power supply with a multimeter to make sure it's not significantly over 12v before connecting it to the Arduino.
To power your Arduino using your 12v power supply - connect its positive voltage terminal to the Arduino's Vin Pin.
An alternative is to use an external voltage regulator or separate power supply for the Arduino of appropriate voltage.
About the TIP120 Transistors
This project uses TIP120 "Darlington" transistors. These transistors are actually two transistors chained together into one. This gives them much higher "gain" - meaning they can use a very small current to switch a much larger current. They are a cheap and easy way to interface microcontrollers to things like speakers and motors.
PWM not Analog
This project generates a digital PWM (pulse width modulation) signal to control the speakers. You might expect the quickly switching 1's and 0's to get converted to analog before going to the speakers - but they don't!
The signal is switched so fast - that the speakers respond as if they are getting an analog signal.
The picture shows an oscilloscope reading taken right off the speaker leads - still digital!
By default the Arduino does PWM at about 500hz - way to slow for this project. If you look through the code you'll find some tweaks that boost that up to 64,000hz.
Step 32: Green Laser Upgrade!
Green lasers with power ratings over 5mw can blind you instantly! Don't mess with them.
A 5mw green laser takes a lot more current to drive (a few hundred milliamps) than a red laser (maybe 20ma) - so we'll need to add some electronics to support it.
Note:
This setup worked for the 5mw green laser I had kicking around (unfortunately I don't have an exact model number).
Some green lasers may have more complicated driving electronics that may make them difficult to turn on / off quickly enough. If one model doesn't work - you may need to try another.
Additional Stuff You'll Need
A 5mw green laser pointer
Look for one that runs off 2 x AAA batteries.
http://www.amazon.com/American-Science-Surplus-Green-Pointer/dp/B0040YL87Q
(This model will likely work - but has not specifically been tested)
220 ohm resistor
Any wattage
100 ohm resistor
Any wattage
LM317T Adjustable Voltage Regulator
Available at Radio Shack - Catalog #: 276-1778
1 x TIP120 Darlington Transistor
1 x TO-220 Heat Sink (for voltage regulator)
#6 Bolt and Nut
Instructions
1. Build the the laser show as described in the previous steps.
2. Attach heat sink to the voltage regulator using the bolt and nut.
3. Wire in additional parts as shown in the schematic above.
4. That's it!
How it Works
The resistors "configure" the voltage regulator to provide about 3.75v (a bit more than 2xAAA batteries).
The heatsink is required since the regulator is dissipating a large amount of voltage with moderate current consumption.
While the red laser could be driven directly from the Arduino - the green laser consumes way too much power for that.
The TIP120 Darlington transistor uses the small signal from the Arduino to switch on and off the current going to the laser. It's not perfectly efficient - so the 3.75v from the voltage regulator ends up closer to 3v (the same as 2 x AAA batteries). Unlike the TIP120's powering the speakers - the load on this one is low enough so that it doesn't need a heatsink.
All other details of the project are the same. If anything isn't obvious - consult the previous steps.
Step 33: Hack this Project!
Make a 2-player laser pong game using potentiometers as controllers.
Make some kind of interactive art installation.
Make a laser clock / countdown timer.
Connect it to the internet - and have it display your favorite RSS feed.
Drive your cat crazy.
Do something no one has even thought of yet!
Visit Our Store »
Go Pro Today »
Going forward I would recommend using a stronger laser... This would allow you to hit a building or billboard at a mysterious distance... I tried to buy a stronger, $14 green laser from China but the china laser circuit did not allow cycling ON/OFF at quick rate like the cheap laser is used...(this is called blanking in the laser light show industry) You could rewrite the code to be more cursive in nature and less ON/OFF dependent... It would be fun to play with the programming in such a way and easy for a beginner... its all cartesian coordinates... that means easy!
thanks again for all the hours of dinking around....
had similar problems trying to use a green laser too.
suspect it's possible to get it a green laser working with some tweaking - the driver circuits are a bit more involved than is intuitive... (think they tend to involve temperature feedback and such).
if you google it - you can see it's propagated via some commonly copy / pasted code.
good news is that particular line isn't ever called - so has no effect on the project (so I'm gonna leave it be).
-Rich
Many good comments and speculations. I don't know if you or others are still playing with this, but FWIW. Actually, you don't want to damp the back EMF of the speaker. Seems counter intuitive, but I explain. I use real galvos in my laser graphics and the way is to use a current drive (high impedance) instead of voltage drive (very low output impedance, like Sound amps). If you recall, the series LR circuit time constant is L divided by R = L/R. This says that a small R makes the time constant large. The current is slower to build, magnetic field slower to build and cone slower to move. Your transistors are current sources, but as said by another poster, a source/sink drive is better - in essence a "Power OpAmp". Unfortunately, driving 8 ohm speakers requires lots of current. A current drive (Google OpAmp current source) is accomplished by pitting a small resistor in series, to ground, with the coil and feeding the voltage at the top of it back into the OpAmp - yielding a voltage to current converter.
Then you sample the back EMF and use it as feedback, through a pot, so U can adjust it to get the best response. This, however, means that your power supplies (yes you'd need a + and a - supply) have to be high enough voltage to allow this back EMF to go as high as it wants to, so-to speak. The high supply voltage isn't needed to get the high current to flow, just to allow the back EMF to have the room it needs to simply exist. This is called compliance in current source Jargon. The analogy is when a voltage power supply can supply higher current spikes due to requirements of the load. For driving inductance like this (like TV Tube deflection), it turns out that the power supply voltages you choose now becomes one of the limiting factor on the speed you can get out of the 'galvos". Speed being the holy grail of laser graphics. If the back EMF is allowed to hit the power supply rails (thus clipping it), this is equivalent to 'damping' and the response actually starts to slow down and distort the image.
I also would have (I do this for another application) cut away a considerable portion of the speaker cone to allow as fast a movement as possible and reduce damping due to air movement. Don't know if this helps anyone, but FWIW. I am starting the process of putting info on my laser graphics on my web site and will be uploading a schematic for such a drive.
In addition, you should low pass filter (RC low pass) the PWM out before the audio amp.
Yes, an amp down to DC is required (which, internally, many audio amps are already), so it would be possible to turn an audio amp into a DC power OpAmp current source to do this.
Too many plates spinning to go into detail here. Motivated folks can try contacting me on my web site for more...
Cheers, Steve
If so - thing should be moving pretty quick. I would try reverting to the code as provided if you've changed anything.
Besides that- easiest way to increase speed is to change "float exp_move =" to a smaller number.
Look at step 29 for more tweaks.
This is a really great project... im exited to get it going.
I am new with all this laser stuff and getting more involved every day.
I just did a spirograph and works nice but now i want to have some kind of scanner controled with an arduino.
Your project seems very easy to do and looks realy nice, but my question is if this setup would work with hard disk drives as galvos instead of speakers?
I would really apreciate your response.
Best regards,
Alejandro C. from Colombia
Have fun!
-Rich
I was planning to use very small speakers, such as some 50mm 3W speakers available for as low as $3. Even though their excursion is tiny, my idea is to glue a lever to the speaker and then glue it VERY close to the mirror rotation axis, so the mirror would tilt a lot. This would also allow to have really small mirrors (reduced inertia of moving parts = great) and have the added benefit of allowing better operation on higher frequencies (small speakers respond better to higher frequencies), and I guess its performance wouldn't be bad on low frequencies since SPL is irrelevant, we only need excursion to tilt the mirror.
Also, I don't want to use an Arduino, I want to use full-fledged computer software to control the output. Eventually, I would record the audio output from the PC and play directly from a tiny mp3 player. It all would make for a very portable solution, maybe even pocketable.
Any tips on great laser animation software which works nicely with an audio DAC (I mean, with the computer's sound output)? Preferably free software with lots of beamshows available! :P
Sounds like a great project / please post details here as you make progress.
if you want brighter - look at the notes for using the green laser pointer.
see step 17 for info on the diodes (I just added a few other references to it in the project). It will improve performance a little - in that it uses maybe 25% less power - reducing the load on the transistors (which can help drawing accuracy).
figured this out through a little theory - and lots of trial / error...
-Rich
Jim
http://www.instructables.com/id/DIY-Front-Surface-Mirror./
yes - definitely loose some definition in the beam to the back-sided mirrors
I should point out the I didn't spend a lot of time with it - I kind of suspect it would work with the right tweaks. Definitely worth trying!
-Rich
Great instructable, very cleverly done. I especially liked the idea of using a green laser to write messages in the sky!
My guess as to why the MOSFETs didn't work is that the voltage they are switching is a lot more than the gate drive, and so they end up running in ohmic mode and getting really hot. Add the fast PWM, and the gate capacitance may never fully charge and get it kicked over into saturation.
I'm planning to make a darlington of a 2n2222 or similar with the MOSFET, so I can drive the gate with the full 12V. I'm posting about my attempt on www.gizmosmith.com, so I'll have details there when I'm done.
good luck!
Yes - I have tested with smaller speakers. I got one set of 3" 'satellite' speakers working fairly well - but the image was -really- small (maybe 5"x5" at 20 feet).
I was leaving the speakers in their enclosures - which resulted in fairly good control. When I took the speakers out of their enclosures - the image was larger - but really sloppy.
that said - my speaker selection has been influenced by whats in stock at the thrift store - so maybe I just never tested with smaller speakers of good enough quality.
if you end up experimenting with this - let me know how it goes!
I want the device to project criticism on projected artwork, so I need it to be mobile, and have stupidly long throw (e.g. across a city street and up three floors). Once I get mine basically working, I'm going to swap in some smaller speakers.
good luck with your build!
haven't played around just doing "patterns" generated by the arduino - that might be a fun area to explore.
let me know if you get things hooked up to the arduino and shoot some video. I'm adding links to other people's version of this project to the main description page.
-Rich
Provide a more stable load for the transistors to drive
Reduce back-EMF
The effect is definitely to increase how much the speakers are driven and the quality of the rendering.
I came up with this configuration more by experimenting than anything else.
If you aren't getting good results - I would be sure the resistors you are using are rated to handle the power.
since you basically only drive your speakers with either positive, or zero voltage, you could replace the resistors with a diode. the diode should point its arrow the other way than the normal flow of current through your circuit. that would drain away the back-emf, but not also the driving voltage. i assume you would find that you will have increased the gain of your diy galvos, and possibly need to adjust for that....
i don't have the time or resources to try this out anytime in the near future, but i would sure love if you'd try out my suggestion and tell me about the results.
I actually have things setup using a diodes now - works great - and uses a little less power.
Had to make a few tweaks to some variables to get good results - but this is probably a better setup.
I'm going to add some notes to the project (and parts numbers for diodes / etc.)
http://en.wikipedia.org/wiki/Flyback_diode
