Arduino Leonardo Eth V3 and MySql Direct Insert No Intermediate Program or Pc
Published
Introduction: Arduino Leonardo Eth V3 and MySql Direct Insert No Intermediate Program or Pc
Step 1: Arduino
Arduino leonardo eth v3 and mysql This example demonstrates how to store data in a table in mysql from 4 button connected to pins 2, 3, 4, 5 For this, we will create a special database and table for testing. The following are the SQL commands you will need to run in order to setup your database for running this sketch.
CREATE DATABASE machine; CREATE TABLE machine.state ( num integer primary key auto_increment, message char(40), recorded timestamp );
Here we see one database and a table with three fields; a primary key that is an auto_increment, a string, and a timestamp. This will demonstrate how to save a date and time of when the row was inserted, which can help you determine when data was recorded or updated.
INSTRUCTIONS FOR USE
1) Create the database and table as shown above.
2) Change the address of the server to the IP address of your MySQL server in my case my IP is 192.186.157.77
3) Change the user and password to a valid MySQL user and password in my case it is sa and 156444
4) install mysql library in your ide go to sketch > include library > manage library and in the filter your search type mysql then install it
5) arduino leonardo use etehrnet2 library so you need to install it in your ide go to sketch > include library > manage library and in the filter your search type ethernet2 then install it
6) also you need to modify this file MySQL_Packet.h the original created by Dr.Charles is -
the new is - ethernet.h the new is ethernet2.h otherwise it will give your error message and not compiled
7) Connect a USB cable to your Arduino
8) Select the arduino leonardo eth board and port
9) Compile and upload the sketch to your Arduino
10) connect 4 push button between ground and pins 2, 3, 4, 5 through 10k Ohm resistor
11) After the sketch has run for some time , press some push buttons and open a mysql client and issue the command: SELECT * FROM machine.state; to see the data recorded. Note the field values and how the database handles both the auto_increment and timestamp fields for us. You can clear the data with. "DELETE FROM machine.state".
Note: The MAC on your board in back if not you can put any thing but make sure it is unique in your network . Note your mysql default port address is 3306 but this will conflict with Skype so you can change it to 3307 in both your sketch and your Mysql and make sore this port is open in your server firewall .
Many thanks for Dr.Charles the man how make this possible .
Created by: Samir Mohamad tawfik 28-1-2018
samirtwf@gmail.com
Step 2:
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
