I have added Ethan Dicks original sheep sculpture sketch to this step. I will add an updated sketch file at a later date when I have finalized the design. This will at least get you started with two working scarves.
Sheep - Use a combination of RGB and IR LEDs and a photosensor to imitate
crowd-reactive (emergent) behavior
This code goes with the Fuse Factory Workshop "Make an Emergent Behavior Sculpture
With The Arduino"
http://thefusefactory.org/2009/09/03/make-an-emergent-behavior-sculpture-with-the-arduino/
The scultpture, or "sheep", is an artistic assemblage of a Lilypad Pro kit (Lilypad
base attached to a Lilipad 5V power unit) with a tri-color LED mounted over the 328V
MCU on the Lilypad board. A Large Lilypad Protoboard sits between the PSU and the
Lilypad itself to route power and to hold resistors and the IR components. The illusion
of a quadraped is completed by 1W and 2W LEDs soldered to the PSU "body" and bent as legs.
The code depends on a persistent variable called "mood" - when it is zero or near zero,
the sheep is "happy". Below zero and the sheep is "lonely"; above zero and the sheep
feels crowded or agitated. Loneliness is represented by blue, happiness by green, and
agitation by red. In between expressing "mood" (using PWM to shade the RGB LED), the
main part of the code checks for IR pulses from other sheep and may emit its own pulses
to "call out" to other sheep. By tweaking internal variables, the sheep can be more or
less sensitive to the calls of other sheep. The emergent behavior comes out when
multiple sheep are assembled and placed on a table, calling out to each other. The
flurry of IR pulses can induce the sheep to be happy or perhaps agitated. Few pulses
and the sheep exhibits loneliness.
Sheep.pde - turn an Arduino into an emergent behavior sculpture
Copyright (C) 2009, Ethan Dicks
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see .
Variable initialization - before the code start, put all of the user-adjustable
parameters at the top so they are easy to tweak.
// Definitions of "mood" values
#define MOODMAX 80
#define MOODMIN (-1 * MOODMAX)
#define LONELY (MOODMIN)
#define HAPPY (0)
#define CROWDED (MOODMAX)
#define MSTEPS 5
#define BLEAT_VOLUME 1
// Global definitions of pin assigments (to simplify individual function calls)
int statusPin = 13; // onboard status LED is connected to digital pin 13
int redPin = 11; // R petal on RGB LED module connected to digital pin 11
int greenPin = 9; // G petal on RGB LED module connected to digital pin 9
int bluePin = 10; // B petal on RGB LED module connected to digital pin 10
int sensorPin = 5; // IR phototransistor connected to digital pin 5
int irPin = 6; // IR LED connected to digital pin 6
// Start off expecting to be happy
int mood = HAPPY;
// Keep track of the sense of the input pin
int eye = 0;
// And remember how "loud" we are "bleating" (flashing our IR LED)
int bleat = BLEAT_VOLUME;
setup() - The Arduino environment will call the code in setup() one time
only, right after the board is reset.
Put code in this function to initialize I/O pins and such - things that
only need to be done once during a run.
void setup()
// for debugging
Serial.begin(9600);
Serial.println("Sheep v0.02");
// Mostly, our I/O pins are outputs to LEDs
pinMode(statusPin, OUTPUT); // sets the statusPin to be an output
pinMode(redPin, OUTPUT); // sets the redPin to be an output
pinMode(greenPin, OUTPUT); // sets the greenPin to be an output
pinMode(bluePin, OUTPUT); // sets the bluePin to be an output
pinMode(irPin, OUTPUT); // sets the irPin to be an output
// One exception is the IR phototransistor
pinMode(sensorPin, INPUT); // sets the sensorPin to be an input
Serial.print("Setting IR 'bleat' to ");
Serial.println(bleat);
analogWrite(irPin, bleat);
loop() - the Arduino environment will call the code in this loop forever.
Put interesting things in here that are meant to run endlessly after setup()
is called once.
The only way out of this loop is to reset the board.
void loop() // run over and over again
// Set our RGB LED to reflect our "mood", which will hopefully change from time to time
set_mood(mood);
// Slow down how fast we react to other 'sheep'
delay(100); // delay for .1 second
// sensorPin has a 10K pullup resistor, so *no* light reports a 1. We need to
// invert the logical sense of the pin if we want to think of the light logically
// as 1-is-on/0-is-off
eye = 1 - digitalRead(sensorPin); // set eye to 1 if we "see" any IR light
// Report our present status everytime through the loop
Serial.print("Mood is ");
Serial.print(mood);
Serial.print(". Sensor is ");
Serial.println(eye);
// If we see pulses from another 'sheep', increment the mood, but not past MOODMAX
if (eye) {
// since humans cannot "see" infrared light, use the status LED as a visible indicator
digitalWrite(statusPin, HIGH); // echo IR input detection on the status LED
mood += MSTEPS * 2;
if (mood >MOODMAX) {
mood = MOODMAX;
// If we don't see any IR pulses, decrement the mood, but not below MOODMIN
else {
digitalWrite(statusPin, LOW); // echo IR input detection on the status LED
mood -= 1;
if (mood < MOODMIN) {
mood = MOODMIN;
set_mood - convert "mood" to a color scheme
Mood varies from some negative number to that same value as a positive number
(so far, -80/+80 and -100/+100 produce reasonable results).
Proportionally, the continuum of mood to color mapping resembles the following:
Mood
-100 0 +100
Lonely -> Happy -> Crowded
R 0 0 0 30 100
G 0 30 100 70 0
B 100 70 0 0 0
void set_mood (int mood)
// Start out with each color being off - adjust upwards based on "mood"
unsigned char redness = 0;
unsigned char greenness = 0;
unsigned char blueness = 0;
#ifdef DEBUG
Serial.println(mood);
#endif
// blueness is all about mood being less then happy
if (mood < HAPPY) {
blueness = abs(mood);
greenness = MOODMAX + mood;
// redness is all about mood being more than happy
else if (mood > HAPPY) {
redness = mood;
greenness = MOODMAX - mood;
// greenness is about mood being around happy
else {
greenness = MOODMAX;
// Set the LED to reflect our present mood
color(redness, greenness, blueness);
color(r, g, b) - set the tri-color LED to the requested color value
Uses analogWrite(pin, value) to set PWM value for each individual LED color
The Tri-color LED is a common-anode device, so to make light, we ground the
desired pin. To invert the PWM waveform, we subtract our desired intensity
from 255, so that, for example, if we want red off, logically, we pass around
a value of zero, but set the PWM value to 255 so that the pin is driven high
100% of the time. To get red to the maximum brightness, we pass around a
logical value of 255, but set the PWM value to 0, pulling that pin low 100%
of the time.
void color (unsigned char red, unsigned char green, unsigned char blue) // the color generating function
#ifdef DEBUG
Serial.print("color(");
Serial.print(red,HEX);
Serial.print(blue,HEX);
Serial.print(green,HEX);
Serial.println(")");
#endif
// invert the sense of the PWM value when calling analogWrite() for each color
analogWrite(redPin, 255-red);
analogWrite(bluePin, 255-blue);
analogWrite(greenPin, 255-green);
It has an arduino output pin effectively shunting current across the LED. With a resistor of 56R and a voltage of 5V this will cause a current of 90mA to flow through the arduino pin. The limit for such current, that is the value where it will start causing damage is 40mA, so it is almost twice overloaded. Even if you run the lilypad at 3v3 you are still going to pull 59mA and exceed the damage threshold. To keep it safe the 56R resistor has to be at least 125R but better would be 133R.
You might not notice the damage straight away but exceeding the manufacturer's ratings is a sure way to shorten the like of any electronic component.
