Arduino MP3 Shield
95,410
79
24
Posted
Introduction: Arduino MP3 Shield
Hi , I would today to share my experiment with MP3 Shield from ELECHOUSE , this Shield have Inboard Keys which is can control the Audio file very easy , Support FAT16 And FAT32 , And can read MP3 , WAV Format from SD Card ,  U disk , and from Build in SPI Flash memory , that Give you an ability to save your Audio file on the Board and play it later, so no need to External Storage device .
as I mentioned before , this shield Has Inboard Keys to control the Audio file , and You can Control the Audio File by Programming from Arduino , You can program your Audio when it's begin , Switch between file and Control the Volume Up and Down very easy .
I want to Show you How we can Play Audio from SD Card and U Disk .
The component that we need is :
1)  Arduino Board .
2) Arduino USB-SD MP3 Shield From ELECHOUSE You can buy it from  here  .
3) SD Card With adapter.Or  USB Flash .
4) Speakers Or Headset .
Step 1: Arduino MP3 Shield
The Arduino MP3 Shield Have many Advantages such like   Control by Serial UART interface or keys onboard , Have Build in Audio Amplifier 3W , and has On board 64MBit SPI-FLASH, which you can Save Your Audio file , and play it later .
This Shield can controlled from Arduino By Hardware Serial "Rx  D0 , Tx  D1 " and  By Software Serial " RX  D7  , Tx  D8" So at first You can  Use Hardware serial , easy to use but you must remove the shield when you want to Upload new sketch .
You can change The Serial interface pin by solder tools , Just remove the solder from Upper 2 pads and solder a small bridge between the 2 pads below to active Software serial Pin . look to the image attached to see these 3 pads .
You can also Bridge amplifier control bridge so you can turn on  or Off by solder Amplifier Control pin , so This pin attached to arduino D9 Pin , I didn't use it in this experiment
You can also Solder Pin header on This shield "Look at the Picture" So You can connect Speakers to this shield
Step 2: Prepare Your Audio File
You can play 2 audio file  format , MP3 And WAV , Before you can play your Audio file on this shield you must :
1) Copy your Audio File to SD Card or U- disk storage Device .
2) Add prefix 0000~9999 to the file names like 0000-My music.mp3 So the shield deal with the Files number , Not with Names .
3)  insert Storage device on the shield  , power it on .
So let's see how we can control the audio file .
Step 3: Play the Audio File
What ever if you are modify This shield to control it via Software serial or leave it  as Hardware serial  , Just you need is upload the sketch below to your arduino  , in this step You can control the Audio file , Play , pause , Volume up and down , and Put the shield in sleep mode ,  through The button on Board .
This code for play sond from SD Card , you can  change it to play U Disk , read the code  below .
Upload this code if you are Using Software serial  :
//Written by : Mohannad Rawashdeh
// this code For MP3 Shield Elechosue
// Software serial interface
// For product : http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=168_170&products_id=2193
//https://www.instructables.com/member/Mohannad+Rawashdeh/
#include <SoftwareSerial.h>
SoftwareSerial Geno(7,8); // Rx , Tx
unsigned char cmd_buf[10];
unsigned char i;
void ArduinoMP3Shield_SendCMD(unsigned char *cmd_buf, unsigned len)
    unsigned i;
    for(i=0; i<len; i++){
        Geno.write(cmd_buf[i]);
void setup(void)
    /** wait until arduino mp3 shield get ready */
    delay(1000);
    Geno.begin(9600);
    /** set volume */
    cmd_buf[0] = 0x7E;          // START
    cmd_buf[1] = 0x03;          // Length
    cmd_buf[2] = 0xA7;          // Command
    cmd_buf[3] = 0x0F;          // new volume
    cmd_buf[4] = 0x7E;          // END
    ArduinoMP3Shield_SendCMD(cmd_buf, 5);
    /** set play mode repeat all */
    cmd_buf[2] = 0xA9;          // Command SET MODE
    cmd_buf[3] = 0x02;          // set mode
    /** select SD card first music and play */
    cmd_buf[1] = 0x04;          // Length
    cmd_buf[2] = 0xA0;          //  For U Disk change this line to 0xA2
    cmd_buf[3] = 0x00;          // file number high byte
    cmd_buf[4] = 0x01;          // file number low byte
    cmd_buf[5] = 0x7E;          // END
    ArduinoMP3Shield_SendCMD(cmd_buf, 6);
void loop(void)
 Upload this code if you are Using Hardware serial  :
unsigned char i;
    unsigned i;
        Serial.write(cmd_buf[i]);
void setup(void)
    delay(1000);
    Serial.begin(9600);
    /** set volume */
    cmd_buf[2] = 0xA0;          // Command For U Disk change this line to 0xA2
void loop(void)
Step 4: Control the Audio Using Aduino
You can control the audio Play , pause , and Volume up and down , Depend on commands you program it on arduino , You Just send Serial Command , It's too easy to send command , this Sketch below show  this method .
No need to library to program it , But if you want there is a Library for this Shield you can Download it from Here
// Mohannad Rawashdeh
// MP3 1.2V Shield test .
unsigned char Data[10];
unsigned char i;
void setup() {
  // put your setup code here, to run once:
  Geno.begin(9600);
  SetVolume(20); // set volume from 0-31
  delay(1000);
  FileSource('SD_card',0x05);
  SetPlayMode('Single_play');
  delay(5000);
  play_pause();// Pause
  delay(3000);
  FileSource('SD_card',0x01);
  play_pause(); // play
  delay(5000);
  Next();
  delay(5000);
  Next();
  for(int v=15;v>0;v--){
  SetVolume(v); // set volume from 0-31
  delay(1000);
  for(int j=0;j<15;j++){
  SetVolume(j); // set volume from 0-31
  delay(500);
  delay(1000);
  FileSource('SD_card',0x04);
  delay(5000);
// FileSource('SD_card',0x03);
  //Stop();
void loop() {
  // put your main code here, to run repeatedly:
// Select File sorce "SD Card, SPI Flash , U Disk "
void FileSource( char type, byte track ){
   Data[0] = 0x7E;
   Data[5] = 0x7E;
  switch (type){
   case 'SD_card':
          // START
    Data[1] = 0x04;          // Length
    Data[2] = 0xA0;          // Command
    Data[3] = 0x00;          // file number high byte
    Data[4] = track;          // file number low byte
    break;
    case 'SPI_Flash':
    Data[2] = 0xA1;          // Command spi flash 0XA1
    Data[4] = track;
   break;
    case 'U_Disk':
    Data[2] = 0xA2;          // Command
    break;
  Command(Data,5);
void SetVolume( int vol){
   Data[0] = 0x7E;          // START
   Data[1] = 0x03;          // Length Not 0x02
   Data[2] = 0xA7;          // Command
   Data[3] = vol;          // new volume
   Data[4] = 0x7E;          // END
   Command(Data,5);
void SetPlayMode(char type){
   Data[4] = 0x7E;          // START
   switch (type){
   case 'Single_play':
   Data[1] = 0x02;          // Length
   Data[2] = 0xA9;          // Command
   Data[3] = 0x00;          //Mode parameter
   break;
   case 'Repeat_single':
   Data[3] = 0x01;          //Mode parameter
   break;
   case 'Repeat_all':
   Data[3] = 0x02;          //Mode parameter
   break;
   case 'Play_Random':
   Data[3] = 0x03;          //Mode parameter
   break;
Command(Data,5);
void play_pause(){
  Data[2] = 0xA3;          // Command
  Data[3] = 0x7E;          //Mode parameter
  Command(Data,4);
  void Stop(){
  Data[2] = 0xA4;          // Command
  Command(Data,4);
  void Next(){
  Data[2] = 0xA5;          // Command
  Command(Data,4);
  void Previous(){
  Data[2] = 0xA6;          // Command
  Command(Data,4);
void Command(unsigned char *Data, int length){
    for(int i=0; i<length; i++){
    Geno.write(Data[i]);
The video Below show to you how it worked  .
Step 5: Final , Document , Helpful Links
This shield Consume about 120mA with 2 speakers 3.2W - 5 Ohm, So it's safe to feed from arduino  and 70mA with no headphone or speakers connected
For more information about this shield You can return to the Manual of this shield , From Here You can Find all commands for this shield , And how you can save your audio file on Board SPI Flash memory
I will prepare some projects about this shield and share it with you .
Thank you
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
24 Comments
Thanks so much for all the info!
I am trying to make a super over engineered alarm clock.
Following your instructions I can get everything working just fine.
But I would like to make a certain .mp3 play at specific times...
Is there a command I can use to make a specific .mp3 to start playing in a if statement???
Cheers
hello so can I have the ardunio board call up a spesfic file from the sd and play it as part of my fuctions as in set it up so I have 3 tracks 3 buttons each button plays a spesfic track on the sd ?
hi man! good tutorial.
Can this shield play several audio files simultaneously?
hi, excellent tutorial. i have one doubt, have any possible to transform this shield in a hot swappable device? i have one, but when i unplug pen drive, the same stop playing, and when i reconnct, the shield doesnt start playing again, and then i have to reboot. have any thing that can i make to change this? thanks
Hello and thank you for your project, it is
clearer than the official manual! I want to put in a box the arduino , so is it possible to
add switches, through the other Arduino pins (through the shield), to control
with a code, play pause next volume functions? (in software serial mode).
Thank you for your answer.
Best.
Hi! I am new to arduino, I have a pretty good background in electronic in general, I've programmed automat in ladder and such, and decided to give a try to arduino. I was wondering if it is possible to connect this screen on top of the mp3 shiel, on top of the arduino: https://www.adafruit.com/products/1651
So this way I could use a touch interface to tell the arduino board to control the volume and such from the mp3 shield. Could anyone confirm me that this is possible please?
Great tutorial
Is it possible to run through folders?
