Arduino - Magnetic FIELD Detector Using the KY-003 or KY-035
Published
Introduction: Arduino - Magnetic FIELD Detector Using the KY-003 or KY-035
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I ma...
Hello world! Here i am again. Today i made 2 Different Schematics and 2 codes.
Don't be confused they look a lot like each other, The only difference is.. 1 sensor, the KY-003 uses a
digital Input, and the KY-035 a Analog input. Therefore there are 2 schematics because they use different codes.
So you can choose which one you want to use, the KY-003 Or the KY-035.
Follow the next step for the schematics code and parts list.
Step 1: Schematics Codes & Parts List.
Parts list.
  1. Arduino Uno, I used the RobotDyn Uno as i always do.
  2. 3 Color RGB KY-016
  3. Hall magnetic sensor KY-003 or KY-035, Depends on which code and Schematic u use!
  4. Buzzer.
  5. A magnet of any kind. Small/big doesn't matter.
(if a small magnet doesn't work with the KY-035 You need to change values in the code, with the KY-003 code any magnet will work right away.)
Good Luck!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
