Arduino, Monitoring Door-Opening Via Gmail
Introduction: Arduino, Monitoring Door-Opening Via Gmail
In this tutorial, I am going to show you how to detect the door-opening event and send a notification via Gmail using Arduino Uno.
I made this tutorial for beginners! It is really easy!!!
Let's get started!
Detecting Door-Opening Event
Magnetic sensor I used includes two parts: sensor and magnet. When two parts are in proximity, the output pin of the sensor is HIGH, otherwise the output pin is LOW. Taking advantage of this feature, I installed one part of the sensor on the door leaf and the other on the door frame. By checking state of the output pin, we can detect when door is opened and then make an alert or send a notification.
Handling Event
When the door-opening event occurs, a notification is sent via Gmail.
Step 1: Things We Need
1. Arduino UNO or Genuino UNO
2. PHPoC Shield for Arduino at
3. Magnetic sensor SAMSUNG SIM-0001 at
Step 2: Assembly
1. Stack PHPoC Shield on Arduino.
2. Connect LAN cable to the shield for Ethernet.
3. Pin wiring between Arduino and Sensor.
----5v--------red pin.
----A0-------black pin.
Step 3: Install This Set on the Door
1. Attach the sensor part, Arduino set (including PHPoC shield) to the door frame
2. Attach the magnet part on the door leaf.
3. Power Arduino
4. Connect to Internet via LAN cable or USB Wifi Dongle.
Step 4: Download and Install Library on Arduino
Get library for PHPoC Shield here:
Step 5: Arduino Code
#include "SPI.h"
#include "Phpoc.h"
PhpocEmail email;
void setup() {
  Phpoc.begin(PF_LOG_SPI | PF_LOG_NET | PF_LOG_APP);
  pinMode(A0, INPUT);
int previous_status = 1;
void loop() {
  int current_status = digitalRead(A0);
  int returnValue;
  if (previous_status == 1 && current_status == 0) {    // if door is opened...
    email.setOutgoingServer("", 587);
    email.setOutgoingLogin("Google ID", "Google Password");
    email.setFrom("Gmail address ", "Sender Name");
    email.setTo("Receiver email address", "Receiver Name");
    email.setSubject("Door is opened. [#905]");  // Mail Subject
    // Mail Contents
    email.println("Door is opened.");
    if (email.send() > 0)  // Send Email
      Serial.println("Your Mail has been sent successfully");
      Serial.println("Your Mail is not sent");
  }   else if (previous_status == 0 && current_status == 1) { // if door is closed...
        // Write codes in the same way
  previous_status = current_status;
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    That's a neat idea :)
