Introduction: Arduino Mood Lamp
Hello Instructables Users!!! This is a simple, fun, and useful project for arduino beginners. You will be building the lamp and then uploading the code to make the lamp light up to a color of your liking. The color is smooth and lights up the area of your room you put it in.
Step 1: Step 1: Needed Parts
These are the parts needed to build the lamp:
1.) Jumper wires
2.) 120k Ohm resistor
3.) The LED color of your choice
4.) LDR (photo light resistor)
5.) Arduino Uno
6.) Breadboard
Step 2: Step 2: Building the Lamp
The following photo above is a schematic to build your mood lamp
Step 3: Step 3: Coding the Arduino
Copy and Paste the following code to use for your lamp:
void setup(){
pinMode(redLed,OUTPUT); pinMode(greenLed,OUTPUT); pinMode(blueLed,OUTPUT); digitalWrite(redLed,HIGH); digitalWrite(greenLed,LOW); digitalWrite(blueLed,LOW); }
void loop(){ for (int y=0; y<=3; y++) { if (y=1){ for (int x=0;x<=255;x++){ RGB[0]=255-x; RGB[1]=0; RGB[2]=0+x; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } if (y=2){ for (int x=0;x<=255;x++){ RGB[0]=0; RGB[1]=0+x; RGB[2]=255-x; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } if (y=3){ for (int x=0;x<=255;x++){ RGB[0]=0+x; RGB[1]=255-x; RGB[2]=0; analogWrite(redLed,RGB[0]); analogWrite(greenLed,RGB[1]); analogWrite(blueLed,RGB[2]); delay(delaymood); } } } }
Step 4: Step 4: Final Result
The final outcome of the lamp is a smooth color added to your room for light!
