loading
Every male and occasional female (send nu--never mind) has been caught, for so many nefarious things. Puberty often needs a helping hand--wait--I mean to say that there is a solution to secure your dignity from prying ears -- or eyes depending on applied hex code.
Things
  1. Arduino Uno (2)
  2. PIR Motion Sensor Module
  3. Nerf Walkie Talkies (5$US on eBay)
  4. IR LED Transmitter
  5. IR Receiver (Salvaged)
  6. 47 R
  7. 2.2K R
  8. TIP120
  9. 330 R
  10. 5V Relay
  11. 4001 D
  12. (Optional) Adafruit NeoPixel LED Strip and 1Knf C and 47 R
Steps
  1. Obtain your television's mute hex codes by applying the Arduino IDE IRRemote Library
    1. Install the IRRemote Library in IDE via Manage Libraries
    2. SparkFun Tutorial - IR Communication
  2. Dismantle walkie talkies and desolder and remove both speakers and microphones
  3. Solder leads to the tone button and power supply on (1) walkie talkie
  4. Solder leads to the power supply (9V) and to the speakers on (2) walkie talkie
  5. Build TIP120 (and 5V relay -- if POS voltage on button) (see schematic)
  6. Assemble together Uno, PIR, Walkie, TIP120 pieces (see schematic)
    1. Note on this brand of walkie talkie -- the transmit button needed to be depressed while the morse code tone was also depressed in order to transmit the tone -- thus a wire tie to tamp it down (see image)
  7. Assemble IR, Walkie (and optional LED) on the other Uno
  8. Turn on Channel 47
As the motion sensor is activated, the host MCU triggers the high tone pulse (morse code button) to the other walkie talkie which in turn, the alternate MCU analog reads (A0) voltage from the receiving speaker. When elevated beyond a threshold (identified here as 25) the MCU signals the IR to mute the television and optionally display a LED alert.
A note on refinement for alternative applications -- reduce the delay and transmit pulses (on/off) in Morse so as to reproduce data streams for a broader exchange.
Uh hem, adult entertainment industry, uh -- this thing. Eh?!
Sensor Code
// Motion Mute
// Sensor Code
// VijeMiller
int pir = 3;
int beep = 4;
int state = 0;
void setup()
  pinMode(pir, INPUT);
  pinMode(beep, OUTPUT);
void loop()
  state = digitalRead(pir);
  if (state == 1) {
    digitalWrite(beep, HIGH);
    delay(2000);
    digitalWrite(beep, LOW);
  } else {
  delay(100);
Mute Code
// Motion Mute
// Mute Code
// @VijeMiller
// IRLED pin 3
#include <IRremote.h>
IRsend irsend;
// Neopixel
#include <Adafruit_NeoPixel.h>
#define PINSTRIP 9
Adafruit_NeoPixel strip = Adafruit_NeoPixel(3, PINSTRIP, NEO_GRB + NEO_KHZ800);
int rec = 0;
int recpin = A0;
void setup()
  Serial.begin(9600);
  // Load Neopixel
  strip.begin();
  strip.show();
  // Loading Alert
  colorWipe(strip.Color(0, 255, 0), 100);
  colorWipe(strip.Color(0, 0, 0), 70);
void loop()
  // Read Speaker
  rec = analogRead(recpin);
  // 0 to 1023
  if (rec > 25) {
    // Send Mute Signal
    for (int i = 0; i < 3; i++) {
      // Designated by IRRecDemo
      // Mute for Samsung
      irsend.sendSony(0xF0A01BE, 12);
      delay(40);
    // Red Alert
    colorWipe(strip.Color(255, 0, 0), 100);
    colorWipe(strip.Color(0, 0, 0), 100);
    // Reduce Redundancy
    delay(3000);
  } else {
    // Light Blue
    colorWipe(strip.Color(0, 0, 10), 100);
  delay(100);
void colorWipe(uint32_t c, uint8_t wait) {
  for (uint16_t i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
http://tvmiller.com/index.php?entry=entry170321-22...
Shameless plug for HackADay
https://hackaday.com/tag/tvmiller/
https://hackaday.com/tag/vijemiller/
About This Instructable
157views
5favorites
License:
Bio: Privateer
More by TVMiller:Arduino Splash Resistant Toilet Foamer Arduino Motion Mute 1992 Isuzu Trooper Windshield Wiper Single Button Hack
Add instructable to:
