Arduino - Multiple Servo Control With Arduino
23,314
164
12
Published
Introduction: Arduino - Multiple Servo Control With Arduino
About: For more project and tutorial visit my YouTube channel Mert Arduino and Raspberry Pi
In this tutorial, we will learn how to use multi-servo with Arduino. We will control 4 servo motors with Arduino PWM outputs.
You can implement your robotic arm projects with reference to this tutorial. Of course we will use external battery / power when doing this. In the next tutorial, I'll show you how to use multiple servos with potentiometers.
Do not forget to subscribe. Thank you for your support.
Step 1: Hardware Required
- Arduino Board
- Servo Motor x4
- Battery
- Wires and Breadboard
Step 2: Connections
- The external battery VCC / GND connect to the breadboard.
- The Arduino GND connect to the breadboard's GND input
- The servo connections we use in this project are as follows;
Orange Input -Signal Input
Red Input -Power Input (VCC)
Brown Input -Ground Input(GND)
- The Servo1 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo1 Signal connect to the Arduino Digital PWM 3
- The Servo2 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo2 Signal connect to the Arduino Digital PWM 5
- The Servo3 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo3 Signal connect to the Arduino Digital PWM 6
- The Servo4 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo4 Signal connect to the Arduino Digital PWM 9
The potentiometer
Two outer pins are power (VCC) and ground (GND)
Middle pin is signal pin
- Potentiometer's one outer pin connect to the breadboard VCC input
- Potentiometer's other outer pin connect to the breadboard GND input
- Potentiometer's middle pin connect to the Arduino Analog 1 input
Step 3: Code
I did not share the code because it is short and it varies according to the number of servos.
You can write code by watching the tutorial. This is a better way to learn.
I will continue to share long and complex codes.
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    12 Discussions
    Hi, this is awesome!
    Just a question:
    How can I have different degrees and delay for each servo?
    I'm new in this "arcuino's world"... please forgive my stupid question :)
    yes u can......only if u r about to add gyro to ur model
    The way you word it, it implies servos have to be onPWM pins. They don't: any pin, even the analog inputs a0-a5 will drive servos with the servo library.
    I'll bet those are 4.8-6V servos: why are you powering them from a 9V battery?
    Hey Its My Youtube Video Tutorial
    https://youtu.be/a_jgmrk4a-Y
    kool video, I love it!!
    I always wondered how to do this.
    Plz give the codes
    And the tutorial of writing any code
    Sparta53535@gmail.com
    Thats a 9V battery, correct?
    Thank you very nice job
    Thanks a lot!
