Introduction: Arduino - Multiple Servo Control With Joystick
In this tutorial, we will learn how to use multi-servo with Joystick. We will control 2 pcs servo motor with 1 Joystick.
You can implement your robotic arm projects with reference to this tutorial. Of course we will use external battery / power when doing this. In the next tutorial, I'll show you how to control multiple servos control with Android Application via Bluetooth.
Do not forget to subscribe. Thank you for your support.
Visit My Youtube Channel - Mert Arduino Tutorial & Projects
Step 1: Hardware Required
Picture of Hardware Required
- Arduino Board - Servo Motor x2
- Joystick Module
- Battery
- Wires and Breadboard
Step 2: Connections
Picture of Connections
- The external battery VCC / GND connect to the breadboard.
- The Arduino GND connect to the breadboard's GND input
- The servo connections we use in this project are as follows;
* Orange Input - Signal Input
* Red Input - Power Input (VCC)
* Brown Input - Ground Input(GND)
- The Servo1 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo1 Signal connect to the Arduino Digital PWM 3
- The Servo2 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo2 Signal connect to the Arduino Digital PWM 5
- The joystick connections we use in this project are as follows;
* The Joystick GND connect to the Arduino GND
* The Joystick VCC connect to the Arduino VCC
* The Joystick 'X' (in some modules 'H') connect to the Arduino Analog 0
* The Joystick 'Y' (in some modules 'V') connect to the Arduino Analog 1
* The Joystick 'SW' (switch or button) not connected.
About the Joystick Module:
2 x 5K Potentiometers for reading the X and Y position
1 x Normally Open Momentary Switch
Simple 5 pin +5Vcc - GND - VRx - VRy - SW
Step 3: Code
Picture of Code
I did not share the code because it is short and it varies according to the number of servo.
You can write code by watching the tutorial. This is a better way to learn.
I will continue to share long and complex codes.
Winnieee (author)2017-02-20
9V burn my 4303R servo motor. Any idea?
arduino650 (author)Winnieee2017-11-27
you could try to add a resistor or you could directly connect it to arduino it works no damage
Leathaldose (author)2017-11-05
It's easier to read code then to try to follow some one on a video.
ahmet_024102 (author)2016-12-20
teşekkürler mert
About This Instructable
10,179views
181favorites
License:
Bio: For more project and tutorial visit my YouTube channel Mert Arduino and Raspberry Pi
More by MertArduino:XY Plotter Drawing Robot | Arduino | PolargraphArduino - Balance - Balancing Robot | How to Make?Arduino - MPU6050 GY521 - 6 Axis Accelerometer + Gyro (3D Simulation With Processing)
Add instructable to:
