Arduino Nano - HTS221 Relative Humidity and Temperature Sensor Tutorial
704
Posted in TechnologyElectronics
Introduction: Arduino Nano - HTS221 Relative Humidity and Temperature Sensor Tutorial
About: We are a group of makers. We work in IoT, IOS app, android app, embedded design, sensor design, raspberry pi, arduino, beaglebone, particle electron, particle photon, Bluetooth.
HTS221 is an ultra compact capacitive digital sensor for relative humidity and temperature. It includes a sensing element and a mixed signal application specific integrated circuit(ASIC) to provide the measurement information through digital serial interfaces. Integrated with so many features this is one of the most appropriate sensors for critical humidity and temperature measurements. Here is the demonstration with arduino nano.
Step 1: What You Need..!!
1. Arduino Nano
2. HTS221
LINK : https://www.controleverything.com/content/Temperature?sku=HTS221_I2CS
3. I²C Cable
LINK : https://www.controleverything.com/content/I2C-Cabl...
4. I²C Shield for Arduino Nano
LINK : https://www.controleverything.com/content/I2C-Master?sku=ANI2C
Step 2: Connections:
Take an I2C shield for Arduino Nano and gently push it over the pins of Nano.
Then connect the one end of I2C cable to HTS221 sensor and the other end to the I2C shield.
Connections are shown in the picture above.
Step 3: Code:
The arduino code for HTS221 can be downloaded from our github repository- ControlEverythingCommunity
Here is the link for the same :
https://github.com/ControlEverythingCommunity/HTS2...
The datasheet of HTS221 can be found here:
https://s3.amazonaws.com/controleverything.media/c...
We include library Wire.h to facilitate the I2c communication of the sensor with the Arduino board.
You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// HTS221
// This code is designed to work with the HTS221_I2CS I2C Mini Module available from ControlEverything.com.
// https://www.controleverything.com/content/Humidit...
#include<Wire.h>
// HTS221 I2C address is 0x5F
#define Addr 0x5F
void setup()
// Initialise I2C communication as MASTER
Wire.begin();
// Initialise serial communication, set baud rate = 9600
Serial.begin(9600);
// Start I2C Transmission
Wire.beginTransmission(Addr);
// Select average configuration register
Wire.write(0x10);
// Temperature average samples = 256, Humidity average samples = 512
Wire.write(0x1B);
// Stop I2C Transmission
Wire.endTransmission();
// Select control register1
Wire.write(0x20);
// Power ON, Continuous update, Data output rate = 1 Hz
Wire.write(0x85);
delay(300);
void loop()
unsigned int data[2];
unsigned int val[4];
unsigned int H0, H1, H2, H3, T0, T1, T2, T3, raw;
// Humidity calliberation values
for(int i = 0; i < 2; i++)
// Send data register
Wire.write((48 + i));
// Request 1 byte of data
Wire.requestFrom(Addr, 1);
// Read 1 byte of data
if(Wire.available() == 1)
data[i] = Wire.read();
// Convert Humidity data
H0 = data[0] / 2;
H1 = data[1] / 2;
Wire.write((54 + i));
Wire.requestFrom(Addr,1);
H2 = (data[1] * 256.0) + data[0];
Wire.write((58 + i));
H3 = (data[1] * 256.0) + data[0];
// Temperature calliberation values
Wire.write(0x32);
T0 = Wire.read();
Wire.write(0x33);
T1 = Wire.read();
Wire.write(0x35);
raw = Wire.read();
raw = raw & 0x0F;
// Convert the temperature calliberation values to 10-bits
T0 = ((raw & 0x03) * 256) + T0;
T1 = ((raw & 0x0C) * 64) + T1;
Wire.write((60 + i));
// Convert the data
T2 = (data[1] * 256.0) + data[0];
Wire.write((62 + i));
// Convert the data
T3 = (data[1] * 256.0) + data[0];
Wire.write(0x28 | 0x80);
// Request 4 bytes of data
Wire.requestFrom(Addr,4);
// Read 4 bytes of data
// humidity msb, humidity lsb, temp msb, temp lsb
if(Wire.available() == 4)
val[0] = Wire.read();
val[1] = Wire.read();
val[2] = Wire.read();
val[3] = Wire.read();
// Convert the data
float humidity = (val[1] * 256.0) + val[0];
humidity = ((1.0 * H1) - (1.0 * H0)) * (1.0 * humidity - 1.0 * H2) / (1.0 * H3 - 1.0 * H2) + (1.0 * H0);
int temp = (val[3] * 256) + val[2];
float cTemp = (((T1 - T0) / 8.0) * (temp - T2)) / (T3 - T2) + (T0 / 8.0);
float fTemp = (cTemp * 1.8 ) + 32;
// Output data to serial monitor
Serial.print("Relative humidity : ");
Serial.print(humidity);
Serial.println(" % RH");
Serial.print("Temperature in Celsius : ");
Serial.print(cTemp); Serial.println(" C");
Serial.print("Temperature in Fahrenheit : ");
Serial.print(fTemp);
Serial.println(" F");
delay(500);
Step 4: Applications:
HTS221 can be employed in various consumer products like air humidifiers and refrigerators etc. This sensor also find its application in a wider arena including Smart home automation, Industrial automation, respiratory equipments, asset and goods tracking.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
