Arduino Nano: Infrared Obstacle Avoidance Sensor With Visuino
34,973
67
6
Published
Introduction: Arduino Nano: Infrared Obstacle Avoidance Sensor With Visuino
Infrared Obstacle Avoidance sensors are cheap, small sensors often used in robots, and Arduino project to detect objects near the sensor.
The Infrared sensors work by sending an infrared light with some frequency, and then detecting if some of the light has reflected back to the sensor. The most common ones have a digital output indicating if object has been detected. Many of them have the option to be enabled or disabled.
In this Instructable, I will show you how easy it is to connect and use such sensor with Arduino.
Some of the sensors have a brief false detection when they are enabled. In the Instructable, I will also show you how you can suppress this false detection with Visuino.
Step 1: Components
  1. One Arduino compatible board (I use Arduino Nano, because I have one, but any other will be just fine)
  2. One Infrared Obstacle Avoidance Sensor module I got from this cheap 37 sensors set
  3. 4 Female-Female jumper wires
Step 2: Understand the Infrared Obstacle Avoidance Sensor
The Obstacle Avoidance Sensors usually come in two types - with 3 and 4 pins. The 3 pin version does not have the ability to be enabled/disabled. The 4 pin version has optional Enable pin. Here I am describing the 4 pin version that I have. The information should also be relevant to other versions of the sensor.
The Infrared Obstacle Avoidance Sensor has Power, Ground, Signal, and Enable pins.
There are also 2 potentiometers, and one jumper on the board (See the Picture).
The top potentiometer on the picture is used to adjust how sensitive the sensor is. You can use it to adjust the distance from the object at which the sensor detects it.
The bottom potentiometer on the picture usually should not be changed. It controls the frequency of the infrared signal, and is preset with a good setting. You may need to use it if there is infrared interference with other infrared sources, but otherwise, avoid changing it.
If the Enable pin of the board is not connected, the jumper should be placed on the board as seen on the picture. The jumper permanently enables the board, and if the jumper is placed the Enable pin can't be used to enable/disable the board.
If you want to use the Enable pin, you have to remove the jumper.
Step 3: Connect the Sensor to Arduino
  1. Make sure the green Enable Jumper is placed on the Infrared Obstacle Avoidance sensor(Picture 1)
  2. Connect Ground(Black wire), Power(Red wire), and Signal(Yellow wire) to the Infrared Obstacle Avoidance Sensor Module(Picture 1)
  3. Connect the other end of the Ground wire(Black wire) to the Ground pin of the Arduino board(Picture 2)
  4. Connect the other end of the Power wire(Red wire) to the 5V power pin of the Arduino board(Picture 2)
  5. Connect the other end of the Signal wire(Yellow wire) to the Digital pin 2 of the Arduino board(Picture 3)
  6. Picture 4 shows where are the Ground, 5V Power, and Digital 2 pins of the Arduino Nano
Step 4: Start Visuino, and Select the Arduino Board Type
To start programming the Arduino, you will need to have the Arduino IDE installed from here: http://www.arduino.cc/ .
Make sure that you install 1.6.7 or higher, otherwise this Tutorial will not work!
The Visuino: https://www.visuino.com also needs to be installed.
  1. Start Visuino as shown in the first picture
  2. Click on the "Tools" button on the Arduino component (Picture 1) in Visuino
  3. When the dialog appears, select Arduino Nano as shown in Picture 2
Step 5: In Visuino: Connect the Digital 2 to Digital 13 Pin
Connect the "Out" pin of the Digital[ 2 ] channel of the Arduino component to the "Digital" input pin of the Digital[ 13 ] channel of the Arduino component as shown on the picture
Step 6: Generate, Compile, and Upload the Arduino Code
  1. In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
  2. In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
Step 7: And Play...
On Picture 1 you can see the completed and running project. The LED on Pin 13 is On.
If you put object at front of the sensor the LED on Pin 13 will turn Off (Picture 2)
On Picture 3 you can see the complete Visuino diagram.
Step 8: Connect the Enable Line of the Sensor to Arduino
  1. Remove the Enable Jumper from the Obstacle Avoidance Sensor Module(Picture 1)
  2. Connect Enable(Green wire) to the Infrared Obstacle Avoidance Sensor Module(Picture 1)
  3. Connect the other end of the Enable wire(Green wire) to the Digital pin 3 of the Arduino board(Picture 2)
  4. Picture 3 shows with Red Arrow where is the Digital pin 3 of the Arduino Nano
Step 9: Simple Option: in Visuino: Add and Connect Pulse Generator to Enable the Sensor
To test the Enable functionality of the sensor we can use a Pulse generator and set it to enable and disable the sensor periodically.
  1. Type "puls" in the Filter box of the Component Toolbox then select the "Pulse Generator" component (Picture 1), and drop it in the design area
  2. In the Object Inspector, set the value of the "Frequency" property of the PulseGenerator1 component to 0.2 (Picture 2)
  3. Connect the "Out" pin of the PulseGenerator1 component to the "Digital" input pin of the Digital[ 3 ] channel of the Arduino component(Picture 3)
Press F9 to Generate the code, and open the Arduino IDE, then compile and Upload the Sketch as you did in Step 6.
The project will work, but as you can also see in the second part of the Video, the sensor (At least the type, that I have) has a brief false detection when it gets enabled. This may be fine in some cases, but usually is not desirable, so move to the next step to see how you can avoid the problem.
Step 10: Avoid Flase Detection: in Visuino: Add and Connect Infrared(IR) Obstacle Avoidance Sensor Component
  1. Start with a new project, and select Arduino Nano as board type as you did in Step 4
  2. Type "infra" in the Filter box of the Component Toolbox then select the "Infrared(IR) Obstacle Avoidance Sensor" component (Picture 1), and drop it in the design area
  3. Connect the "Out" pin of the Digital[ 2 ] channel of the Arduino component to the "In" pin of the ObstacleAvoidance1 component (Picture 2)
  4. Connect the "Out" pin of the ObstacleAvoidance1 component to the "Digital" input pin of the Digital[ 13 ] channel of the Arduino component(Picture 3)
Step 11: In Visuino: Add and Connect Pulse Generator to Enable the Sensor
  1. Type "pul" in the Filter box of the Component Toolbox then select the "Pulse Generator" component (Picture 1), and drop it in the design area
  3. Connect the "Out" pin of the PulseGenerator1 component to the "Enable" input pin of the ObstacleAvoidance1 component(Picture 3)
  4. Connect the "Enable" output pin of the ObstacleAvoidance1 component to the "Digital" input pin of the Digital[ 3 ] channel of the Arduino component(Picture 4)
  5. You can optionally specify a different delay for ignoring false detection when enabling the Sensor, by setting a different value for the EnableDelay property of the ObstacleAvoidance1 component in the Object Inspector (Picture 5)
Step 12: And Play...
On Picture 1 you can see the completed and powered up project, and the sensor with the disconnected Enable Jumper.
In the last part of the video you can see that when the sensor is enabled it has a brief false detection, but that detection is not shown in the LED on Pin 13. The "Infrared(IR) Obstacle Avoidance Sensor" component in Visuino suppresses the false detection when enabling the sensor.
Congratulations! You have mastered using Infrared Obstacle Avoidance Sensor module with Arduino, and Visuino.
On Picture 2 you can see the complete Visuino diagram.
Also attached are the Visuinoprojects, that I created for this Instructable. You can download and open them in Visuino: https://www.visuino.com
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    can you please drop the program in the comment !!? Thanks in advance.
    Which of the projects? I show how to build 3 different projects in this tutorial. The project sources are in the zip. You can open them with latest version of Visuino and generate the code. I keep updating the Visuino and its libraries to optimize them, and if I post generated code, it will become obsolete over time. It is best to generate the code with the latest version for its libraries.
    I originally had a detection distance of about 3 cm, but increased this to 10+ cm by turning the top potentiometer (as seen in the picture under step 2) 45° counter-clockwise. I also physically adjusted the IR transmitter and receiving pieces because they were bent out of shape. Personally, I found tilting the IR receiver slightly downwards helped in detection, but (carefully!) move it and see what your sensor does.
    Thanks to BoianM for including which potentiometer does what!
    Congratulations! You are Welcome! Enjoy :-)
    If you want to understand this IR Obstacle Avoidance Sensor device a little better, you may find more information here: http://irsensor.wizecode.com/
    Thank you! :-)
