Arduino Nano - TCN75A Temperature Sensor Tutorial
Published
Introduction: Arduino Nano - TCN75A Temperature Sensor Tutorial
About: We are a group of makers. We work in IoT, IOS app, android app, embedded design, sensor design, raspberry pi, arduino, beaglebone, particle electron, particle photon, Bluetooth.
TCN75A is a two-wire serial temperature sensor incorporated with temperature-to-digital converter. It is incorporated with user programmable registers that provide flexibility for temperature-sensing applications. The register settings allow users to configure power saving mode, shutdown mode, one shot mode etc.The sensor has an i2c compatible serial interface which can facilitate connection of upto eight devices in a single serial bus. Here is its demonstration with arduino nano.
Step 1: What You Need..!!
Step 2: Connection:
Take an I2C shield for Arduino Nano and gently push it over the pins of Nano.
Then connect the one end of I2C cable to TCN75A sensor and the other end to the I2C shield.
Connections are shown in the picture above.
Step 3: Code:
The arduino code for TCN75A can be downloaded from our github repository-ControlEverythingCommunity
Here is the link for the same :
https://github.com/ControlEverythingCommunity/TCN7...
The datasheet of TCN75A can be found here:
https://s3.amazonaws.com/controleverything.media/c...
We include library Wire.h to facilitate the I2c communication of the sensor with the Arduino board. You can also copy the code from here, it is given as follows:
// Distributed with a free-will license.
// Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
// TCN75A
// This code is designed to work with the TCN75A_I2CS I2C Mini Module available from ControlEverything.com.
// https://www.controleverything.com/content/Tempera...
#include<Wire.h>
// TCN75A I2C address is 0x48(72)
#define Addr 0x48
void setup()
// Initialise I2C communication as Master
Wire.begin();
// Initialise serial communication, set baud rate = 9600
Serial.begin(9600);
// Start I2C transmission
Wire.beginTransmission(Addr);
// Select configuration register
Wire.write(0x01);
// 12-bit ADC resolution
Wire.write(0x60);
// Stop I2C transmission
Wire.endTransmission();
delay(300);
void loop()
unsigned int data[2];
// Select data register
Wire.write(0x00);
// Request 2 bytes of data
Wire.requestFrom(Addr, 2);
// Read 2 bytes of data
// temp msb, temp lsb
if (Wire.available() == 2)
data[0] = Wire.read();
data[1] = Wire.read();
// Convert the data to 12-bits
int temp = (((data[0] * 256) + (data[1] & 0xF0)) / 16);
if(temp > 2047)
temp -= 4096;
float cTemp = temp * 0.0625;
float fTemp = (cTemp * 1.8) + 32;
// Output data to serial monitor
Serial.print("Temperature in Celsius : ");
Serial.print(cTemp); Serial.println(" C");
Serial.print("Temperature in Fahrenheit : ");
Serial.print(fTemp);
Serial.println(" F");
delay(1000);
Step 4: Applications:
TCN75A is a temperature sensor that can be employed in personal computers and servers.It can also be deployed in entertainment systems,office equipments, hars disk drives and other PC peripherals.This sensor also find its application in data communication equipment.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    Nice! Thanks for sharing!
