Arduino PIR Sensor Alarm (SIMPLE VERSION)
Published
Introduction: Arduino PIR Sensor Alarm (SIMPLE VERSION)
Get Resources For Project
  • Arduino Uno REV 3
  • PIR Sensor
  • Piezo Buzzer
  • Jumper Wires
  • Blue LED
Step 1: Build & Program Your Arduino PIR Sensor Alarm
Building & Programming The Arduino PIR Sensor Alarm
This Is A Simple 1-Step Project To Create A PIR Sensor Alarm Using The Arduino Uno. When It Detects Motion The LED Will Flash And The Piezo Buzzer Will Sound To Alert You That Motion Was Detected. So Just Connect The Bliue LED With Large Lead Into PIN 13 And Smaller Lead Into GND. Connect The Piezo Buzzer's Large Lead To PIN 10 And The Shorter Lead To GND. Finally, Connect The PIR Sensor's OUT PIN To PIN 2. Also Connect The PIR Sensor's GND Pin To GND And It's VCC PIN To 5V.
  • Make it Move Contest
  • Microcontroller Contest
  • Casting Contest
    Casting Contest
13 Comments
It works!!
sir i uploaded the code now my pir sensor is trigering the led even if there is no motion.
plz help
its not suddden sound
Hello! It works for me but the beeping sound just starts and never stops so I don't think it is activated by the PIR sensor. I also didn't use a LED so I just cuted off the lines with LED instructions in the sketch, could this be the cause of the circuit never stopping?
About 20FT Is The Range. Sorry For The Late Response!
Hello, could this be modified to be use as a trash can sensor so that when someone drops trash into a hole in a trash can lid, it causes a cheering or clapping sound? Thanks so much.
Yes! I Am Sorry For The Late Response. I Have just Recently Had Time To Start Working On My Projects Again. You Could Simple Add A Speaker Or Piezo Element To The Assembly. You Would Have To Find The Audio File In Which The Speaker Would Play When You Opened The Trash Can Lid. I Will Be Happy To Research This More If You Want.
Hi, I am looking for something similar . The only challenge would be finding something which can create a cheering sound or any other sound. Rest everything would be same. Let me know if you find anything.
