Arduino Photoresistor LED On/off
40,891
25
7
Posted
Introduction: Arduino Photoresistor LED On/off
this is another simple arduino project that turn on light when it's dark and turn off when is light))
Step 1: Materials
You will need:
Arduino
Breadboard
2x 240ohm resistors
1x Clear White l.e.d
1x photoresistor
Some Jumper Cables
Step 2: Circuite
Step 3: The Code
//photoresistor A Style Tech.
int Pr = 0; // will be used for analog 0.
int PrValue = 0; // value of output
int Pr_Input = 19; // value of when light is on
void setup() {
Serial.begin(9600); //start serial Monitor
pinMode(8, OUTPUT); // pin 8 as output
void loop() {
PrValue = analogRead(Pr);
Serial.println(PrValue); //prints photoresistor value
delay(100); // value updated every 0.1 second.
if (PrValue < Pr_Input) // if sensor value is less than 19, light will turn on.
{ digitalWrite(8, HIGH);//LED on } else { digitalWrite(8, LOW);// LED off }
Step 4: Finish!!
if all went well, try to add more leds
and change sensitivity of photoresistor " int Pr_Input = 19; // value of when light is on"
GOOD LUCK! ;)
2 People Made This Project!
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
5 Comments
Can i make the same project (photoresistor-LED-on/off) combined with a speedometer, using the same arduino board and the same breadboard?
Can I use 12v led strips ?
Any one else getting this message, when trying to load the code
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
sketch_feb23a.ino: In function 'void loop()':
sketch_feb23a:37: error: expected '}' at end of input
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
void setup() {
void loop() {
if (PrValue < Pr_Input) {
} else {
digitalWrite(8, LOW); }
USE THIS
void setup() {
void loop() {
} else {
