loading
Step 6: More Arduino?
Originally, I bought an "Arduino" Mega 1280 on Ebay. I didn't realize I was buying a counterfeit board, but the price was terrific and I should have known. I wanted the mega because it had more ports and more memory, so I assumed that meant I could do more with it than the other boards. Unfortunately, I found that I couldn't use a lot of the standard shields that are available. I bought a PoE (Power over Ethernet) shield from Sparkfun that didn't specifically say what boards it worked with, and discovered that it would not work with the Mega boards. The digital pins on other boards are combined with other pins, but on the Mega, the digital pins moved to the end of the board. I tried a workaround, but had no luck so I went ahead and bought an Uno board.
The mounting holes are a bit different on this board than they are on the longer Mega board. I made some more standoffs for the Uno and mounted it to the Plexiglas alongside the Mega.
Made something like this several months back. But rather then using the double sided tape that came on the back of the breadboard i removed that then soldered wires on the back side of the power rails. This way you don't have to always use jumper wires to bridge the gaps and it gives you a cleaner setup. I had to use screws and nuts to bolt the breadboard to the acrylic and pinch it tight together so that the metal clips in the board don't fall out. I used Sugru on the ends of the screws for soft feet. No the whole things sits up high enough for a small battery pack to be mounted under the Arduino to make things more portable.
If you want ill buy that arduino mega from you....
brilliant idea.
About This Instructable
9,305views
57favorites
License:
More by JmsDwh:Upgraded Helping Hands Quick Soaking Wood Chips for Smoking Meat Easily Print an Unusual Shape
Add instructable to:
