Arduino Power Supply
2,421
31
13
Posted
Introduction: Arduino Power Supply
Step 1: Parts
1. 1 9volt battery
2. 1 9volt battery connector
3. 1 connector
Step 2: Soldering
Solder the connector to the 9v clip
Step 3: Finished Product
Enjoy
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    12 Comments
    There is also a "Vin' port which can accept voltages it's on the power terminal block, it also goes through the regulator ;)
    last time I tried that it got warm
    Perhaps use a 9v battery, I can run mine for more than 4hours and I have tested the power regulator with an oscilloscope and an infrared thermometer probe and it looks fine.
    I wouldn't use more than 9volts and 500mA though.
    Does anyone know how to save data from a sensor to a sd card with arduino
    Will it run on 6volts?
    I think the arduino uno can except up to 12 volts but I wouldn't do it unless you new exactly how many volts it excepts
    According to the website it can technically accept up to 20V, however the voltage regulator will run too hot if run over 12V.
    Just use a 6v lantern battery from a flash light
    I have found that a 9 volt battery only last about a day.
    I have started including 'wall warts' in my designs from the start. This allows a more continuous power flow
