3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Powered Binary Clock
Step 5Arduino Sketch
Arduino Sketch
An open-source binary clock for Arduino.
Based on the code from by Rob Faludi (http://www.faludi.com)
Code under (cc) by Daniel Spillere Andrade, www.danielandrade.net
http://creativecommons.org/license/cc-gpl
int second=0, minute=0, hour=0; //start the time on 00:00:00
int munit,hunit,valm=0,valh=0,ledstats,i;
void setup() { //set outputs and inputs
pinMode(1, OUTPUT);pinMode(2, OUTPUT);pinMode(3, OUTPUT);pinMode(4, OUTPUT);pinMode(5, OUTPUT);
pinMode(6, OUTPUT);pinMode(7, OUTPUT);pinMode(8, OUTPUT);pinMode(9, OUTPUT);pinMode(10, OUTPUT);
pinMode(11, OUTPUT);pinMode(12, OUTPUT);pinMode(13, OUTPUT);
pinMode(0, INPUT);
void loop() {
static unsigned long lastTick = 0; // set up a local variable to hold the last time we moved forward one second
// (static variables are initialized once and keep their values between function calls)
// move forward one second every 1000 milliseconds
if (millis() - lastTick >= 1000) {
 lastTick = millis();
 second++;
// move forward one minute every 60 seconds
 if (second >= 60) {
 minute++;
 second = 0; // reset seconds to zero
// move forward one hour every 60 minutes
if (minute >=60) {
 hour++;
 minute = 0; // reset minutes to zero
if (hour >=24) {
 hour=0;
 munit = minute%10; //sets the variable munit and hunit for the unit digits
 hunit = hour%10;
 ledstats = digitalRead(0);  // read input value, for setting leds off, but keeping count
 if (ledstats == LOW) {
 for(i=1;i<=13;i++){
 digitalWrite(i, LOW);}
 } else  {
 //minutes units
 if(munit == 1 || munit == 3 || munit == 5 || munit == 7 || munit == 9) {  digitalWrite(1, HIGH);} else {  digitalWrite(1,LOW);}
 if(munit == 2 || munit == 3 || munit == 6 || munit == 7) {digitalWrite(2, HIGH);} else {digitalWrite(2,LOW);}
 if(munit == 4 || munit == 5 || munit == 6 || munit == 7) {digitalWrite(3, HIGH);} else {digitalWrite(3,LOW);}
 if(munit == 8 || munit == 9) {digitalWrite(4, HIGH);} else {digitalWrite(4,LOW);}
 //minutes
 if((minute >= 10 && minute < 20) || (minute >= 30 && minute < 40) || (minute >= 50 && minute < 60))  {digitalWrite(5, HIGH);} else {digitalWrite(5,LOW);}
 if(minute >= 20 && minute < 40)  {digitalWrite(6, HIGH);} else {digitalWrite(6,LOW);}
 if(minute >= 40 && minute < 60) {digitalWrite(7, HIGH);} else {digitalWrite(7,LOW);}
 //hour units
 if(hunit == 1 || hunit == 3 || hunit == 5 || hunit == 7 || hunit == 9) {digitalWrite(8, HIGH);} else {digitalWrite(8,LOW);}
 if(hunit == 2 || hunit == 3 || hunit == 6 || hunit == 7) {digitalWrite(9, HIGH);} else {digitalWrite(9,LOW);}
 if(hunit == 4 || hunit == 5 || hunit == 6 || hunit == 7) {digitalWrite(10, HIGH);} else {digitalWrite(10,LOW);}
 if(hunit == 8 || hunit == 9) {digitalWrite(11, HIGH);} else {digitalWrite(11,LOW);}
 //hour
 if(hour >= 10 && hour < 20)  {digitalWrite(12, HIGH);} else {digitalWrite(12,LOW);}
 if(hour >= 20 && hour < 24)  {digitalWrite(13, HIGH);} else {digitalWrite(13,LOW);}
 valm = analogRead(0);    // add one minute when pressed
  if(valm<800) {
  minute++;
  second=0;
  delay(250);
 valh = analogRead(5);    // add one hour when pressed
  if(valh<800) {
  hour++;
  second=0;
  delay(250);
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:ArduinoFun
