Arduino Pro Mini Music Box
Introduction: Arduino Pro Mini Music Box
My recreation of a Music Box based on:
Sophie's Music Box Page
Experience level: medium, as you need some soldering skills and using a drill to make some holes.
Time to complete the project: 30 min assuming you have all the materials, components and tools.
Project cost: $10-$15
Step 1: Gather All the Materials
Music Box Materials:
1. Arduino Pro Mini (5V, 16MHz)
2. Speaker (8 Ohms)
3. Battery (9V)
4. Battery snaps contacts
5. Toggle switch (SPST On/Off)
6. Project Box (4.5x2.5x1.5 LxWxH) inch
7. Cable wires (24 gauge)
Step 2: Get Tools and Equipment Ready
Tools and equipment:
1. PC with Arduino software, version 1.6.7
2. The Fur Elise sketch
3. USB to serial adapter CH340 (and OS driver) or equivalent
4. Soldering iron and solder
5. Drill with different diameter drill bits
6. Sharpie pen
7. Ruler
8. Double sided tape
9. Crazy glue
10. Philips screwdriver
Step 3: Arduino Software and Upload Sketch
1. Start Arduino software.
2. Connect the USB to serial adapter to your computer. Make sure you have the OS driver for your adapter and you know the COM port assigned to the adapter.
3. Open the Fur Elise sketch .
4. Connect your Arduino Pro Mini board to the USB adapter and upload the sketch to the Arduino Pro Mini board. Make sure pin orientation of USB adapter and Arduino board match.
Step 4: Construction
5. Perform a dry fit of the components inside the box by arranging all components inside the box.
6. Once you know how all the components are going to fit together; install the toggle switch.
7. Mark the placement of the toggle switch on the box cover.
Step 5: Switch Mount
8. Select a small drill bit and start drilling a hole for the switch. Change the drill bit for a larger one until the hole is the appropriate side for the switch to fit through.
9. Make another small hole for the switch locking ring
10. Then mount the switch on the box cover
Step 6: Soldering Components
11. Get your soldering iron and solder all the components together as such
Step 7: Testing Connections
12. Now it is time to test the wiring. Connect the battery and toggle the switch to the On position. If you installed everything correctly the power LED should light up on the Arduino board and the song should begin to play.
13. Turn off the switch.
Step 8: Placement of Components
14. Use double side tape and place the Arduino board and battery inside the box at the corresponding location. Do not tape the speaker.
15. Add a few small holes to the box cover so that you can hear the speaker sound. Use the ruler and mark a few hole directly above the speaker.
Step 9: Completing the Project
16. Add a few drops of crazy glue to secure the speaker on the box cover.
17. Close the box cover and secure cover with 4 screws
18. End, turn On the toggle switch and enjoy the music!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Fun music box idea. This would be great to build inside a kid's toy set.
