3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino R/C Lawnmower (painted)
Step 3The Wheels
The Wheels
First you need to mount the drive sprockets to the wheels.
The EASY way:
If you are smart and have more money, you can find a set of wheelchair motors that have the wheels mounted to them.
The CHEAP way:
I could not find any in my price range, so I went with just the motors, then bought wheels, then sprockets. Believing it would not be strong enough to mount the wheels directly to the motors, I opted to mount the drive wheels on an axle, then the motors to the frame, and use chain to transmit the power. A picture is worth 1000 words, so look at them carefully.
Mount the sprockets to the wheels:
I had to place the sprocket on the center of the wheel and drill 3 holes through the sprocket and then through the wheel itself. Once the sprocket is lined up and properly centered, I placed the 3 bolts through the sprocket and wheel and tightened them up as much as possible. I then welded the sprocket to the wheel hub to keep it centered.
The wheels from Harbor Freight Tools have built in bearings for a 5/8" shaft, hence the 5/8" threaded-rod we are going to use as an axle.
Repeat this process for both wheels.
There is more detailed info tagged in the pictures.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
86
Author:johndavid400
I have always been one to take things apart to figure out how they work, so most of what I own has been dismantled. If it can't be taken apart or hacked, i'd rather not have it. And I like to do thing...
more »
