3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino R/C Lawnmower (painted)
Step 7Mounting the mower deck
  • last photo ←
Next we need to mount the mower deck to the frame. Remember we made the frame wide enough that the edges of the frame would be centered on the lawnmower wheel shafts.
All we have to do is cut 4 pieces of 1" angle-iron equal lengths so that the mower deck hangs evenly from the frame.
So measure the height of the frame from the top to the ground. Now measure how high the mower sits off the ground from the center of the wheel shafts (when the original wheels are on the lawnmower and all the height adjusters for each wheel are in the middle position).  Now subtract the height the mower sits of the ground from the frame height, and cut 4 pieces of 1" angle iron to that length.
Now drill 1 hole in the end of each piece of angle-iron, about 1/2" from each end. The holes at the bottom will need to be the diameter of the lawnmower wheel shafts and the holes at the top will need to be bolted into the frame (hung at equal distances from the top of the frame).
Once you have all 4 hangers installed, you can install the mower deck and tighten up the bolts. Make sure you have at least 1/2" of clearance or more between the drive tires and the lawnmower wheel shafts.
You are almost ready to go.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
86
Author:johndavid400
I have always been one to take things apart to figure out how they work, so most of what I own has been dismantled. If it can't be taken apart or hacked, i'd rather not have it. And I like to do thing...
more »
