Step 3Build the RFID Reader
To build this, we are going to send 5v/Ground over from the primary bread board to a secondary bread board we are building the Reader on. Also send over 3 wires from 3 of the arduino output pins to control the RGB LED, one for each color. One more wire, Brown in the pictures, will be a serial connection for the ID-20 to talk to the arduino's Rx serial input. This is a very simple circuit to connect. LED's get resistors and a few points on the ID-20 are tied to ground/5v to set the correct status.
To make it easier to breadboard the ID-10/ID-20 Sparkfun sells a Breakout board that allows you to attach longer pin headers that are spaced to fit a bread board. This part and the pinheaders and listed in the parts list.
The schematic should be strait forward and easy to follow.
reader_PCB.pdf(612x792) 8 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comments
Add Comment
Add Comment
