Introduction: Arduino RFID Reader / MFRC522 Turorial
This is an simple tutorial for beginner on how to use a MFRC522 module using Arduino
Remarks* I apologize for my english's grammar because i am a chinese :)
Step 1: Collecting Parts and Programs
In this project, you needed these parts :
1.Aruduino Uno R3 (you can also use the other version of Arduino)
2.MFRC522 module
3.Arduino IDE ( you can download it from here https://www.arduino.cc/en/Main/Software )
4.5V relay (not necessary)
5.TIP31 transistor (not needed if you didn't use the 5V relay)
6.Jumper cables
7.LEDs
Programs :
You will need the RFID library and the programs which you can download from the file that i attached . If you don't know how to add a library , here's the link https://www.arduino.cc/en/Guide/Libraries
Step 2: Connecting the Component
Connect the pins with following :
- MOSI ---> PIN 11
- MISO ---> PIN 12
- SCK ---> PIN 13
- SS/SDA ---> PIN 10
- RST ---> PIN 9
- LED ---> PIN 7 & GND
- Relay / Output power ---> VCC connect to 5V pins and the collector pin of the TIP31
- GND connect to GND pins,
- IN connect to emitter pin of TIP31
- Pin 8 is connected to the base pin of the TIP31
*Ways to connect the led and relay is shown on the image above ( i didn't connect the arduino with the mfrc522 module because i didn't know how to make it , so just follow the text above to connect them)
*Double check before you connect your arduino with your computer , the wrong connection could damage your arduino
Step 3: Setting Up for Your Card
First:
Plug your arduino into your computer and select the correct board and com, then verify and upload your sketch
Second:
Open up serial monitor and set your baud to 9600 baud
Third:
Scan your card , your should saw a bunch of numbers pop out
Last:
Copy only the number and paste it to the column after "int cards[][5] = { (replace the space with ',' as shown in the image above, in my case, my card is 5 117 21 219 190 )
You're Done !
Pls comment if you spot any mistake of my instructables or any question to ask me
