Arduino RGB LED Music Lights
22,891
56
13
Posted
Introduction: Arduino RGB LED Music Lights
In this ultra-simple project, we're gonna connect 3 (three) RGB LEDs with an Arduino, and use Processing in our PC to analyze and control the LEDs.
The video basically shows what our project is all about. The LEDs displays colors than was captured in the camera. My camcoder doesn't take good videos in the dark, and the LEDs are not distinct when there is too much light. Bummer.
Step 1: Connect the Components
You'll need -
  • 3 x RGB LEDs
  • 9 x 220 ohm resistors
  • Arduino
  • Wires
Connect all components as shown in the schematic.
Check the type of your RGB LEDs. I'm using the Common Anode type. Hence, the anodes are all connected to +5v pin of the Arduino. If your LEDs are of the Common Cathode type, you need to connect them all to GND.
Open the Arduino IDE, go to File > Examples > Firmata > StandardFirmata, and upload the example sketch to your Arduino.
Step 2: Time to Party
Open the Processing IDE if you already have Processing installed, else install it. Then go to Sketch > Import Libraries and check if Arduino (Firmata) is on the list. If it's not there, install it from Sketch > Import Libraries... > Add Library...
Download the source code (musicLED.pde) from the bottom of this page and open it using Processing. Processing will copy it into a folder with the same name. Copy a mp3 song into the folder (/path/to/musicLED) where you saved the Processing sketch. Change the song.mp3 string in line 36 to the name of your mp3 file, or rename your mp3 file to song.mp3.
As I said before, I'm using the Common Anode type of RGB LEDs. If you have the Common Cathode type, you have to change int common_cathode = 0 to int common_cathode = 1 on line 26 in the above source code.
Also, you should probably use some basic program to check whether the variables like redPin1, bluePin2, etc. are all correct. Different RGB LEDs may have different pin patterns.
Also you have to change the /dev/ttyUSB0 in line 31 to point to your Arduino's port (something like /dev/name on Linux or com5 on Windows).
Put on your party hats, hit run (the triangular thing on the top of the Processing IDE). Sit back and enjoy...
You can also find this tutorial here .
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
12 Comments
how would I modify the code to make 6 rgb leds work instead of just 3
I was ale to correct my issue. My baud rate was at 9600. I put it to 57600 and it works perfect now. hopes this helps
Hi !
I have done all the steps as brief in tutorial and able to run the music too. But my LED's are only glowing initially and not changing with music. Kindly help me out ?
I am having the same issue. Did you figure it out? please if so let me know i really want to finish this amazing project thank you
how do i change the transition time b/w colors???
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\HieuPhysics\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10607 -build-path "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\HieuPhysics\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10607 -build-path "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\sketch\RGBmusic.pde.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\sketch\RGBmusic.pde.cpp" -o "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\sketch\RGBmusic.pde.cpp" -o "C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\sketch\RGBmusic.pde.cpp.o"
RGBmusic:42: error: stray '#' in program
background(#151515);
RGBmusic:47: error: stray '#' in program
stroke(#FFF700);
RGBmusic:84: error: stray '#' in program
stroke(#FF0000);
RGBmusic:94: error: stray '#' in program
fill(#111111);
RGBmusic:98: error: stray '#' in program
fill(#046700);
RGBmusic:1: error: 'import' does not name a type
import ddf.minim.*;
RGBmusic:2: error: 'import' does not name a type
import ddf.minim.analysis.*;
RGBmusic:3: error: 'import' does not name a type
import processing.serial.*;
RGBmusic:4: error: 'import' does not name a type
import cc.arduino.*;
RGBmusic:6: error: 'Arduino' does not name a type
Arduino arduino;
RGBmusic:8: error: 'Minim' does not name a type
Minim minim;
RGBmusic:9: error: 'AudioPlayer' does not name a type
AudioPlayer song;
RGBmusic:10: error: 'FFT' does not name a type
FFT fft;
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void setup()':
RGBmusic:29: error: 'size' was not declared in this scope
size(800, 600);
RGBmusic:31: error: 'arduino' was not declared in this scope
arduino = new Arduino(this, "/dev/ttyUSB0", 57600);
RGBmusic:31: error: expected type-specifier before 'Arduino'
RGBmusic:31: error: expected ';' before 'Arduino'
RGBmusic:32: error: 'Arduino' was not declared in this scope
for (int i = 0; i <= 13; i++) arduino.pinMode(i, Arduino.OUTPUT);
In file included from C:\Users\HIEUPH~1\AppData\Local\Temp\buildbfe527539d40d23b2e85452625ad86ed.tmp\sketch\RGBmusic.pde.cpp:1:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:44:16: error: expected unqualified-id before numeric constant
#define OUTPUT 0x1
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde:32:62: note: in expansion of macro 'OUTPUT'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:40:14: error: expected unqualified-id before numeric constant
#define HIGH 0x1
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde:33:66: note: in expansion of macro 'HIGH'
for (int i = 0; i <= 13; i++) arduino.digitalWrite(i,arduino.HIGH);
RGBmusic:35: error: 'minim' was not declared in this scope
minim = new Minim(this);
RGBmusic:35: error: expected type-specifier before 'Minim'
RGBmusic:35: error: expected ';' before 'Minim'
RGBmusic:36: error: 'song' was not declared in this scope
song = minim.loadFile("fugly.mp3");
RGBmusic:38: error: 'fft' was not declared in this scope
fft = new FFT(song.bufferSize(), song.sampleRate());
RGBmusic:38: error: expected type-specifier before 'FFT'
RGBmusic:38: error: expected ';' before 'FFT'
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void draw()':
RGBmusic:42: error: 'background' was not declared in this scope
RGBmusic:44: error: 'fft' was not declared in this scope
fft.forward(song.mix);
RGBmusic:44: error: 'song' was not declared in this scope
RGBmusic:46: error: 'strokeWeight' was not declared in this scope
strokeWeight(1.3);
RGBmusic:47: error: 'FFF700' was not declared in this scope
stroke(#FFF700);
RGBmusic:47: error: 'stroke' was not declared in this scope
stroke(#FFF700);
RGBmusic:50: error: 'pushMatrix' was not declared in this scope
pushMatrix();
RGBmusic:51: error: 'translate' was not declared in this scope
translate(250, 0);
RGBmusic:53: error: 'height' was not declared in this scope
line(i, height*4/5, i, height*4/5 - fft.getBand(i)*4);
RGBmusic:53: error: 'line' was not declared in this scope
RGBmusic:54: error: 'text' was not declared in this scope
if(i%100==0) text(fft.getBand(i), i, height*4/5+20);
RGBmusic:82: error: 'popMatrix' was not declared in this scope
popMatrix();
RGBmusic:84: error: 'FF0000' was not declared in this scope
stroke(#FF0000);
RGBmusic:88: error: 'line' was not declared in this scope
line(i, 50 + song.left.get(i)*50, i+1, 50 + song.left.get(i+1)*50);
RGBmusic:93: error: 'noStroke' was not declared in this scope
noStroke();
RGBmusic:94: error: 'fill' was not declared in this scope
fill(#111111);
RGBmusic:95: error: 'height' was not declared in this scope
rect(0, 0, 250, height);
RGBmusic:95: error: 'rect' was not declared in this scope
RGBmusic:97: error: 'textSize' was not declared in this scope
textSize(24);
RGBmusic:99: error: 'text' was not declared in this scope
text("left amplitude", 10, 50);
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void stop()':
RGBmusic:107: error: 'arduino' was not declared in this scope
#define HIGH 0x1
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde:107:66: note: in expansion of macro 'HIGH'
RGBmusic:108: error: 'song' was not declared in this scope
song.close();
RGBmusic:109: error: 'minim' was not declared in this scope
minim.stop();
RGBmusic:110: error: 'super' was not declared in this scope
super.stop();
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void setColor1(int, int, int)':
RGBmusic:119: error: 'arduino' was not declared in this scope
arduino.digitalWrite(redPin1, red);
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void setColor2(int, int, int)':
RGBmusic:130: error: 'arduino' was not declared in this scope
arduino.digitalWrite(redPin2, red);
C:\Users\HieuPhysics\Downloads\RGBmusic\RGBmusic.pde: In function 'void setColor3(int, int, int)':
RGBmusic:141: error: 'arduino' was not declared in this scope
arduino.digitalWrite(redPin3, red);
exit status 1
I got that message and do not know how to fix it. Please help me!!!
Hey, nice project.
But i notice that 'redPin1' and 'redPin3' never get to turn on. Is that on purpose or is somthing wrong with the code?
I also notice that with some songs the LEDs seems to not react, i suspect that it has something to do with the frequency/rythm of the music. This happens, for instance, wit the music Afterglow from Wilkison.
If you could give some more information about what the code does it would be nice, since i don't hnow what some of the instructions are doing.
Btw, thanks for sharing this.
Is there a way to process music being played over speakers. So can i open Pandora and have this analyze the output audio? I know this specific code you need to load one .mp3 at a time, but i was looking for someone who may have modified it to just listen to music internally
Hii i have also used minim's beatWrite library and this code restricts to the use of one mp3 that is mentioned in code itself.We just can't play any random music file and let arduino do the work.This can only be achieved if we extend the sensory capabilities of our board by using a sound sensor so for that we have to write a new code to analyse the input coming from sound sensor and define the range for drum beats or other musical frequencies.There is another approach too .
We can make the code access our entire music folder on our hard disk (PC/Computer) but i am also tinkering how can this be done.
If anyone has any idea how to do it please share.
So I tried to run your code but on line 36, I get a NullPointerException with an error message that says
"==== JavaSound Minim Error ====
==== Error invoking createInput on the file loader object: null"
Do you have any ideas about how to fix this problem? Thanks
