Introduction: Arduino RGB LED Strip Controller
Picture of Arduino RGB LED Strip Controller
In this Instructable I will show you how to make an Arduino RGB LED strip controller with a rotary encoder. Usually, when people want to control their RGB LED strip with an Arduino, three potentiometers are used to mix the red, green and blue colors. This works and could be perfectly fine for your needs, but I wanted to make something more intuitive, something more like a color wheel. So I searched the internet and found something called a rotary encoder. This is a turning knob that registers in which way the shaft is turned. This way you can attach some variable which increases when the encoder is turned one way, and decreases when it is turned the other way. For more on rotary encoders, you can watch this video which explains it more in-depth.
This Instructable covers the construction of the circuit on a breadboard. In the future, I will include the design and production of a custom PCB which fits the Arduino and all the parts, for advanced makers.
Step 1: Parts
Picture of Parts
I bought nearly all the necessary parts at Banggood.com, but they can also be found at eBay, Adafruit, SparkFun etc. For the LED controller you will need the following materials:
Step 2: Circuit
Picture of Circuit
Connect the components and wires as shown in the diagram. Connect the 12V power supply to the positive and ground rail of the breadboard. Make sure you check polarities! Then you can connect the positive wire of the LED strip to the brown wire, and the red, green and blue wires of the LED strip to the corresponding wires on the breadboard.
Arduino
Vin - 12V
GND - gnd
Rotary encoder (see image for pinout)
Pin A - D4
Pin B - D3
Pin C - gnd
MOSFET Red (see image for pinout)
Gate - gnd
Drain - LED strip red wire
Source - D11
MOSFET Green (see image for pinout)
Gate - gnd
Drain - LED strip green wire
Source - D9
MOSFET Blue (see image for pinout)
Gate - gnd
Drain - LED strip blue wire
Source - D6
Step 3: Code
int redPin = 11;
int greenPin = 6;
int bluePin = 9;
int colorVal;
int redVal;
int greenVal;
int blueVal;
int encoder0PinA = 4;
int encoder0PinB = 3;
int encoder0Pos = 0;
int encoder0PinALast = HIGH;
int n = LOW;
void setup()
 pinMode (encoder0PinA,INPUT_PULLUP);
 pinMode (encoder0PinB,INPUT_PULLUP);
void loop()
  // Rotary encoder
  // INPUT: rotary encoder position
  // OUTPUT: encoder0Pos [0-1535]
  n = digitalRead(encoder0PinA);
  if ((encoder0PinALast == LOW) && (n == HIGH))
    if (digitalRead(encoder0PinB) == LOW)
      encoder0Pos = encoder0Pos - 8;
    else
      encoder0Pos = encoder0Pos + 8;
    if (encoder0Pos < 0)
      encoder0Pos = 1535;
    else if (encoder0Pos > 1535)
      encoder0Pos = 0;
  encoder0PinALast = n;
  // Led strip
  // INPUT: encoder0Pos [0-1535]
  // OUTPUT: redVal [0-255], greenVal [0-255], blueVal [0-255]
  // Red to yellow
  if (encoder0Pos <= 255)
    colorVal = encoder0Pos;
    redVal = 255;
    greenVal = colorVal;
    blueVal = 0;
  // Yellow to green
  else if (encoder0Pos <= 511)
    colorVal = encoder0Pos - 256;
    redVal = 255 - colorVal;
    greenVal = 255;
    blueVal = 0;
  // Green to cyan
  else if (encoder0Pos <= 767)
    colorVal = encoder0Pos - 512;
    redVal = 0;
    greenVal = 255;
    blueVal = colorVal;
  // Cyan to blue
  else if (encoder0Pos <= 1023)
    colorVal = encoder0Pos - 768;
    redVal = 0;
    greenVal = 255 - colorVal;
    blueVal = 255;
  // Blue to magenta
  else if (encoder0Pos <= 1279)
    colorVal = encoder0Pos - 1024;
    redVal = colorVal;
    greenVal = 0;
    blueVal = 255;
  // Magenta to red
  else
    colorVal = encoder0Pos - 1280;
    redVal = 255;
    greenVal = 0;
    blueVal = 255 - colorVal;
  // Set LED strip color
  analogWrite(redPin, redVal);
  analogWrite(greenPin, greenVal);
  analogWrite(bluePin, blueVal);}<br>
Step 4: Result
After uploading the code, you should be able to control the RGB LED strip by turning the rotary encoder clockwise or counterclockwise. Enjoy!
tomatoskins (author)2017-05-23
Thanks for sharing your great arduino project!
Tiggelen (author)tomatoskins2017-05-25
Thanks! Glad you like it
About This Instructable
1,705views
17favorites
Bio: Mechanical Engineering Student
More by Tiggelen:Arduino RGB LED Strip Controller
Add instructable to:
