Introduction: Arduino: Random Options Picker
Arduino: Random Options Picker is a tool to generate a random name based on your options, with unlimited options, and different Random Seed every time you push the button. I spent +$36. Time needed just about 2-3 hours. Let's get started.
Step 1: Preparing...
Picture of Preparing...
Here's the things you gonna need:
(1) Arduino Uno
(1) 16x2 LCD
(1) Breadboard
(1) Button
(1) Potentiometer 10kΩ
(1) Resistor 220Ω
(18) Wire or Jumper Wire
(1) Arduino Cable to USB or 9V Battery + DC Adaptor
Step 2: Making...
Picture of Making...
The form is technically looks-like on the graph. Simple. Follow it and done.
Step 3: Uploading...
Once you have finish the "plugging cable" and "stuffs", it's time to upload the code to the Arduino.
Step 4: Finishing...
Picture of Finishing...
Once you have finished, try to use it. When you push the button, it will shows a random name from your options for 5 sec (you can change the time from the code).
*P.S. If necessary, you can make a case or any alternative, so it can look cleaner and tidier.
Step 5: Extras
Picture of Extras
If the LCD don't show any text, but just blocks or weird languages somehow like error, you can:
1. Make sure that all your cables are fine and can be used.
2. Make sure that your cables, LCD, button, and Potentiometer are plugged at the right spot.
3. If it still not working, Reset the Arduino, or Re-Make it.
ehudwill (author)2016-01-23
I like this. I want to build a random number generator.
haydians09 (author)ehudwill2016-01-23
Yeah that could work too. But I suggest you to use the random number generator code, because this one is for options you made.
ehudwill (author)haydians092016-02-02
I would like to make a device that generates all manner of randomness. Mostly for use in an RPG setting.
asharma172 (author)2016-01-23
can u have a cheaper one
haydians09 (author)asharma1722016-01-24
Of course it can. There's a lot cheaper LCD with blue light in Amazon and cheaper wires and stuffs. Or even cheaper by using Serial.println, not by LCD.
Samuel_Alexander (author)2016-01-23
Really simple and can be very useful for some occasions ;)
One question, what is the function of the number below the name?
Well at first I'm trying to put a timer below the name, but since I still haven't find out what's the code, I turned it into a stopwatch.
About This Instructable
705views
7favorites
License:
Bio: Stay thinking 24/7
More by haydians09:Arduino: Random Options PickerCircular Display Picture of PeopleSimple Plastic Fastener
Add instructable to:
