Introduction: Arduino Robotic Arm
I have bought 2 joysticks from ebay and tried to think what can I do. Then I came up with idea to make a small robot arm. What I needed was:
1x Arduino Nano
3x MG996R servos (I used one Futaba, because I had only two MG996R and it was not necessary to have much torque for turning)
1x Micro servo
2x Two axis joysticks
1x 6V voltage regulator
1x Battery
Other items: double sided PCB covered with photoresist, diode, capacitor, switch, socket for Arduino Nano, strip cable with connectors, PCB stands, screws, bike spokes for pushrods, linkage stoppers.
Step 1: Sketching and Modelling
I borrowed the frame from backhoe and made some sketches. Then using AutoCAD I made a 3D model. It was one of the longest step during production. I attach AutoCAD and .stl files if you want to see or take some ideas. Also I drew an outline for control joystick.
Step 2: Production
As you probably saw, the 3D parts are made of rectangle pipes. The reason of this is that I wanted to make the robot of aluminium pipes, but when I started, I realised that it is too big challenge. The bending places breaks, so it has to be hot, but I don't have equipment for that, so I jumped to 3D printing technology.
I brought 3D model to local company and it printed the parts for $25. That wasn't the best quality, but acceptable for this robot.
Step 3: Assembly
The best part of production was assembly. All I needed to do was to insert servos, make hinges of spokes, bend and connect spokes for pushrods.
Step 4: Programming and PCB Production
First I have made testing circuit on breadboard and wrote a program with Arduino software. I attach the code here. Then I drew tested circuit with Eagle software and printed it on transparent paper, which you can buy in almost any office. After that I peeled of the cover film from PCB, put on circuit scheme and using energy saving lamp exposured the board. I have made 2 boards, one for robot and one for control joystick. Following step was to clean left photoresistor in alkali bath and after that etching. After etching I drilled the holes and PCBs were ready to solder.
Step 5: Base and Joystick Assembly, Soldering
I used plywood to make base and joystick. When PCBs were soldered, I attached them to plywood. And here it comes two errors of designing PCB:
- Lower holes of control joystick PCB are partly covered by connector sockets, so it's not possible to screw the board through them;
- Connector socket, which goes to robot is placed incorrectly. I messed up with pins, so I had to solder it upside down.
Last two things was to connect all wires and calibrate the movements.
And that's it, here is finished Robot Arm.
Step 6: Presentation
In this video you can go through again all these steps and check how the Robot Arm works. By the way, control is based on the ISO pattern.
If you like my project, please VOTE. Thank you for your interest!
have you worked upon eezybotarm mk1?
73 Comments
Hello how can i convert my old video game gamepad into wireless controller for my racing robot? I dont know the exact specifications, hence im sending some pictures of its circuit board and connecting pin.. Hope i get reply soon should i use tje joysticks for arduino as per ur project? How can i program my arduino to controll robot's left-right movement with one joystick and reverse-forward with another?
Hi. It is possible, but as it is a specific joystick and as I see it has a chip, it could be not easy to find out how it works. It might need some studies about similar joysticks and testing of the circuit. Probably it will be easier to do a joystick yourself where all connections and information of operation can be found easily and understood clearly :)
where did you go to get 3d printed items?
Hi. I have sent my 3d drawing to a local company and they have printed the parts for me.
what was the name of the company?
Sorry for delayed answer. It is a small company in Lithuania with a website www.3dgamyba.lt
I do not know if it helps you :)
Instead of using MG996R servos will FS5103R servos work in replacement?
Hi! Yes, but it is more complicated. Since these servos are continuous rotation you need to make some changes in code and I advice to put limit switches, otherwise you can break your robot :)
its awesome i made it using a relays
Congratulation! Please share with us!
