loading
loading
Picture of Arduino Solar Tracker
What is does:
It searches for the brightest light source like the sun.
Step 1: How it works
Picture of How it works
How it works:
I'd made a sensor of 4 LDRs with sheets between them
The withe stips are the LDRs
When the stick on top is righted to the sun or the brightest point
the four LDRs get the same amount of light on them.
Example1 when the light is left on top:
right-top, right-down, left-down are in the shadow
and left-top get the most light
Example2 when the light is on top
left and right down are in the shadow and top is in the light
Step 2: Parts List
  • 2 x servo's
  • 4 x lightdepending resistors (ldr)
  • 4 x resistors 10K
  • 1 x Arduino
  • 2 x potentiometers 10k (value doesn't matter)
Step 3: The set-up
Picture of The set-up
Just hot glue it together!!!
Step 4: The circuitry
Picture of The circuitry
1-40 of 224Next »
Spellmal made it!5 months ago
Just finished up my take on this tracker. I used continuous rotation servos, so i had to modify the code a bit. Super fun project, thanks geo Bruce!
AlberA Spellmal3 months ago
Hi could you send me the schematic for the build and the codes... because i think im going to go with the continuous rotation servos too.... ty
Spellmal AlberA3 months ago
My wiring and build was pretty much the same as GeoBruces, except for an LCD I added.
For your individual motors, the servohstop and servovstop values might need adjusting. If it doesnt work as is, try setting both of these values to 90 and go from there.
#include <LiquidCrystal.h> //include LCD Library
#include <Servo.h> // include Servo library
LiquidCrystal lcd (2, 3, 4, 5, 6, 7); //
Servo horizontal;
int servohStop = 95;
int servohLeft = 105; //move horizontal
int servohRight = 85;
Servo vertical; // vertical servo
int servovStop = 95;
int servovUp = 105 ;
int servovDown =87;// move vertical servo
// LDR pin connections
// name = analogpin;
int ldrLeftTop = 1; //LDR top left
int ldrRightTop = 0; //LDR top right
int ldrLeftBottom = 2; //LDR down left
int ldrRightBottom = 3; //ldr down right
int dtime = 25; //delay time in milliseconds
int tolerance = 100; //difference tolerance between ldr readings
int count = 0; //millis(); //start millisecond count
void setup()
lcd.begin(16, 2); //begin 16x2 LCD
Serial.begin(9600);
// servo connections
// name.attach(pin);
horizontal.attach(9);
vertical.attach(10);
void loop()
//int count = millis(); //start millisecond count
int leftTop = analogRead(ldrLeftTop); // top left
int rightTop = analogRead(ldrRightTop); // top right
int leftBottom = analogRead(ldrLeftBottom); // down left
int rightBottom = analogRead(ldrRightBottom); // down right
//print resistance values to serial monitor for debugging
Serial.println(leftTop );
Serial.println(rightTop );
Serial.println(leftBottom );
Serial.println(rightBottom );
Serial.println();
count++;
int avt = (leftTop + rightTop) / 2; // average value top
int avd = (leftBottom + rightBottom) / 2; // average value down
int avl = (leftTop + leftBottom) / 2; // average value left
int avr = (rightTop + rightBottom) / 2; // average value right
int avgTot = (rightTop+rightBottom+leftTop+leftBottom) / 4;
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and right
if (count%10 == 1) //mod the millis count so the lcd screen updates every 10 millis
lcd.clear(); //clear the screen and position cursor at top left
lcd.print("dvert: "); //difference in vertical resistances read from the LDRs
lcd.print(dvert);
lcd.setCursor(0,1); //set lcd cursor to bottom left
lcd.print("dhoriz: "); //difference in horizontal resistance read from the LDRs
lcd.print(dhoriz);
if (-1*tolerance > dvert || dvert > tolerance) // check if the difference is in the tolerance else change vertical angle
if (avt > avd) //if average resistance on top is greater than on bottom
vertical.write(servovUp);
else //avg resistance on bottom is greater than on top
vertical.write(servovDown);
else if (-1*tolerance < dvert || dvert < tolerance) //if difference is smaller than tolerance, stop vertical servo
vertical.write(servovStop);
if (-1*tolerance > dhoriz || dhoriz > tolerance) // check if the difference is in the tolerance else change horizontal angle
if (avl > avr)
horizontal.write(servohLeft);
else
horizontal.write(servohRight);
else if (-1*tolerance < dhoriz || dhoriz < tolerance) //if difference in horizontal
horizontal.write(servohStop);
delay(dtime);
can i know what is the function of the LCD?and can i get the full image of your model solat tracker?
I followed your schematic and used your code but I can't get info to display on LCD.. lcd back light lights up and white squares are there when I turn potentiometer... do the 4 resistors have to be a certain ohm to work correctly...
this is all I get :-(
Thank you for the answers... so i wounder if your servos are modifyed to make a full spinn... if i do that to my servos would the code you sent me work?
Hi could you send me the schematic for the build and the codes... because i think im going to go with the continuous rotation servos toceers
Hello is there any chance you could send me the schematic for the build and the codes... because i think im going to go with the continuous rotation servos too.... thank you
sali58 AlberA3 months ago
hi can you please send me same stuff (he schematic for the build and the codes for display ..)to build a solar tracker
Thank you
TomDunlap1 year ago
Just finished it and got it debugged. Really cool. Now I'm going to try to use it to build a Solar Forge and or a Solar Sand Sinter 3D Printer. Should be a snap. ;-)
geo bruce (author)  TomDunlap1 year ago
cool! :p
can you show us some video's or pictures?
thnx
*videos *thanks
Another development, I used a Makerbot Replicator to print a replacement for the foam core sensor holder. Here is the Sketchup pic of it. The two pieces glue together. The center top hole is for a fifth sensor to shut the system down if clouds block the sun so it doesn't try to point at the brightest cloud.
nice upload your design to http://www.thingiverse.com/
thnx!!
Sure, here is the link to the YouTube clip I made: http://youtu.be/6GTVWdeKvzY
Nice!!!
It's cool to see your instructable finished by someone else :D
it means i've helped someone ^^ or someone liked my project! :D
It's really helpful to get me started toward my other goals.
Next I want to modify the code to operate some 12V drill motors with a MotorShield or the like if I can find one that will handle the 3-4A current.
hbulushios made it!17 days ago
thanx for the great project ..explain it in detail help me alot to finish it with excellent results
Hi, so i'm trying to run this with and LCD display. i followed Spellmal->AlberA 's instructions and i've gotten each part to work individually, but when i throw two servos an lcd and the ldr's on the board at the same time, nothing works. LCD display non-sence, servos vibrate. i've tried extra capacitors but got the same. any advice anyone?
FadhelA23 days ago
Hello geo bruce, am so interested in making this project, I need your help though, I ran to a trouble that I want this project to work on a normal DC motor and run it both ways, is there a way to do that ? or do i just have to stick with the Servo's.
The problem I have is that I have ordered 4 servo motor's to do the project and when it arrived i toke the motors and they were so small and it doesn't serve my design because i have modified the project to be a tracker for my solar system.
I really need your help if possible I will be so glad to hear your reply.
Thx again for sharing your idea.
Alcee24 days ago
why do you use 2 potentiometers??? which is their function?
wic128 days ago
Any idea how to use the same stuff on larger motor (to hold up home antena)?
Other thing is... how to do it so it will not wrap the cables around. Would be nice if it would go bac 'after the tracks' to the start after whole day round .
EVANNOH1 month ago
I'm using 60 degree's motor instead of 90 degree's motor what you used in. so how to change the coding?
Help needed
My tracker is not working.
ldr's always giving a value of 1023 as i checked through serial monitor
and the pot is giving 256 and 52 as the values always.
What should i do.
i have done everything as mentioned in ur circuit diagram but it is still and not responding to any light.
rroji11 month ago
I have done all the process as mentioned above but the head is not tracking the path of light.
Need help
lad_deep made it!1 month ago
just i finished...its work very accurate...love it..tanks
20150406_172517.jpg20150406_172523.jpg20150406_172849.jpg20150408_150307.jpg20150408_150314.jpg20150408_150327.jpg
torrio1 month ago
Hello friend, is just what I was looking for.
you can send me the code and circuit please my email is tonygt@outlook.com
MarceloS32 months ago
Just finished my solar tracker. Thanks geo bruce for your share ,it helped me a lot in my school project, blecaute of your help i could get 19. Thanks very much. In my project i needed to change some things blecause in the place where i was is very Lightning and i adjust the program to the "arm " escape from the shadow thank very much one more time!!!
hey can u please help me in this project ..i have done everything but still it rotates anywer even if no torch light is directed on it
nshaikh1 month ago
Hey! Please help me...I followed all of your instructions but my ldr is not tracking sun..it is juz rotating in any direction ..please reply soon
Irfan-931 month ago
Hi there. This guide have been really useful for my project. But I have several questions that I hope you can answer about this project. How did you power the servos?? using your arduino uno usually wouldn't be enough right?
i want to know what kind of project to i have to create to paste the code can you help me
swordsatu2 months ago
what type arduino will used to make arduino solar tracker??
DPont swordsatu2 months ago
Uno. Thanks for the reply.
colton.barty2 months ago
Did you have any problems with the LDRs giving differnt resistance values for the same amount of light? And if so how did you correct for it
iko.lola2 months ago
Very nice :)
Is the value of resistors that you used is necessarily be 10kohms ?
Thanks
1-40 of 224Next »
