Arduino Solar Tracking Robot
 by Bot1398
Featured
This is a simple solar tracker which automatically orients itself towards the sun or any bright source of light like the sun .If you place solar panels on this robot it can increase their productivity by 90 to 95 %. At first creating a solar tracking robot may sound complicated but it quite quickly becomes clear. As the title suggests it runs on the arduino board .This is a fun to do and low cost project.
This instructable was inspired from geo bruces instructable solar tracking robot
This instructable explains how to create your own solar tracking robot, how to set up the robot and how to test the robot.
This instructable is a entry in the robot challenge in the age category of 13 - 18 (I am 14 years old).
Step 1: Parts & Tools
Parts:
~ 2 x Servo Motors - Local Electronics Store
~ 4 x LDR's - Local Electronics Store
~ 4 x 10k Resistors - Local Electronics Store
~ Arduino Uno - Sparkfun.com
~ 2 x 50k Variable Resistor - Local Electronics Store
Tools:
~ Soldering Iron - Sparkfun.com
~ Solder Wire  - Sparkfun.com
~ Jumper Wires - Sparkfun.com
~ Protoboard - Local Electronics Store
All the parts will cost you less than 30$ (Excluding the arduino and all the tools)
Step 2: Build The Circuit
The Circuit is pretty simple connect the four LDR's to analog pins 0,1,2 and 3 respectively via a 10k resistor.Connect the two servos to digital pins 9 and 10 respectively.Conect the two variable resistors to analog pins 4 and 5 .Take a Look at the pictures they really help.See the last picture for the circuit diagram (It might be the baddest that you have ever seen).
Step 3: Build The Sensor Assembly
To build the the sensor assembly take two rectangular pieces of cardboard, cut a long slit through the middle of the first cardboard piece.Cut a short slit through the middle of the second cardboard piece and then intersect both of them and fix them nicely using some tape. It should look like a 3D cross with 4 sections..We have to place our four LDR's in these four sections of the cross.See the pictures they really help.
Step 5: The Code
Heres the code for your solar tracing robot:
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90; // stand horizontal servo
Servo vertical; // vertical servo
int servov = 90; // stand vertical servo
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
void setup()
  Serial.begin(9600);
// servo connections
// name.attacht(pin);
  horizontal.attach(9);
  vertical.attach(10);
void loop()
  int lt = analogRead(ldrlt); // top left
  int rt = analogRead(ldrrt); // top right
  int ld = analogRead(ldrld); // down left
  int rd = analogRead(ldrrd); // down rigt
  int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > 180)
servov = 180;
else if (avt < avd)
servov= --servov;
if (servov < 0)
servov = 0;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < 0)
servoh = 0;
else if (avl < avr)
servoh = ++servoh;
if (servoh > 180)
servoh = 180;
else if (avl = avr)
// nothing
horizontal.write(servoh);
delay(dtime);
Step 6: All Done!
Hope this project inspires further experimentation. The Arduino board is incredibly versatile,cheap, and accessible to all hobbyists . This is just one of many simple projects which can be constructed using the arduino. Keep pondering!.Dont forget to follow mores comming up.For any queries contact me heres my E-mail ID r1398ohit@gmail.com
hesterbergnl says: Sep 28, 2012. 4:11 PM
Alright, so did you write this originally, or did this guy:
http://www.instructables.com/id/Arduino-Solar-Tracker/
geo bruce in reply to hesterbergnlMay 1, 2013. 5:24 AM
the link you posted is mine instructable
I wrote it almost a year before this guy "copied" it.
but he didn't read the license terms
This license lets others remix, tweak, and build upon your work non-commercially, as long as they credit you and license their new creations under the identical terms.
"as long as they credit you" <<< you didn't :(
emdarcher says: Sep 6, 2012. 8:28 AM
you should make it powered by a solar panel that it holds, and directs towards the light, it would be independent. also you could split the power to go to the arduino, and some for surplus energy.
ftello barahona says: Jul 29, 2012. 11:04 AM
Your diagram has free wires
jwkooi says: Jun 12, 2012. 2:16 AM
Nice project! Well done. Do you have a youtube clip to see it working?
mmorlan62 says: Jun 14, 2012. 4:59 AM
That has got to be the punkiest build I've ever seen. LoL! :)
I like the simplicity of the circuit and code. Well done.
Consider painting your cruciform tube black (eliminating stray bounces off the cardboard) to improve the accuracy of the sensors.
Consider how this setup will react to cloudy days. Will it be sending the servos all over the place looking for the brightest spot in the sky? If so, how do you slow down the motion so you don't burn out the servos? Consider adding some acceleration curve code to the movement of the servos, especially once they are driving a load.
Also, consider adding a power relay circuit for the servos so your arduino can turn them on and off, thus relieving them of stress when they aren't moving anyway. The code could;
o turn on the relay, powering the servos
o move the servos to their new position via acceleration curves
o turn off the relay, shutting down the servos
Have fun!
seraine says: Jun 12, 2012. 8:24 PM
You should consider making a schematic, because it makes it a lot easier to understand. Great Instructable, though.
Bot1398 (author) in reply to seraineJun 12, 2012. 9:47 PM
I added a circuit diagram (last pic step 2) now
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
