Introduction:
Step 1: Parts & Tools
Parts:
~ 2 x Servo Motors - Local Electronics Store
~ 4 x LDR's - Local Electronics Store
~ 4 x 10k Resistors - Local Electronics Store
~ Arduino Uno - Sparkfun.com
~ 2 x 50k Variable Resistor - Local Electronics Store
Tools:
~ Soldering Iron - Sparkfun.com
~ Solder Wire - Sparkfun.com
~ Jumper Wires - Sparkfun.com
~ Protoboard - Local Electronics Store
All the parts will cost you less than 30$ (Excluding the arduino and all the tools)
Step 2: Build the Circuit
The Circuit is pretty simple connect the four LDR's to analog pins 0,1,2 and 3 respectively via a 10k resistor.Connect the two servos to digital pins 9 and 10 respectively.Conect the two variable resistors to analog pins 4 and 5 .Take a Look at the pictures they really help.See the last picture for the circuit diagram (It might be the baddest that you have ever seen).
Step 3: Build the Sensor Assembly
To build the the sensor assembly take two rectangular pieces of cardboard, cut a long slit through the middle of the first cardboard piece.Cut a short slit through the middle of the second cardboard piece and then intersect both of them and fix them nicely using some tape. It should look like a 3D cross with 4 sections..We have to place our four LDR's in these four sections of the cross.See the pictures they really help.
Step 4: Set It Up
Find a base (Nescafe bottle in my case) and stick your fist servo to it then to the rotor of the first servo connect the second servo.To the rotor of the second servo connect the sensor assembly that we made earlier.To test your robot take it out in the sun and it should automatically align itself towards the sun.If indoors it will align itself to the brightest source of light in the room. Take a look at the pictures they really help.
Step 5: The Code
Heres the code for your solar tracing robot:
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90; // stand horizontal servo
Servo vertical; // vertical servo
int servov = 90; // stand vertical servo
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
void setup()
Serial.begin(9600);
// servo connections
// name.attacht(pin);
horizontal.attach(9);
vertical.attach(10);
void loop()
int lt = analogRead(ldrlt); // top left
int rt = analogRead(ldrrt); // top right
int ld = analogRead(ldrld); // down left
int rd = analogRead(ldrrd); // down rigt
int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > 180)
servov = 180;
else if (avt < avd)
servov= --servov;
if (servov < 0)
servov = 0;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < 0)
servoh = 0;
else if (avl < avr)
servoh = ++servoh;
if (servoh > 180)
servoh = 180;
else if (avl = avr)
// nothing
horizontal.write(servoh);
delay(dtime);
Step 6: All Done!
Hope this project inspires further experimentation. The Arduino board is incredibly versatile,cheap, and accessible to all hobbyists . This is just one of many simple projects which can be constructed using the arduino. Keep pondering!.Dont forget to follow morescomming up.For any queries contact me heres my E-mail ID r1398ohit@gmail.com
Green Tech Contest
Robot Challenge
