Introduction: Arduino Spectrum Slider
Picture of Arduino Spectrum Slider
Use a potentiometer to show scroll through the visible spectrum
Step 1: Parts
Picture of Parts
Arduino uno
1x long blue jumper cable
1x long red jumper cable
2x short black jumper cable
1x of each RGB jumper cables
Tri color led
Potentiometer
All can be gotten in sidekick kit
Step 2: Schematics
Picture of Schematics
Wire as shown in picture. if led has common cathode rather than anode connect to ground, not 5v.
Step 3: Code
Copy and paste. If common cathode as RGB values to 0 instead of subtracting.
int rPin = 11;
int gPin = 10; int bPin = 9; float rPinBrightness; float gPinBrightness; float bPinBrightness; float value; float mval; float Red; float Green; float Blue; float factor; void setup() { // put your setup code here, to run once:
void color() { mval = analogRead(A1); value = map(mval, 0, 1023, 380, 650);
if((value >= 380) && (value<440)){ Red = -(value - 440) / (440 - 380); Green = 0.0; Blue = 1.0; }else if((value >= 440) && (value<490)){ Red = 0.0; Green = (value - 440) / (490 - 440); Blue = 1.0; }else if((value >= 490) && (value<510)){ Red = 0.0; Green = 1.0; Blue = -(value - 510) / (510 - 490); }else if((value >= 510) && (value<580)){ Red = (value - 510) / (580 - 510); Green = 1.0; Blue = 0.0; }else if((value >= 580) && (value<645)){ Red = 1.0; Green = -(value - 645) / (645 - 580); Blue = 0.0; }else if((value >= 645) && (value<781)){ Red = 1.0; Green = 0.0; Blue = 0.0; }else{ Red = 0.0; Green = 0.0; Blue = 0.0; }; if((value >= 380) && (value<420)){ factor = 0.3 + 0.7*(value - 380) / (420 - 380); }else if((value >= 420) && (value<701)){ factor = 1.0; }else if((value >= 701) && (value<781)){ factor = 0.3 + 0.7*(780 - value) / (780 - 700); }else{ factor = 0.0; };
void loop() { // put your main code here, to run repeatedly: color(); analogWrite(rPin, 255 - Red*100*factor); analogWrite(gPin, 255 - Green*100*factor); analogWrite(bPin, 255 - Blue*100*factor); delay(10); }
About This Instructable
322views
4favorites
More by jallred274:How to Reach Arena 7 in Clash RoyaleArduino Spectrum SliderHow To Win Flappy Bird Every Time
Add instructable to:
