Introduction: Arduino Sun Tracker Turret
Follow the sun with Arduino! In this tutorial, we'll be building an Arduino based Solar Tracking Turret. Most commonly, these are used in Photovoltaic systems to maximize the surface area of sun exposure on solar panels. This is an easy build, so let's get started!
Step 1: Project Parts List
You can use any variety of light sensor, potentiometer, or hobby servo, but for this guide, we recommend the following parts for ease of use.
Step 2: Assemble the Turret
Follow the Desktop RoboTurret Assembly Guide. Once your turret is built, there are many ways to build the top portion of the tracker. General advice for building the top portion: Attach your sensors to the top plates as close to center as possible. Shown in the first picture is the simplest way to get all of your sensors near center. Notice the wiring through the plate, kept loose so that there aren't any snags as the turret aims itself. The fins are 8 inches tall, which should be plenty to cast shadow on the sensors. I've used scrap cardboard for the fins, but you can use whatever material suits you best, so long as it is opaque and can throw a shadow. At the back of the turret base, there is plenty of room to mount your two potentiometers. one controls speed, the other controls the sensitivity threshold for the light sensors. Mounting them to the base allows you to fiddle with them to easily dial in your settings once you have it running.
Step 3: Wiring
Follow the Wiring Diagram carefully to hook up your electronics. Mind the position of your Light Sensors, as putting them in the wrong spot will cause strange behavior. Also mind that your jumper for the servo pins 9, 10, and 11 is set to VIN, so that your servos function properly. (note: a 6V power supply will work just fine, and is included in the RoboTurret Kit)
| Device | Sensor Shield Port |
Top Left Light Sensor RobotGeek Light Sensor | Analog 0 |
Top Right Light Sensor RobotGeek Light Sensor | Analog 1 |
Bottom Left Light Sensor RobotGeek Light Sensor | Analog 2 |
Bottom Right Light Sensor RobotGeek Light Sensor | Analog 3 |
Turret Speed RobotGeek Rotation Knob | Analog 4 |
Light Sensor Sensitivity RobotGeek Rotation Knob | Analog 5 |
Pan RobotGeek 180 Degree Servo | Digital 9 |
Tilt RobotGeek 180 Degree Servo | Digital 10 |
Step 4: Programming
Download the desktopRoboTurretV3 sketches from Github if you haven't already, and extract it to your arduino folder. Open up:
File → Sketchbook → desktopRoboTurretV3 → roboTurret3_solarTracker
and upload it to your arduino.
Power up your turret, get a lamp ready, and start fiddling with the knobs! You'll notice as you adjust one of the knobs, the turret will turn faster or slower. As you adjust the other, the light sensitivity will rise and fall, giving you different behavior. Adjust these knobs until your turret tracks the light smoothly, and you're ready to get some sunburn!
Step 5: Let There Be Light!
You've made a robot that just can't help but stare directly at the sun! What will you do now? We'd suggest looking into making your own solar panel to throw on it so you can reclaim the energy lost by the servos and maybe charge a cell phone while you're at it? What would happen if you swapped out the Light Sensors for something like a Flame Sensor or UV Sensor? Let us know what you come up with, we'd love to see it!
