Arduino - TTP223B - CAPACITIVE TOUCH SENSOR SWITCH
12,731
14
5
Posted in TechnologyArduino
Introduction: Arduino - TTP223B - CAPACITIVE TOUCH SENSOR SWITCH
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I ma...
Hello world! Today i made a code for the ttp223b capacitive touch sensor. A sensor that i am testing for my webshop, and it does its job! So soon i will add it to my webshop at arduinosensors.nl. The code is really easy and can be used with normal buttons to. Follow the next step for the schematic, code & parts list.
Step 1: Schematic Code & Parts List.
It is very easy, Just wire it up like the schematic and upload the code.
Parts list:
  1. Arduino uno, I used the RobotDyn Uno.
  2. KY-019 Relay
  3. TTP223B Capacitive touch sensor.
  4. Jumper wire set MM/FF/MF
  5. Lamp socket + power cable & light bulb (optional)
Good luck!
Follow me for more!
Check out my website arduinosensors.nl
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    5 Comments
    Hello vandenbrande !!!!! i made it , thanks to you for the codes and schematic. Now am trying to make a 4 channel touch relay control. Can you help me with the code ?
    can the touch sensor work by not installing relay ?
    Forgot to push reply button ;D
    Works without relay as well.
    #define TouchSensor 10 // Pin for capactitive touch sensor
    boolean currentState = LOW;
    boolean lastState = LOW;
    int counter = 0;
    void setup() {
    Serial.begin(9600);
    pinMode(TouchSensor, INPUT);
    void loop() {
    currentState = digitalRead(TouchSensor);
    if (currentState == HIGH && lastState == LOW){
    counter++;
    Serial.print("Button pressed: ");
    Serial.print(counter);
    Serial.print(" times!");
    Serial.println("||");
    //delay(1);
    lastState = currentState;
