Arduino Thermometer
6,904
33
Published
Introduction: Arduino Thermometer
This is a thermometer for ambient temperature; it uses a thermistor and displays temperatures from 0 to 40 degrees Celsius.
Step 1: Materials and Schematic
Materials:
Seeeduino (or Arduino) X1
Servo X1
10k resistor X1
50k Thermistor X1
Jumper wires
All materials except the board come from Seeedstudio's Sidekick Kit, which can be found here:
http://www.seeedstudio.com/depot/Sidekick-Basic-Ki...
The picture illustrates the schematic
Step 2: Code
The code is included in the file. It's modified based on Adafruit's tutorial on thermistors, which can be found here:
http://learn.adafruit.com/thermistor/using-a-therm...
It's the most detailed tutorial I've come across, and it explains very clearly the concept of a thermistor, how to connect it to the board, and how to convert the readings into temperatures.
Step 3: Final Step
With the parts working, we just need to add a box outside of the board to protect the wires, and a panel on the servo that marks the temperatures. The servo's arm will point to the number that corresponds to the ambient temperature, with a range from 0 to 40 degrees Celsius.
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    hello. i'm using TMP36 analog temp sensor instead, so no need for a 10k resistor. i have everything plugged in otherwise the same. but in the serial monitor i get numbers like 120, 118, 117 etc. not real C or F values. how can i really tell if it is working, does the code need adjusting if i'm using this type of sensor.? thank you
