3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Thermometer(7-Segment)
Using a dual 7-segment display, a DS18B20 temperature sensor and a couple of shift registers I figured that I could build a digital thermometer.
Step 1Temperature Sensor
Temperature Sensor
The sensor I'm using is the DS18B20, it's a 3pin sensor that just requires a single input pin from the arduino. Multiple sensors can be hooked together, however I'm just using one for this project. As with a lot of different sensors there's a handy library that makes it particularly easy to get the temperature in centigrade or fahrenheit, it's the Dallas_Temperature library available here and a spec sheet for the sensor available from maxim.
To connect it to the arduino connect the ground pin on the sensor to a ground pin on the arduino, put a 4.7k resistor between pin 2 and pin 3 on the sensor, connect pin 3 to 3.3v from the arduino and then connect pin 2 to digital input on the arduino. Once this is done, we're ready to read the temperature!
3 comments
Nov 24, 2011. 6:42 PMmmendoza10 says:
hello,
nice project, i wonder if i can put an interrupt on this program. I will greatly appreciate if you can help me making it work.Thank you.
Nov 8, 2011. 1:49 PMrho2k10 says:
Hello Rahul,
Could you please help out with the schematics? The schematics pic you posted seems very blur.. cant make out what the pinouts are. Thanks!
Nov 7, 2011. 3:22 PMSimpson_jr says:
Hi,
I like your design, using shift registers to free arduino pins is nice and expandable should one want to display really hot or cold temperatures or 1/10 of a degree.
One small detail, you do use Shift-registers, but haven't told which ones, several different ones exist...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rkar(Rahul Kar)
