Arduino Time-Lapse Panorama Controller
21,540
262
30
Published
Introduction: Arduino Time-Lapse Panorama Controller
Panorama Controller for GoPro Cameras
The controller will rotate your GoPro over a set angle for a set duration or will rotate you GoPro for a full rotation for a set duration.
This project is based on the original instructable by Tyler Winegarner See instructable here and also from Mark Wheeler's version of Tyler Winegarner's instructable See Mark Wheeler's instructable here or his web site here .
My instructable combines software and hardware from both versions as well as adding some different build and control options of my own. further details on my web site.
I have added code for a 4x20 I2C LCD display and switches rather than the SainSmart LCD Keypad Shield. I have also removed the Arduino UNO shield and replaced it with an Arduino Atmega 328 mounted on vero board. Full schematics and vero board layouts included.
The Arduino controls a Geared Stepper Motor 28BYJ-48 via a ULN2003 Stepper Motor Driver Board. The 4x20 I2C LCD display and 5 micro switches form the interface to the Arduino. The controller has a Manfrotto 200PL-14 quick release tripod mount for attachment to my tripod and other mounting hardware fitted with a Manfrotto 323 Quick Release Clamp Adapter. Power is provided by a 50000mah USB Power Bank Battery Pack.
Step 1: Parts
General parts list.
I tried to use items I had left over from other projects to keep the cost down. Ebay items in links may only be available for short periods if the links are not there try a search for the items instead.
Atmega328P Kit, Arduino Uno Bootloader, 16MHZ Crystal, 22pF Capacitors Ebay
Geared Stepper Motor 28BYJ-48 + ULN2003 Driver Test Module Board for Arduino 5v
Vero board Ebay
Perspex Sheet/Aluminium sheet as required A5
50000mah Power Bank Pack Backup Mobile Phone Charger Ebay see pic 1 above
USB Lead A to B
USB B PCB socket
Stainless Steel Bar 4mm x 100mm Rod Shaft Ebay
M4 x 50mm (2") Hex Bolts
Nuts/bolts/washers as required
Aluminium Tube to cover hex bolt threads local DIY shop
Aluminium bar loca DIY shop
Wire/connectors
323 Quick Release Clamp Adapter+Plate Compatible fr Manfrotto 200PL Ebay
Bearing Flanged 4mm x2 Ebay
Bearing Flanged 3mm x1 Ebay
Hot Shoe Spirit level Ebay
Adjustable Speedlite Cold Shoe 1/4 Screw to Flash Hot Shoe Mount Adapter Ebay
Meccano Part 26A 19 tooth pinion Ebay
Meccano Black 3.5 inch Gear Wheel No 27b 133 tooth Ebay
Meccano drive shaft stop (taken off an old meccano face plate 109)
GoPro self adhesive mount
Step 2: Hardware
Hardware
The stepper motor and gear wheel are mounted between 2 Perspex sheets separated by 4 x M4 x50mm (2") hex bolts and 4 x aluminium tubes to act as spacers. Flanged bearings 4mm top and 3mm bottom are fitted into holes in the sheet. Once the stepper motor and gears were fitted the control boards were then fitted in around these parts.
I drew a drilling template in Turbocad then marked up the Perspex sheet through the paper printout. Top and lower Perspex sheet were then clamped together and mounting holes and preliminary gear wheel bearing holes were drilled out. Final bearing holes were drilled out once the sheets were separated as the lower bearing is smaller. Before drilling out the stepper motor mounting/pinion hole I mounted the 133 tooth gear wheel and bearings cut the pinion hole then test fitted the stepper motor to check alignment. I slotted one of the stepper motor mounting holes to give a few millimetres of adjustment to enable correct gear meshing.
Pic 1 Top Perspex sheet drilling template for mounting bolts, stepper motor and gear wheel. Lower Perspex sheet is identical but does not require stepper motor holes. It will need additional holes though for the middle bearing plate mount.
Once the stepper motor and gear wheel had been mounted I cut a short piece of aluminium bar to mount the middle bearing. To ensure the middle bearing was in alignment with the the upper and lower bearings I drilled a 4mm hole the middle of the aluminium bar and mounted it on the gear wheel drive shaft. I then marked mounting holes on the lower Perspex sheet through small preliminary holes on the bearing mounting bar.
The 4x20 LCD display is mounted on 2 flat metal bars. These bars are bent to angle the display for viewing and also to keep the overall mounted height within the distance between the Perspex sheets. The bars are fixed to the Perspex sheets with large washers to spread the load on the Perspex. I have used one of the mounting holes to fix the spirit level in place. See pics 2 to 6 above for details.
Step 3: Motor, Gear Wheel and Bearings
The Geared Stepper Motor 28BYJ-48 has a 19 tooth Meccano Pinion attached. The pinion is drilled out to 5mm to fit the stepper motor drive shaft.
The Meccano 133 toothed gear wheel is fitted to a 4mm shaft. The shaft runs on 3 flanged bearings. One on the top Perspex sheet (4mm), one on an aluminium bearing mount fixed 10mm off the bottom Perspex plate (4mm). The 3rd (3mm) on the lower Perspex sheet. The lower bearing is 1mm smaller so the drive shaft cannot pass through but just sit on the bearing surface so it can be supported and still rotate.
Bearing locations pic 4
A. 133 toothed gear wheel B. Upper 4mm bearing C. 133 toothed gear wheel shaft stop (see below) D. 4mm 133 toothed gear wheel shaft E. Middle 4mm bearing F. Lower 3mm bearing
133 Toothed gear wheel release pic 5
133 toothed gear wheel shaft stop (C) prevents the 133 toothed gear wheel and attached camera from falling out of the controller.
Free movement (J ) allows the 133 toothed gear wheel to be lifted free of the stepper motor pinion so the camera can be rotated to any start position by hand. This is useful for initial camera positioning or a quick check of Panorama start and end points before setting on the controller.
Step 4: 323 Quick Release Clamp Adapter+Plate Compatible for Manfrotto 200PL
A Manfrotto PL200 quick release plate pic 1 (A) is fitted to the bottom of the controller
using a number of Manfrotto 323 quick release adapters pic 1(B) I can quickly mount the controller to any number of tri-pods or mounting devices.
pic 2 controller fitted to a miniature tripod via a Manfrotto PL200 quick release adapter plate
and pic 2 fitted to universal bar clamp
Step 5: Electronic
Pic 1 shows the overall schematic
Pic 2 shows the schematic of the ULN2003 stepper motor driver board
Pic 3 shows the ULN2003 board itself
Full size schematic
Step 6: Veroboard Layouts
Pic 1 shows the front of the Veroboard
Pic 2 shows the back of the Veroboard flipped down
Pic 3 shows the front of the switch Veroboard
Pic 4 shows the rear of the switch Veroboard flipped down
Pic 5 shows the switch Veroboard painted black and an aluminum label bar attached
Step 7: Code
Code
This code is based on Tyler Winegarner/Mark Wheeler's code and has been modified to work on a 20x4 I2C LCD display without built in switches.
On normal boot/reset a modified version of Tyler Winegarner's set angled rotation Panorama is loaded. If the Rotate Mode switch is held on reset then a modified version of Mark Wheeler's full rotation panorama is loaded.
Download Code
Step 8: Video
Video shows setup of both types of panorama and also a short demo timelapse.
  • Water Contest
    Water Contest
  • Oil Contest
    Oil Contest
  • Clocks Contest
    Clocks Contest
30 Discussions
HtetS2
2 days ago
Hi Oliverb
if you have customized StepperAK.h library file can you share it?
I have pasted the StepperAK.h library in the code section of this instructable. Let me know how you get on.
thanks to you after installed the library
I still have this error message
Timelapse_Panorama_098:29: error: 'POSITIVE' was not declared in this scope
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
Timelapse_Panorama_098:54: error: 'int time' redeclared as different kind of symbol
int time = 0; // clock holder
In file included from C:\Users\user\Desktop\Timelapse_Panorama_098\Timelapse_Panorama_098.ino:22:0:
c:\users\user\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\time.h:122:21: note: previous declaration 'time_t time(time_t*)'
time_t time(time_t *timer);
C:\Users\user\Desktop\Timelapse_Panorama_098\Timelapse_Panorama_098.ino: In function 'void loop()':
Timelapse_Panorama_098:486: error: 'now' was not declared in this scope
time_t timeNow = now(); // What time is it right now?
Timelapse_Panorama_098:586: error: 'now' was not declared in this scope
Timelapse_Panorama_098:587: error: 'second' was not declared in this scope
endtime = second(timeNow) + (minutes*60); // Add duration seconds to get endtime
exit status 1
can you help me cause I choose this as my Arduino first project I have little bit difficult in arduino coding
HtetS2
2 days ago
Hi Oliverb
I got problem with your new coding and I dont know to where to find stepperAK.h library file
if I change to Stepper.h is ok and still got an error in crystal.I2C
haung9
3 months ago
Hi oliverb I having problem with usb connector and push button
.if you can tell me show me the connection diagram for that USB connector and push button
Hi the USB connector only needs 2 pins connected. See this pic for pinouts http://petrockblog.files.wordpress.com/2012/05/wpi...
I will try and re-draw my Veroboard diagram to make it a bit clearer.
I can't remember but you may have to bend the other connector pins away or cut them off.
All the switches apart from the reset switch connect at one end to 5volts. The other ends connect to the Arduino Pins as follows: Select, Rotate, Left/M- and Right/M+.
The rest Switch connects one end to 0v and the other to the reset pin of the Arduino.
I'll let you know when I have updated the Veroboard layouts.
Have added a new step just showing the re-drawn Veroboards.
Hello oliverb
The program works and thank you for your help.
Hello oliverb
I really like
your "Time-Lapse Panorama Controller" project so I made
i too, but with Arduino UNO module.
I have
downloaded the code for the Arduino Time-Lapse Panorama Controller, but I get
the following error:
One more thing,
how important is the 19/133 diameter of gear (cogwheel), will it
influence the accuracy of the rotation?
Thanks for your
answer. Bohuslav Kozdon
"Program error"
C:\Users\xxxx\Documents\Arduino\Timelapse_Panorama_098\Timelapse_Panorama_098.ino:22:0:
c:\program files
(x86)\arduino\hardware\tools\avr\avr\include\time.h:122:21: note: previous
right now?
is it right now?
exit status 1
The big wheel just give a smoother and slower step.
Did you download the code from my link ? Try this link from my web site http://home.btconnect.com/brettoliver1/Timelapse_Panorama/Timelapse_Panorama.zip
Yes, I use the program on your web.site.
The problem is about the library - Time.h.
Error: int time = 0; // clock holder
You can put a link to your - Time.h
please help
I have put a copy of the Time library on my site here http://home.btconnect.com/brettoliver1/Time.zip
I use an $9 egg timer from IKEA.. Does the same thing, alot cheaper.
I have tried the egg timer but you can't control the speed of rotation. You have 1 speed over any angle. They are too slow for a full rotation panorama taking an hour. I use around 2 mins and if you need a narrow angle time lapse over an hour time period for example they turn far too quickly.
Rienv
2 years ago
Good morning Brett,
I have checked all the libraries, but all the libraries are present. Is it possible to sketch including the necessary libraries in a zip file to email to me, I do not come no further,
Sorry for my bad English, I'm 69. Google translator is my friend.
Kind regards,
Rien van Westreenen
The Netherlands
Hi Brett,
I tried both options, but I'm getting at when compiling both the same error message.
Would you please send me the sketch zip file, including the "include files"
The hardware I just almost finished the sketch I do not get to work.
Kind regards,
Rien van Westreenen
The Netherlands
Rienv
2 years ago
Hello Oliver, Please can you help me. I have downloaded the code for the Arduino Time-Lapse Panorama Controller, but I get the following error:
My English is not so good but I hope you understand me.
Kind regards,
Rien van Westreenen \
The Netherlands
Hi Rien.
POSITIVE is used in the Liquid Crystal library.
Try checking you have all the libraries installed for this project.
You will need
<Wire.h>
<LiquidCrystal_I2C.h>
<StepperAK.h>
<Time.h>
Hope this helps.
Brett.
