Arduino Traffic Light Controller W/Remote Control
Published
Introduction: Arduino Traffic Light Controller W/Remote Control
I had a traffic light that I was refinishing.  The only thing left to do was to build the controller for the light's signal patterns.  To give it a twist I incorporated a remote control.  This was also the perfect opportunity for me to try out an Arduino.  I wanted to use the Arduino becuase it was easy to use on both MAC and Windows.
Step 1: Define the Project
To start an electronics design project first define the parameters of it functionality.
This project is defined as:
Control 3 outputs
Read 4 inputs
Read 1 interupt
Features:
3 outputs are sequenced in multiple modes
-Standard Traffic Light pattern
-Reversed Pattern
-Steady on each output
-Blink each output
-Turn off
Increment and decrement sequence speed
Modify saved timing parameters using remote control
and most important; Execute in a realtime manor.
Step 2: Prototype the Circuit
Use prototype methods to test the circuit.
I used the Arduino Duemilanov.  I attached 3 LED's , 4 switches and began to write the code.  The Arduino IDE (which is FREE!!) uses a syntax that is very similar to good old fashioned ANSI C.  I started with the modes of signal patterns.  I used a case statement to modularize my code.  I the added the code for the buttons.  The buttons control mode UP/DN and speed UP/DN.
Step 3: Write the Code
Once I got the basics down I moved on to the add-ons.  I wired the remote control receiver to the Arduino making sure to connect the signal received line to my interrupt pin.   I also buffered my Arduino's output pins using switching transistors that drive 5 volt relays.
Step 4: TEST TEST TEST TEST
Test your circuit and code thoroughly.
The Arduino allows for field program ability, but that is no excuse for not testing.
After adding the remote control I had alot of code changes in order to operate the code.
This version has usable code for the remote's receiver but it breaks the ability to reprogram the timing and default flash pattern and speed at power up.
Step 5: Electronic Schematic Design
Use a design program to model the electronic schematic
Create each component and connect their pins together
Step 6: PCB Layout
Use the design software to layout the PCB (Printed Circuit Board).  Make a cardboard cut out of the final layout and TEST FIT IT.  I got lucky and had enough play if I left the screws loose in the Light Housing, to correctly close and latch the light doors.
Step 7: Cut the PCB
Use an engraver, CNC, Laser, or etching to make the circuit board.
Special thanks to Steve over at The Award Gallery.  Check with your local trophy shop or sign engraver.  They may not know they have this ability.
My board was cut on a 10 year old trophy/plaque engraver.  I used NOVARM's DipTrace to make my schematic and PCB.
Step 8: Assemble the Project
Place the components on the PCB.
Solder the pins and leads.
Step 9: Install the PCB
Install the PCB into the Traffic Light.
Wire all the components
Step 10: Finish
Ada Boy!  Sit back and enjoy the fruits of your labor.
BTW the light bulbs are handmade high efficiency LED's.  This whole traffic light draws less than 10W at 5V with all three lights on.
    • Make it Move Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    hey could i get one from where exactly the traffic light just wondering
    Love this project. About 5 years ago, I got a full size traffic light on eBay, but had no way of controlling it, other than manually with a three way switch I installed.
    Fav'd this, and will give it a try. Been looking for an Arduino project, and I think this is it.
    Thanks!
    That's great, thanks. How bout you share with us your plans for the building of your Traffic Light Stand? That's what I really need more is a stand for my existing light. Thanks, H in FL
    The stand is nothing more than steel pipe and fittings from the home store and an old tire mounted on a donor rim filled with 100lbs of sand
     Great idea! I don't know if it's just me, but all the pictures are grey and say 'This area will preview all your images'. Just FYI
