Arduino Transistor Tester
Published
Introduction: Arduino Transistor Tester
About: I am a arduino developer + all lot of prograaming language developer of age 10
now days you can get transistor tester which can also test other components like resistor,capacitor,inductor,etc.but why to spend some much if you want to know are your transistor are fine so in this instructable I will show you how to make a arduino transistor tester
Note:This works with only NPN Transistor
Step 1: Things Needed
Things required for the project are
  • Arduino (any type)
  • Resistor(1k)
  • Resistor(x2)(220)
  • Red LED
  • Green LED
  • Working Transistor(optional just for helping);
Step 2: Connect the Component on a Breadboard
  • connect gnd to negative rail of breadboard
  • connect collector of transistor to gnd
  • connect 1k resistor to base of resistor
  • connect other side of 1k resistor to pin 2
  • connect emitter of transistor to pin 3
  • connect green LED positive to 220 resistor
  • connect other leg of 220 resistor to pin 13
  • connect the green led negative to gnd
  • connect red led negative to 220 resistor
  • connect the other end of the 220 resistor to gnd
  • connect the red led positive to pin 13
  • done now to the code
Step 3: Code
Now Write the code. The code is in bold
void setup() {
pinMode(2,OUTPUT);
pinMode(3,INPUT_PULLUP);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
Serial.begin(9600);
void loop() {
digitalWrite(2,HIGH); if(digitalRead(3)==LOW){
digitalWrite(13,HIGH);
digitalWrite(12,LOW);
Serial.println("Transistor is working");
delay(100);
else{
digitalWrite(13,LOW);
digitalWrite(12,HIGH);
Serial.println("No transistor or the transistor is broken");
delay(100);
Step 4: How to Know It Works
If you place a transistor(working one) then the green led should light up
if not then then red led should light
Step 5: Sucess
If you done it right then congrats you made now no more transistor tester
thanx for reading my instructable
Microcontroller Contest
This is an entry in the
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    It would be really cool if you could make a tester that could measure the beta value of the transistor.
