Step 9My SW (free for anyone to use)
#include
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);// initialize the library with the numbers of the interface pins
int sensorPin = 0; // select the input pin for the potentiometer (pin 23)
int sensor2Pin = 2; // select the input pin for the potentiometer (pin 23)
int ledPin = 13; // select the pin for the LED
int SPKPin = 6;
int sensorValue = 0; // variable to store the value coming from the sensor
int sensor2Value = 0; // variable to store the value coming from the sensor
float LiMinThreshold = 2700; // Lithium Minimal Voltage for load removal
float LiMaxThreshold = 4200; // Lithium Max Voltage for load removal
float NmhMinThreshold = 950; // NMH Minimal Voltage for load removal
float NmhMaxThreshold = 1600; // NMH Max Voltage for load removal
float SelectedMinThreshold = 5000;
int i;
int BatVoltage = 5000;
int FetVoltage = 5000;
long TotalCurrent = 0;
boolean done = false;
unsigned long PrevMillis ;
unsigned long MillisPassed ;
void CL2(){
lcd.setCursor(0, 1);// Second line first char
lcd.print(" ");
void setup() {
Serial.begin(9600);// start serial port to send data during run to the PC
pinMode(ledPin, OUTPUT);//activation led and enable for FET
pinMode(SPKPin, OUTPUT);//activation led and enable for FET
lcd.begin(24, 2);// set up the LCD's number of rows and columns:
lcd.print("Bat PWR Tester[Active]"); // Print a message to the LCD.
lcd.print("Detecting Bat Type..."); // print voltage value
delay(2000);
lcd.print(" ");
digitalWrite(ledPin, HIGH); // set the LED on
sensorValue = analogRead(sensorPin); // read the value from the sensor:
digitalWrite(ledPin, LOW); // set the LED off
// Detecting battery type
BatVoltage = sensorValue*4.887;
if (BatVoltage > 4500){
lcd.print("Warning high-V! ");
done = true;}
else if (BatVoltage > LiMinThreshold){
lcd.print("Type:Li-Ion Bat ");
SelectedMinThreshold = LiMinThreshold;}
else if (BatVoltage > NmhMinThreshold){
lcd.print("Type:NiMH/Cd Bat ");
SelectedMinThreshold = NmhMinThreshold;}
else{
lcd.print("Unknown Bat V<1 ");
done = true;}
lcd.print("V=");
lcd.print(sensorValue*4.887); // print voltage value
Serial.print("DT[ms]");
Serial.print("\t");
Serial.print("Bat[mV]");
Serial.print("\t");
Serial.print("Fet[mV]");
Serial.println("");
delay(3000);
CL2();
PrevMillis = millis();
void loop() {
if (BatVoltage > SelectedMinThreshold && !done) {
sensor2Value = analogRead(sensor2Pin); // read the value from the FET:
FetVoltage = (sensor2Value*4.887);
BatVoltage = (sensorValue*4.887);
CL2();
lcd.print("V=");
lcd.print(BatVoltage); // print voltage value
lcd.print("mV");
//lcd.print(FetVoltage); // print voltage value
TotalCurrent=TotalCurrent+MillisPassed/1000*(BatVoltage-FetVoltage)/2.2/3.6;
lcd.print(" I=");
lcd.print(TotalCurrent/1000);
lcd.print("mAH ");
delay(1000);
MillisPassed = millis()- PrevMillis;
Serial.print(int(MillisPassed));
Serial.print("\t"); // prints a tab
Serial.print(BatVoltage);
Serial.print(FetVoltage);
Serial.println(""); // prints a tab
CL2();
else
done=true;
digitalWrite(ledPin, LOW); // set the LED off - stop loading
lcd.setCursor(0, 0);// First line first char
lcd.print("Bat Power Tester [DONE] "); // Print a message to the LCD.
CL2();//clear line 2
lcd.print("V=");
lcd.print("mV I=");
lcd.print("mAH ");
for (int i=0; i<100 ; i++){
digitalWrite(SPKPin, HIGH);
delay(1);
digitalWrite(SPKPin, LOW);
delay(1);
delay(1000);
$ diff my.cpp orig.cpp
7,8c8,9
< int ledPin = 8; // select the pin for the LED
< int SPKPin = 9;
> int SPKPin = 6;
18c19
< int FetVoltage = 0;
66,67d66
< Serial.print("\t");
< Serial.print("Capacity[mAH]");
75c74
< if ( (BatVoltage-FetVoltage) > SelectedMinThreshold && !done) {
86c85
< TotalCurrent=TotalCurrent+MillisPassed/1000*(BatVoltage-FetVoltage)/10/3.6;
98,99d96
< Serial.print("\t"); // prints a tab
< Serial.print(TotalCurrent/1000);
