Arduino Uno W/ ATmega168 W/ 16Mhz and 20Mhz Support
Published
Introduction: Arduino Uno W/ ATmega168 W/ 16Mhz and 20Mhz Support
If you want to use an atmega160 mcu on an adruino uno or a 20Mhz oscillator to boost it a little bit
you have 3 choices
#1 easy way : buy an Arduino duemilanove or a decimilia board
#2 the free way : edit the Arduino app to accept the 168 on the uno :-P
#3 buy a raspberry pi to get more power $$$
Step 1: The MacOS Way
picture #1 open app folder
picture #2 right click on Arduino app and open the second item
follow the folder in each pic
last picture : open up board text file
Step 2: The Windows Way
go to your app folder usually c:\program files
find the Arduino folder
browse to \hardware\arduino\avr
open up board.txt
Step 3: The Interesting Part
copy and paste this programmation below in the board text file
Ps: you must replace everyting with this code
source code on pastebin
menu.cpu=Processor
menu.speed=Speed
yun.name=Arduino Yún
yun.upload.via_ssh=true
yun.vid.0=0x2341 yun.pid.0=0x0041 yun.vid.1=0x2341 yun.pid.1=0x8041 yun.vid.2=0x2A03 yun.pid.2=0x0041 yun.vid.3=0x2A03 yun.pid.3=0x8041
yun.upload.tool=avrdude yun.upload.protocol=avr109 yun.upload.maximum_size=28672 yun.upload.maximum_data_size=2560 yun.upload.speed=57600 yun.upload.disable_flushing=true yun.upload.use_1200bps_touch=true yun.upload.wait_for_upload_port=true
yun.bootloader.tool=avrdude yun.bootloader.low_fuses=0xff yun.bootloader.high_fuses=0xd8 yun.bootloader.extended_fuses=0xfb yun.bootloader.file=caterina/Caterina-Yun.hex yun.bootloader.noblink=caterina/Caterina-Yun-noblink.hex yun.bootloader.unlock_bits=0x3F yun.bootloader.lock_bits=0x2F
yun.build.mcu=atmega32u4 yun.build.f_cpu=16000000L yun.build.vid=0x2341 yun.build.pid=0x8041 yun.build.usb_product="Arduino Yun" yun.build.board=AVR_YUN yun.build.core=arduino yun.build.variant=yun yun.build.extra_flags={build.usb_flags}
uno.name=Arduino/Genuino Uno uno.vid.0=0x2341 uno.pid.0=0x0043 uno.vid.1=0x2341 uno.pid.1=0x0001 uno.vid.2=0x2A03 uno.pid.2=0x0043 uno.vid.3=0x2341 uno.pid.3=0x0243
uno.upload.tool=avrdude uno.upload.protocol=arduino
uno.bootloader.tool=avrdude
uno.build.board=AVR_UNO uno.build.core=arduino uno.build.variant=standard
## Arduino Uno w/ ATmega328 16Mhz ## --------------------------------------------- uno.menu.cpu.atmega32816=ATmega328 16Mhz uno.menu.cpu.atmega32816.upload.maximum_size=32256 uno.menu.cpu.atmega32816.upload.maximum_data_size=2048 uno.menu.cpu.atmega32816.upload.speed=115200 uno.menu.cpu.atmega32816.bootloader.high_fuses=0xDE uno.menu.cpu.atmega32816.bootloader.low_fuses=0xFF uno.menu.cpu.atmega32816.bootloader.extended_fuses=0x05 uno.menu.cpu.atmega32816.bootloader.lock_bits=0x0F uno.menu.cpu.atmega32816.bootloader.unlock_bits=0x3F uno.menu.cpu.atmega32816.bootloader.file=optiboot/optiboot_atmega328.hex uno.menu.cpu.atmega32816.build.mcu=atmega328p uno.menu.cpu.atmega32816.build.f_cpu=16000000L
## Arduino Uno w/ ATmega328 20Mhz ## --------------------------------------------- uno.menu.cpu.atmega32820=ATmega328 20Mhz uno.menu.cpu.atmega32820.upload.maximum_size=32256 uno.menu.cpu.atmega32820.upload.maximum_data_size=2048 uno.menu.cpu.atmega32820.upload.speed=115200 uno.menu.cpu.atmega32820.bootloader.high_fuses=0xDE uno.menu.cpu.atmega32816.bootloader.low_fuses=0xFF uno.menu.cpu.atmega32816.bootloader.lock_bits=0x0F uno.menu.cpu.atmega32816.bootloader.unlock_bits=0x3F uno.menu.cpu.atmega32820.bootloader.extended_fuses=0x05 uno.menu.cpu.atmega32820.bootloader.file=optiboot/optiboot_atmega328_20Mhz.hex uno.menu.cpu.atmega32820.build.mcu=atmega328p uno.menu.cpu.atmega32820.build.f_cpu=20000000L
## Arduino Uno w/ ATmega168 20Mhz ## --------------------------------------------- uno.menu.cpu.atmega16820=ATmega168 20Mhz uno.menu.cpu.atmega16820.upload.maximum_size=14336 uno.menu.cpu.atmega16820.upload.maximum_data_size=1024 uno.menu.cpu.atmega16820.upload.speed=19200 uno.menu.cpu.atmega16820.bootloader.high_fuses=0xDD uno.menu.cpu.atmega16820.bootloader.low_fuses=0xFF uno.menu.cpu.atmega16820.bootloader.lock_bits=0x0F uno.menu.cpu.atmega16820.bootloader.unlock_bits=0x3F uno.menu.cpu.atmega16820.bootloader.extended_fuses=0x00 uno.menu.cpu.atmega16820.build.mcu=atmega168 uno.menu.cpu.atmega16820.build.f_cpu=20000000L uno.menu.cpu.atmega16820.bootloader.file=optiboot/optiboot_atmega168_20Mhz.hex
## Arduino Uno w/ ATmega168 16Mhz ## --------------------------------------------- uno.menu.cpu.atmega16816=ATmega168 16Mhz uno.menu.cpu.atmega16816.upload.maximum_size=14336 uno.menu.cpu.atmega16816.upload.maximum_data_size=1024 uno.menu.cpu.atmega16816.upload.speed=19200 uno.menu.cpu.atmega16816.bootloader.high_fuses=0xdd uno.menu.cpu.atmega16816.bootloader.low_fuses=0xFF uno.menu.cpu.atmega16816.bootloader.lock_bits=0x0F uno.menu.cpu.atmega16816.bootloader.unlock_bits=0x3F uno.menu.cpu.atmega16816.bootloader.extended_fuses=0x00 uno.menu.cpu.atmega16816.build.mcu=atmega168 uno.menu.cpu.atmega16816.build.f_cpu=16000000L uno.menu.cpu.atmega16816.bootloader.file=optiboot/optiboot_atmega168.hex
diecimila.name=Arduino Duemilanove or Diecimila
diecimila.upload.tool=avrdude diecimila.upload.protocol=arduino
diecimila.bootloader.tool=avrdude diecimila.bootloader.low_fuses=0xFF diecimila.bootloader.unlock_bits=0x3F diecimila.bootloader.lock_bits=0x0F diecimila.build.f_cpu=16000000L diecimila.build.board=AVR_DUEMILANOVE diecimila.build.core=arduino diecimila.build.variant=standard
## Arduino Duemilanove or Diecimila w/ ATmega328 ## --------------------------------------------- diecimila.menu.cpu.atmega328=ATmega328 diecimila.menu.cpu.atmega328.upload.maximum_size=30720 diecimila.menu.cpu.atmega328.upload.maximum_data_size=2048 diecimila.menu.cpu.atmega328.upload.speed=57600 diecimila.menu.cpu.atmega328.bootloader.high_fuses=0xDA diecimila.menu.cpu.atmega328.bootloader.extended_fuses=0x05 diecimila.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex diecimila.menu.cpu.atmega328.build.mcu=atmega328p
## Arduino Duemilanove or Diecimila w/ ATmega168 ## --------------------------------------------- diecimila.menu.cpu.atmega168=ATmega168
diecimila.menu.cpu.atmega168.upload.maximum_size=14336 diecimila.menu.cpu.atmega168.upload.maximum_data_size=1024 diecimila.menu.cpu.atmega168.upload.speed=19200
diecimila.menu.cpu.atmega168.bootloader.high_fuses=0xdd diecimila.menu.cpu.atmega168.bootloader.extended_fuses=0x00 diecimila.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
diecimila.menu.cpu.atmega168.build.mcu=atmega168
nano.name=Arduino Nano
nano.upload.tool=avrdude nano.upload.protocol=arduino
nano.bootloader.tool=avrdude nano.bootloader.unlock_bits=0x3F nano.bootloader.lock_bits=0x0F
nano.build.f_cpu=16000000L nano.build.board=AVR_NANO nano.build.core=arduino nano.build.variant=eightanaloginputs
## Arduino Nano w/ ATmega328 ## ------------------------- nano.menu.cpu.atmega328=ATmega328
nano.menu.cpu.atmega328.upload.maximum_size=30720 nano.menu.cpu.atmega328.upload.maximum_data_size=2048 nano.menu.cpu.atmega328.upload.speed=57600
nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05 nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
nano.menu.cpu.atmega328.build.mcu=atmega328p
## Arduino Nano w/ ATmega168 ## ------------------------- nano.menu.cpu.atmega168=ATmega168
nano.menu.cpu.atmega168.upload.maximum_size=14336 nano.menu.cpu.atmega168.upload.maximum_data_size=1024 nano.menu.cpu.atmega168.upload.speed=19200
nano.menu.cpu.atmega168.bootloader.low_fuses=0xff nano.menu.cpu.atmega168.bootloader.high_fuses=0xdd nano.menu.cpu.atmega168.bootloader.extended_fuses=0x00 nano.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
nano.menu.cpu.atmega168.build.mcu=atmega168
mega.name=Arduino/Genuino Mega or Mega 2560
mega.vid.0=0x2341 mega.pid.0=0x0010 mega.vid.1=0x2341 mega.pid.1=0x0042 mega.vid.2=0x2A03 mega.pid.2=0x0010 mega.vid.3=0x2A03 mega.pid.3=0x0042 mega.vid.4=0x2341 mega.pid.4=0x0210 mega.vid.5=0x2341 mega.pid.5=0x0242
mega.upload.tool=avrdude mega.upload.maximum_data_size=8192
mega.bootloader.tool=avrdude mega.bootloader.low_fuses=0xFF mega.bootloader.unlock_bits=0x3F mega.bootloader.lock_bits=0x0F
mega.build.f_cpu=16000000L mega.build.core=arduino mega.build.variant=mega # default board may be overridden by the cpu menu mega.build.board=AVR_MEGA2560
## Arduino/Genuino Mega w/ ATmega2560 ## ------------------------- mega.menu.cpu.atmega2560=ATmega2560 (Mega 2560)
mega.menu.cpu.atmega2560.upload.protocol=wiring mega.menu.cpu.atmega2560.upload.maximum_size=253952 mega.menu.cpu.atmega2560.upload.speed=115200
mega.menu.cpu.atmega2560.bootloader.high_fuses=0xD8 mega.menu.cpu.atmega2560.bootloader.extended_fuses=0xFD mega.menu.cpu.atmega2560.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
mega.menu.cpu.atmega2560.build.mcu=atmega2560 mega.menu.cpu.atmega2560.build.board=AVR_MEGA2560
## Arduino Mega w/ ATmega1280 ## ------------------------- mega.menu.cpu.atmega1280=ATmega1280
mega.menu.cpu.atmega1280.upload.protocol=arduino mega.menu.cpu.atmega1280.upload.maximum_size=126976 mega.menu.cpu.atmega1280.upload.speed=57600
mega.menu.cpu.atmega1280.bootloader.high_fuses=0xDA mega.menu.cpu.atmega1280.bootloader.extended_fuses=0xF5 mega.menu.cpu.atmega1280.bootloader.file=atmega/ATmegaBOOT_168_atmega1280.hex
mega.menu.cpu.atmega1280.build.mcu=atmega1280 mega.menu.cpu.atmega1280.build.board=AVR_MEGA
megaADK.name=Arduino Mega ADK
megaADK.vid.0=0x2341 megaADK.pid.0=0x003f megaADK.vid.1=0x2341 megaADK.pid.1=0x0044 megaADK.vid.2=0x2A03 megaADK.pid.2=0x003f megaADK.vid.3=0x2A03 megaADK.pid.3=0x0044
megaADK.upload.tool=avrdude megaADK.upload.protocol=wiring megaADK.upload.maximum_size=253952 megaADK.upload.maximum_data_size=8192 megaADK.upload.speed=115200
megaADK.bootloader.tool=avrdude megaADK.bootloader.low_fuses=0xFF megaADK.bootloader.high_fuses=0xD8 megaADK.bootloader.extended_fuses=0xFD megaADK.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex megaADK.bootloader.unlock_bits=0x3F megaADK.bootloader.lock_bits=0x0F
megaADK.build.mcu=atmega2560 megaADK.build.f_cpu=16000000L megaADK.build.board=AVR_ADK megaADK.build.core=arduino megaADK.build.variant=mega
leonardo.name=Arduino Leonardo leonardo.vid.0=0x2341 leonardo.pid.0=0x0036 leonardo.vid.1=0x2341 leonardo.pid.1=0x8036 leonardo.vid.2=0x2A03 leonardo.pid.2=0x0036 leonardo.vid.3=0x2A03 leonardo.pid.3=0x8036
leonardo.upload.tool=avrdude leonardo.upload.protocol=avr109 leonardo.upload.maximum_size=28672 leonardo.upload.maximum_data_size=2560 leonardo.upload.speed=57600 leonardo.upload.disable_flushing=true leonardo.upload.use_1200bps_touch=true leonardo.upload.wait_for_upload_port=true
leonardo.bootloader.tool=avrdude leonardo.bootloader.low_fuses=0xff leonardo.bootloader.high_fuses=0xd8 leonardo.bootloader.extended_fuses=0xcb leonardo.bootloader.file=caterina/Caterina-Leonardo.hex leonardo.bootloader.unlock_bits=0x3F leonardo.bootloader.lock_bits=0x2F
leonardo.build.mcu=atmega32u4 leonardo.build.f_cpu=16000000L leonardo.build.vid=0x2341 leonardo.build.pid=0x8036 leonardo.build.usb_product="Arduino Leonardo" leonardo.build.board=AVR_LEONARDO leonardo.build.core=arduino leonardo.build.variant=leonardo leonardo.build.extra_flags={build.usb_flags}
micro.name=Arduino/Genuino Micro
micro.vid.0=0x2341 micro.pid.0=0x0037 micro.vid.1=0x2341 micro.pid.1=0x8037 micro.vid.2=0x2A03 micro.pid.2=0x0037 micro.vid.3=0x2A03 micro.pid.3=0x8037
micro.vid.4=0x2341 micro.pid.4=0x0237 # If the board is a 2341:0237 use 2341:8237 for build and set # other parameters as well micro.vid.4.build.vid=0x2341 micro.vid.4.build.pid=0x8237 micro.vid.4.build.usb_product="Genuino Micro" micro.vid.4.bootloader.file=caterina/Caterina-Genuino-Micro.hex
micro.vid.5=0x2341 micro.pid.5=0x8237 # If the board is a 2341:8237 use 2341:8237 for build and set # other paramters as well micro.vid.5.build.vid=0x2341 micro.vid.5.build.pid=0x8237 micro.vid.5.build.usb_product="Genuino Micro" micro.vid.5.bootloader.file=caterina/Caterina-Genuino-Micro.hex
micro.upload.tool=avrdude micro.upload.protocol=avr109 micro.upload.maximum_size=28672 micro.upload.maximum_data_size=2560 micro.upload.speed=57600 micro.upload.disable_flushing=true micro.upload.use_1200bps_touch=true micro.upload.wait_for_upload_port=true
micro.bootloader.tool=avrdude micro.bootloader.low_fuses=0xff micro.bootloader.high_fuses=0xd8 micro.bootloader.extended_fuses=0xcb micro.bootloader.file=caterina/Caterina-Micro.hex micro.bootloader.unlock_bits=0x3F micro.bootloader.lock_bits=0x2F
micro.build.mcu=atmega32u4 micro.build.f_cpu=16000000L micro.build.vid=0x2341 micro.build.pid=0x8037 micro.build.usb_product="Arduino Micro" micro.build.board=AVR_MICRO micro.build.core=arduino micro.build.variant=micro micro.build.extra_flags={build.usb_flags}
esplora.name=Arduino Esplora esplora.vid.0=0x2341 esplora.pid.0=0x003C esplora.vid.1=0x2341 esplora.pid.1=0x803C esplora.vid.2=0x2A03 esplora.pid.2=0x003C esplora.vid.3=0x2A03 esplora.pid.3=0x803C
esplora.upload.tool=avrdude esplora.upload.protocol=avr109 esplora.upload.maximum_size=28672 esplora.upload.maximum_data_size=2560 esplora.upload.speed=57600 esplora.upload.disable_flushing=true esplora.upload.use_1200bps_touch=true esplora.upload.wait_for_upload_port=true
esplora.bootloader.tool=avrdude esplora.bootloader.low_fuses=0xff esplora.bootloader.high_fuses=0xd8 esplora.bootloader.extended_fuses=0xcb esplora.bootloader.file=caterina/Caterina-Esplora.hex esplora.bootloader.unlock_bits=0x3F esplora.bootloader.lock_bits=0x2F
esplora.build.mcu=atmega32u4 esplora.build.f_cpu=16000000L esplora.build.vid=0x2341 esplora.build.pid=0x803c esplora.build.usb_product="Arduino Esplora" esplora.build.board=AVR_ESPLORA esplora.build.core=arduino esplora.build.variant=leonardo esplora.build.extra_flags={build.usb_flags}
mini.name=Arduino Mini
mini.upload.tool=avrdude mini.upload.protocol=arduino
mini.bootloader.tool=avrdude mini.bootloader.low_fuses=0xff mini.bootloader.unlock_bits=0x3F mini.bootloader.lock_bits=0x0F
mini.build.f_cpu=16000000L mini.build.board=AVR_MINI mini.build.core=arduino mini.build.variant=eightanaloginputs
## Arduino Mini w/ ATmega328 ## ------------------------- mini.menu.cpu.atmega328=ATmega328
mini.menu.cpu.atmega328.upload.maximum_size=28672 mini.menu.cpu.atmega328.upload.maximum_data_size=2048 mini.menu.cpu.atmega328.upload.speed=115200
mini.menu.cpu.atmega328.bootloader.high_fuses=0xd8 mini.menu.cpu.atmega328.bootloader.extended_fuses=0x05 mini.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328-Mini.hex
mini.menu.cpu.atmega328.build.mcu=atmega328p
## Arduino Mini w/ ATmega168 ## ------------------------- mini.menu.cpu.atmega168=ATmega168
mini.menu.cpu.atmega168.upload.maximum_size=14336 mini.menu.cpu.atmega168.upload.maximum_data_size=1024 mini.menu.cpu.atmega168.upload.speed=19200
mini.menu.cpu.atmega168.bootloader.high_fuses=0xdd mini.menu.cpu.atmega168.bootloader.extended_fuses=0x00 mini.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
mini.menu.cpu.atmega168.build.mcu=atmega168
ethernet.name=Arduino Ethernet
ethernet.upload.tool=avrdude ethernet.upload.protocol=arduino ethernet.upload.maximum_size=32256 ethernet.upload.maximum_data_size=2048 ethernet.upload.speed=115200
ethernet.bootloader.tool=avrdude ethernet.bootloader.low_fuses=0xff ethernet.bootloader.high_fuses=0xde ethernet.bootloader.extended_fuses=0x05 ethernet.bootloader.file=optiboot/optiboot_atmega328.hex ethernet.bootloader.unlock_bits=0x3F ethernet.bootloader.lock_bits=0x0F
ethernet.build.variant=ethernet ethernet.build.mcu=atmega328p ethernet.build.f_cpu=16000000L ethernet.build.board=AVR_ETHERNET ethernet.build.core=arduino
fio.name=Arduino Fio
fio.upload.tool=avrdude fio.upload.protocol=arduino fio.upload.maximum_size=30720 fio.upload.maximum_data_size=2048 fio.upload.speed=57600
fio.bootloader.tool=avrdude fio.bootloader.low_fuses=0xFF fio.bootloader.high_fuses=0xDA fio.bootloader.extended_fuses=0x05 fio.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex fio.bootloader.unlock_bits=0x3F fio.bootloader.lock_bits=0x0F
fio.build.mcu=atmega328p fio.build.f_cpu=8000000L fio.build.board=AVR_FIO fio.build.core=arduino fio.build.variant=eightanaloginputs
bt.name=Arduino BT
bt.upload.tool=avrdude bt.upload.protocol=arduino bt.upload.speed=19200 bt.upload.disable_flushing=true
bt.bootloader.tool=avrdude bt.bootloader.low_fuses=0xff bt.bootloader.unlock_bits=0x3F bt.bootloader.lock_bits=0x0F
bt.build.f_cpu=16000000L bt.build.board=AVR_BT bt.build.core=arduino bt.build.variant=eightanaloginputs
## Arduino BT w/ ATmega328 ## ----------------------- bt.menu.cpu.atmega328=ATmega328 bt.menu.cpu.atmega328.upload.maximum_size=28672 bt.menu.cpu.atmega328.upload.maximum_data_size=2048
bt.menu.cpu.atmega328.bootloader.high_fuses=0xd8 bt.menu.cpu.atmega328.bootloader.extended_fuses=0x05 bt.menu.cpu.atmega328.bootloader.file=bt/ATmegaBOOT_168_atmega328_bt.hex
bt.menu.cpu.atmega328.build.mcu=atmega328p
## Arduino BT w/ ATmega168 ## ----------------------- bt.menu.cpu.atmega168=ATmega168 bt.menu.cpu.atmega168.upload.maximum_size=14336 bt.menu.cpu.atmega168.upload.maximum_data_size=1024
bt.menu.cpu.atmega168.bootloader.high_fuses=0xdd bt.menu.cpu.atmega168.bootloader.extended_fuses=0x00 bt.menu.cpu.atmega168.bootloader.file=bt/ATmegaBOOT_168.hex
bt.menu.cpu.atmega168.build.mcu=atmega168
LilyPadUSB.name=LilyPad Arduino USB LilyPadUSB.vid.0=0x1B4F LilyPadUSB.pid.0=0x9207 LilyPadUSB.vid.1=0x1B4F LilyPadUSB.pid.1=0x9208
LilyPadUSB.upload.tool=avrdude LilyPadUSB.upload.protocol=avr109 LilyPadUSB.upload.maximum_size=28672 LilyPadUSB.upload.maximum_data_size=2560 LilyPadUSB.upload.speed=57600 LilyPadUSB.upload.disable_flushing=true LilyPadUSB.upload.use_1200bps_touch=true LilyPadUSB.upload.wait_for_upload_port=true
LilyPadUSB.bootloader.tool=avrdude LilyPadUSB.bootloader.low_fuses=0xff LilyPadUSB.bootloader.high_fuses=0xd8 LilyPadUSB.bootloader.extended_fuses=0xce LilyPadUSB.bootloader.file=caterina-LilyPadUSB/Caterina-LilyPadUSB.hex LilyPadUSB.bootloader.unlock_bits=0x3F LilyPadUSB.bootloader.lock_bits=0x2F
LilyPadUSB.build.mcu=atmega32u4 LilyPadUSB.build.f_cpu=8000000L LilyPadUSB.build.vid=0x1B4F LilyPadUSB.build.pid=0x9208 LilyPadUSB.build.usb_product="LilyPad USB" LilyPadUSB.build.board=AVR_LILYPAD_USB LilyPadUSB.build.core=arduino LilyPadUSB.build.variant=leonardo LilyPadUSB.build.extra_flags={build.usb_flags}
lilypad.name=LilyPad Arduino
lilypad.upload.tool=avrdude lilypad.upload.protocol=arduino
lilypad.bootloader.tool=avrdude lilypad.bootloader.unlock_bits=0x3F lilypad.bootloader.lock_bits=0x0F
lilypad.build.f_cpu=8000000L lilypad.build.board=AVR_LILYPAD lilypad.build.core=arduino lilypad.build.variant=standard
## LilyPad Arduino w/ ATmega328 ## ---------------------------- lilypad.menu.cpu.atmega328=ATmega328
lilypad.menu.cpu.atmega328.upload.maximum_size=30720 lilypad.menu.cpu.atmega328.upload.maximum_data_size=2048 lilypad.menu.cpu.atmega328.upload.speed=57600
lilypad.menu.cpu.atmega328.bootloader.low_fuses=0xFF lilypad.menu.cpu.atmega328.bootloader.high_fuses=0xDA lilypad.menu.cpu.atmega328.bootloader.extended_fuses=0x05 lilypad.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
lilypad.menu.cpu.atmega328.build.mcu=atmega328p
## LilyPad Arduino w/ ATmega168 ## ---------------------------- lilypad.menu.cpu.atmega168=ATmega168
lilypad.menu.cpu.atmega168.upload.maximum_size=14336 lilypad.menu.cpu.atmega168.upload.maximum_data_size=1024 lilypad.menu.cpu.atmega168.upload.speed=19200
lilypad.menu.cpu.atmega168.bootloader.low_fuses=0xe2 lilypad.menu.cpu.atmega168.bootloader.high_fuses=0xdd lilypad.menu.cpu.atmega168.bootloader.extended_fuses=0x00 lilypad.menu.cpu.atmega168.bootloader.file=lilypad/LilyPadBOOT_168.hex
lilypad.menu.cpu.atmega168.build.mcu=atmega168
pro.name=Arduino Pro or Pro Mini
pro.upload.tool=avrdude pro.upload.protocol=arduino
pro.bootloader.tool=avrdude pro.bootloader.unlock_bits=0x3F pro.bootloader.lock_bits=0x0F
pro.build.board=AVR_PRO pro.build.core=arduino pro.build.variant=eightanaloginputs
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328 ## ------------------------------------------------- pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720 pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048 pro.menu.cpu.16MHzatmega328.upload.speed=57600
pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05 pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328 ## -------------------------------------------------- pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 8 MHz)
pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720 pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048 pro.menu.cpu.8MHzatmega328.upload.speed=57600
pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x05 pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168 ## ------------------------------------------------- pro.menu.cpu.16MHzatmega168=ATmega168 (5V, 16 MHz)
pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336 pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024 pro.menu.cpu.16MHzatmega168.upload.speed=19200
pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0x00 pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
pro.menu.cpu.16MHzatmega168.build.mcu=atmega168 pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168 ## -------------------------------------------------- pro.menu.cpu.8MHzatmega168=ATmega168 (3.3V, 8 MHz)
pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336 pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024 pro.menu.cpu.8MHzatmega168.upload.speed=19200
pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6 pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0x00 pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
pro.menu.cpu.8MHzatmega168.build.mcu=atmega168 pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
atmegang.name=Arduino NG or older
atmegang.upload.tool=avrdude atmegang.upload.protocol=arduino atmegang.upload.speed=19200
atmegang.bootloader.tool=avrdude atmegang.bootloader.unlock_bits=0x3F atmegang.bootloader.lock_bits=0x0F
atmegang.build.mcu=atmegang atmegang.build.f_cpu=16000000L atmegang.build.board=AVR_NG atmegang.build.core=arduino atmegang.build.variant=standard
## Arduino NG or older w/ ATmega168 ## -------------------------------- atmegang.menu.cpu.atmega168=ATmega168
atmegang.menu.cpu.atmega168.upload.maximum_size=14336 atmegang.menu.cpu.atmega168.upload.maximum_data_size=1024
atmegang.menu.cpu.atmega168.bootloader.low_fuses=0xff atmegang.menu.cpu.atmega168.bootloader.high_fuses=0xdd atmegang.menu.cpu.atmega168.bootloader.extended_fuses=0x00 atmegang.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
atmegang.menu.cpu.atmega168.build.mcu=atmega168
## Arduino NG or older w/ ATmega8 ## ------------------------------ atmegang.menu.cpu.atmega8=ATmega8
atmegang.menu.cpu.atmega8.upload.maximum_size=7168 atmegang.menu.cpu.atmega8.upload.maximum_data_size=1024
atmegang.menu.cpu.atmega8.bootloader.low_fuses=0xdf atmegang.menu.cpu.atmega8.bootloader.high_fuses=0xca atmegang.menu.cpu.atmega8.bootloader.file=atmega8/ATmegaBOOT-prod-firmware-2009-11-07.hex
atmegang.menu.cpu.atmega8.build.mcu=atmega8
robotControl.name=Arduino Robot Control robotControl.vid.0=0x2341 robotControl.pid.0=0x0038 robotControl.vid.1=0x2341 robotControl.pid.1=0x8038 robotControl.vid.2=0x2A03 robotControl.pid.2=0x0038 robotControl.vid.3=0x2A03 robotControl.pid.3=0x8038
robotControl.upload.tool=avrdude robotControl.upload.protocol=avr109 robotControl.upload.maximum_size=28672 robotControl.upload.maximum_data_size=2560 robotControl.upload.speed=57600 robotControl.upload.disable_flushing=true robotControl.upload.use_1200bps_touch=true robotControl.upload.wait_for_upload_port=true
robotControl.bootloader.tool=avrdude robotControl.bootloader.low_fuses=0xff robotControl.bootloader.high_fuses=0xd8 robotControl.bootloader.extended_fuses=0xcb robotControl.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Control.hex robotControl.bootloader.unlock_bits=0x3F robotControl.bootloader.lock_bits=0x2F
robotControl.build.mcu=atmega32u4 robotControl.build.f_cpu=16000000L robotControl.build.vid=0x2341 robotControl.build.pid=0x8038 robotControl.build.usb_product="Robot Control" robotControl.build.board=AVR_ROBOT_CONTROL robotControl.build.core=arduino robotControl.build.variant=robot_control robotControl.build.extra_flags={build.usb_flags}
robotMotor.name=Arduino Robot Motor robotMotor.vid.0=0x2341 robotMotor.pid.0=0x0039 robotMotor.vid.1=0x2341 robotMotor.pid.1=0x8039 robotMotor.vid.2=0x2A03 robotMotor.pid.2=0x0039 robotMotor.vid.3=0x2A03 robotMotor.pid.3=0x8039
robotMotor.upload.tool=avrdude robotMotor.upload.protocol=avr109 robotMotor.upload.maximum_size=28672 robotMotor.upload.maximum_data_size=2560 robotMotor.upload.speed=57600 robotMotor.upload.disable_flushing=true robotMotor.upload.use_1200bps_touch=true robotMotor.upload.wait_for_upload_port=true
robotMotor.bootloader.tool=avrdude robotMotor.bootloader.low_fuses=0xff robotMotor.bootloader.high_fuses=0xd8 robotMotor.bootloader.extended_fuses=0xcb robotMotor.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Motor.hex robotMotor.bootloader.unlock_bits=0x3F robotMotor.bootloader.lock_bits=0x2F
robotMotor.build.mcu=atmega32u4 robotMotor.build.f_cpu=16000000L robotMotor.build.vid=0x2341 robotMotor.build.pid=0x8039 robotMotor.build.usb_product="Robot Motor" robotMotor.build.board=AVR_ROBOT_MOTOR robotMotor.build.core=arduino robotMotor.build.variant=robot_motor robotMotor.build.extra_flags={build.usb_flags}
gemma.vid.0=0x2341 gemma.pid.0=0x0c9f
gemma.name=Arduino Gemma
gemma.bootloader.low_fuses=0xF1 gemma.bootloader.high_fuses=0xD5 gemma.bootloader.extended_fuses=0xFE gemma.bootloader.tool=avrdude gemma.bootloader.lock_bits= gemma.bootloader.unlock_bits= gemma.bootloader.file=gemma/gemma_v1.hex
gemma.build.mcu=attiny85 gemma.build.f_cpu=8000000L gemma.build.core=arduino gemma.build.variant=gemma gemma.build.board=AVR_GEMMA
gemma.upload.tool=avrdude gemma.upload.maximum_size=5310
Step 4: Time to Test Whoot Whoot !!!
if everything goes good you should have this
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    I'm pretty new to Arduino. What would be the benefit to using the 168 on the UNO instead of the 328 it comes with?
    Thanks for sharing :)
