Arduino VU Meter
34,765
53
14
Posted in TechnologyArduino
Introduction: Arduino VU Meter
About: I am an electrical engineer and an Arduino and electronics enthusiasts. I believe working with electricity should be fun as well as beneficial to engineers and the world at large. Twitter handle: @arduinoha...
Lets make a simple Arduino VU meter!!!
Step 1: Components
· LM386 operational amplifier
· Electret microphone condenser
· Arduino duemilanove
· 10k potentiometer
· Capacitors: 47 nF, 1uF, 10uF, 100uF, 100nF
· Resistors: 10Ω, 22k
· 6 LEDs
To distinguish between the electret positive and negative terminal, perform a continuity test. Measure the resistance between each pin/terminal and the outer casing of the electret. The resistance between the negative pin and the casing should be zero, since they are connected.
Also make sure you understand the LM386 pin configuration as shown in the diagram
Step 2: Electret Circuit
Connect the positive pin of the electret to a 22k resistor and then to the 5v of the arduino.
Connect a capacitor in parallel with the 22k resistor. The capacitor cathode should then connect to the amplifier circuit
Step 3: Amplifier Circuit
The connection is done as shown above. That is why it is important for you to learn the LM386 pin numbers that i showed you in a previous image.
Pin 1 and 8 are not connected to anything, since i will be using the default gain (20x)
Pin 2 and 4 are connected to ground
Pin 3 is is the input and is connected to the input (10k potentiometer slider)
Pin 5 is the output. Its connected to a 47nF capacitor (current bank) and a 10 ohm pulldown resistor. The output is tapped from the pin before the current bank connection.
Pin 6 is connected to 5v
Pin 7 is connected to a 1uF cap and then to ground
Step 4: Video
Step 5: Complete Setup
Here is the complete setup. Upload the code below and enjoy the show.
To learn more about the arduino VU meter and LM386+electret circuit, please visit the link below:
http://www.arduino-hacks.com/arduino-vu-meter-lm386electret-microphone-condenser/
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Make it Move Contest
    14 Comments
    I just put extra 270ohm resistors for leds and did some delay in a code. To fade out more natural, more analog console way. Fun build! Thanks!
    add some capacitors instead of resistors to the leds in parralel
    why capacitors, wont work with them
    can i conect the eletrect directly to the LM386 without the potentiometer ?
    I will adapt your instructables on my Led Cube 8x8x8
    Thanks ;)
    https://www.instructables.com/id/8x8x8-RGB-led-cube-By-Pierrot/
    Hi yhtomitsy. Thanks for the instructable. I have hooked up (what appears to be) your circuit on a breadboard, but i can't get it to work... Using the pot i can get the LED's to light up properly, but there is no sound sensitivity at all. Instead it somehow works like a proximity meter with the display going up, as i move my hand near the board. I have ensured that the electret is positioned right, of course.Do you have any idea, what i could have done wrong?
    I am not sure what the problem is. Would you mind sending a photo of your circuit
    Nice job. Do you know how to convert electret adc value to decibel(dB) ?
    I havent done it before, however, please check out this forum. I think it has exactly what you need http://forum.arduino.cc/index.php?topic=182968.0
    Very nicely done! Can the electret mic be hooked up to the Arduino without a amplifier? Man I was just getting into the song when my internet failed :)
    Yes it can, however its sensitivity is decreased. Check out this link for the instructions on how to do it https://electronpi.wordpress.com/2013/05/28/getting-going-with-an-electret-microphone-and-an-arduino/
    Thanks a lot for the timely reply! I'll have to do this soon. I'll post a pic when I'm done :D
