Introduction: Arduino Vocal Effects Box
This Arduino-powered vocal effects box pitch shifts and distorts incoming audio signals to produce a wide variety of vocal effects. This project is my first experiment with real-time digital signal processing using Arduino. It samples an incoming microphone signal at a rate of about 40kHz, manipulates the audio digitally, and then outputs 8 bit audio at 40kHz. To minimize the amount of computation required by the Arduino, I used a technique called granular synthesis to manipulate the incoming audio signal. Essentially, as audio comes into the Arduino it gets cut up and stored as small (millisecond or microsecond sized) samples called "grains." These grains are then individually manipulated and played back; they may be lengthened or shortened, stretched or compressed, played back in reverse, copied several times, or mixed with other grains. You can hear a (somewhat creepy) audio sample from the effects box below:
Granular synthesis creates a unique type of distortion caused by discontinuities between individual grains in the outgoing signal. Sometimes this distortion creates an effect I can only describe as a "ripping" sound, other times it introduces new frequencies into the audio that were not present before. Here is an example by Aphex Twin, the granular synthesis is especially prominent in the bridge at around 3min in. Another example of granular synthesis, this time applied to vocals for pitch shifting and textural effects, is from Paul Lansky. My favorite thing to do with this effects box is to use subtle pitch shifting to achieve an androgynous vocal sound, I got the idea for the project after listening to copious amounts of Fever Ray this past winter, you can hear how she pitch shifts her voice to sound somewhat masculine at times.
PARTS LIST
(1x) Arduino Uno REV 3 Radioshack 276-128
(7x) 10K Ohm 1/4-Watt Carbon Film Resistor (2 packages) Radioshack #271-1335
(9x) 20K Ohm 1/4-Watt Carbon Film Resistor (2 packages)
(1x) 1K Ohm 1/4-Watt Carbon Film Resistor Radioshack 271-1321
(1x) 50K-Ohm Linear-Taper Potentiometer Radioshack #271-1716
(1x) 10KOhm Audio Control Potentiometer with SPST Switch Radioshack #271-215 (this will be used to control volume and turn the device on/off)
(5x) 0.25" Knurled Knob Radioshack 274-424
(2x) 9V Alkaline Battery Radioshack #23-866
(2x) Heavy-Duty 9V Snap Connectors Radioshack #270-324
(1x) PC Board with Copper Radioshack #276-147
(1x) SPST PC-Mountable Submini Toggle Switch Radioshack #275-645
(2x) Male Header Pins Jameco 103393
(3x) 8 pin socket Radioshack 276-1995
(1x) TL082 Wide Dual JFET Input Op Amp Radioshack 276-1715
(3x) 100K Ohm 1/4-Watt Carbon Film Resistor (1 package) Radioshack 271-1347
(1x) 10uF electrolytic capacitor
(1x) 47nF capacitor
(3x) 0.1uf capacitor Radioshack 55047557
(2x) 1M-Ohm Linear Taper Potentiometer Radioshack 271-211
(1x) 1MOhm logarithmic potentiometer
(1x) 2kOhm 1/4-Watt Carbon Film Resistor
(1x) male header pins Jameco 103393
(1x) 10K-Ohm Linear-Taper Potentiometer Radioshack 271-1715
(1x) DPDT Flatted Metal Lever Toggle Switch Radioshack 275-636
(2x) 1/4" stereo jack Radioshack 274-141 or Radioshack 274-312
(2x) 5mm High-Brightness White LED (1 package) Radioshack 276-017
(2x) 100 ohm 1/4W 5% Carbon Film Resistor Radioshack 271-1311
(2x) TS922IN Dual Op Amp Digikey 497-3049-5-ND (one TS924 would also work, but they are not available on digikey at the moment)
Additional Materials:
22 Gauge Wire Radioshack #278-1224
Solder Radioshack #64-013
sand paper
plywood
wood glue
hot glue
screws
Download Arduino IDE
Step 1: Schematic
I've broken the schematic into three parts so it is easier to understand.
The first schematic shows the audio out circuit. This project outputs audio through an 8 bit R2Rdigital to analog converter through Arduino digital pins 0-7. This signal is sent through an amplifier, a low pass filter, and a volume control pot before being sent out to speakers.
The second schematic shows the mic input circuit. The line in the from the mic is sent through an amplifier and a DC offset circuit before being sent into the Arduino via analog input pin A0.
The third schematic shows how all the controls of the effects box are connected to the Arduino. There are two LED indicators in this project: one clipping indicator and one output indicator. Three pots on the device control grain size, pitch, and wet/dry mix and a switch controls the direction of sample playback (forward or reverse).
Step 2: Header Pins
Solder header pins to your protoboard so that you can snap the arduino directly to the board. Unfortunately the spacing between digital pins 7 and 8 on the arduino is not the standard 2.54mm, so I've found that it's best to try to avoid using these pins if possible (anolog pins can also be used as digital I/O). If you have to use them, try finding long header pins which you can bend into shape (fig 4- from another project).
Step 3: DAC: Part 1
Solder eight 20kOhm resistors to arduino pins D0-D7 as shown in the images above.
Step 4: DAC: Part 2
Solder seven 10kOhm resistors in between each of the 20kOhm's you just soldered. Add an additional 20kOhm resistor to the 20kOhm connected to arduino D0 (the bottom of the ladder).
Step 5: DAC: Part 3
Connect the other end of the 20kOhm reisistor to arduino ground
Step 6: Test DAC
Some info about the code- basically what I've done here is set up a timer interrupt that increments the variable t at a frequency of 40kHz. Once t reaches 627 it resets back to zero (this happens with a frequency of 40,000/628 = 63Hz). Meanwhile, in the main loop the Arduino sends a value between 0 (00000000 in binary) and 255 (11111111 in binary) to digital pins 0 through 7 (PORTD). It calculates this value with the following equation:
PORTD=byte(127+127*sin(2*t/100));
So as t increments from 0 to 627 the sine function moves through one complete cycle. The value sent to PORTD is a sine wave with frequency 63Hz and amplitude 127, oscillating around 127. The DAC translates this to a voltage between 0 and 5V, where a 0 sent to PORTD equals 0V and a 255 sent to PORTD equals 5V.
Step 7: 8 Pin Socket and Buffer
Solder an 8 pin socket to the breadboard. Connect ground to pin 4, 5V to pin 8 and the signal from the DAC to pin3. Solder pins 1 and 2 together (fig 2). This puts the signal through a voltage follower. The voltage follower acts as a buffer, protecting the output from the DAC from any loads that are put on it later in the circuit.
Step 8: Wire Up Pot
Connect three leads to a 10k exponential pot (labelled with an "A") as shown in fig 3. Solder the red lead to pin 1, the green lead to pin 5, and the black lead to ground/pin 4. Solder pins 6 and 7 together (fig 2). This pot will adjust the amplitude of the signal- it is a volume control knob. It does this by acting as a variable voltage divider.
Step 9: Second 8 Pin Socket
Solder a second 8 pin socket and connect ground to pin 4 and 5V to pin 8.
Step 10: Voltage Divider
Solder a 10kOhm resistor to pin 7 of the first TS922IN. Connect a 2kOhm resistor in series with the 10kOhm resistor and connect the other end of the 2kOhm to ground. This is another voltage divider- the purpose of this portion of the circuit is to scale the signal to 2000/(10000+2000) =1/6th its amplitude, I did this so that the max volume would not completely destroy my hearing. Unlike the voltage divider I set up in the last step with the pot, this voltage divider does not change; it scales the amplitude of the signal permanently. The scaled signal comes out from the junction between the two resistors.
If you are planning to send the output out as line level into another effects module or amplifier, then do not add this voltage divider.
Step 11: RC Low Pass Filter
The purpose of a low pass filter in this part of the circuit is to remove the digital artifacts from the output of the DAC without losing too much detail in the higher frequencies of the audio signal.
Nyquist's Theroum states that for a sampling rate of x Hz, the highest frequency that can be produced is x/2 Hz. So if you have a sampling rate of 40kHz (standard for most audio), then the maximum frequency you can reproduce is 20kHz (the upper limit of the audible spectrum).
By using a low pass filter on the signal with a cutoff frequency of 20kHz, you can smooth out the "steps" in your waveform while keeping the overall shape of the waveform intact. I used a simple RC flow pass filter to achieve this: a resistor and a capacitor in series to ground. Connect the resistor to the incoming signal and the capacitor to ground, the signal from the junction between these two components will be low pass filtered.
You can calculate the values of the capacitor and resistor you need for a low pass filter according to the following equation:
cutoff frequency = 1/ (2*pi*R*C)
so for a cutoff frequency of 20,000Hz and 1kOhm resistor:
20000=1/(2*3.14*1000*C)
C =~ 8nF
Since 8nF capacitors are hard to come by I rounded up to 0.01uF. This gives a cutoff frequency of about 16kHz. You can mess around with different values and see what you like best, I tend to like heavier filtering bc it removes more unwanted noise.
Solder a 1kOhm resistor to the junction from the voltage divider from the last step (if you did not include the voltage divider, solder straight to pin 7). Solder a 0.01uF capacitor in series with this resistor to ground. Solder a wire from the junction between the capacitor and resistor to pin 5 of the second socket.
Step 12: More Buffering
In this step I wired the two op amps on the second chip as voltage followers and wired them in parallel so they could source twice the current. As in step 7, this voltage follower acts as a buffer, protecting the incoming waveform from the load of the headphones which will eventually be attached to the output of the buffer.
Solder a wire between the two non-inveting inputs of the op amps (pins 5 and 3 of the second socket). Solder another wire between the two outputs (pins 1 and 7 of the second socket). On the underside of the board solder the inverting inputs to their outputs (fig 2).
Step 13: DC Offset
After all the voltage dividers, the signal coming out of the op amps oscillates between 0 to about 1V (or 0 to 5V if you did not include the voltage divider in step 10). Before sending the signal out to speakers/headphones, it must be offset to oscillate around 0V. This is called a DC offset, it is achieved by running the signal through a capacitor.
Solder the - end of a 100uF (or higher) capacitor to the output of the second op amp. The signal coming from the + end of the capacitor will be DC offset to oscillated around 0V.
Step 14: Audio Jack
Unscrew the plastic case of the audio jack. Solder a black wire (ground) to the longer lead, and wire a green wire (signal out) to the two shorter leads. This jack is stereo, but the signal out of the Arduino is mono, so just wire the mono signal to both stereo outputs.
Use hot glue to add some structural support to these connections and prevent short circuits. Solder the green wire to the + end of the 100uF capacitor and solder the black wire to ground.
Step 15: Microphone Circuit
Fig 2 shows the signal coming straight out of the microphone on an oscilloscope. The signal is relatively weak, with an amplitude of only 200mV. Notice how the signal oscillates around 0 volts- this is typical of audio signals. Ideally, you want to have a signal with a max amplitude of 2.5V oscillating around 2.5V. This way the signal is completely contained within 0-5V; the Arduino will be able to measure it with maximum resolution and no clipping. In order to do this, the signal will need to be DC offset and amplified. DC offset means changing the level that the wave oscillated around (the midpoint of the wave). Amplification means increasing the amplitude (distance between the center point and max or min) of a signal. Amplification also buffers the microphone element from any loads that you may put on it later in the circuit, which is a good thing because it prevents distortion.
Fig 3 shows the same microphone signal after amplification, you can see how the height of the peaks has increased so that the wave oscillates between -2.5 and 2.5 V (amplitude of 2.5V). Fig 4 shows the signal after it has been DC offset; it still has an amplitude of 2.5V, but the center point is 2.5V instead of 0V, so the wave never drops down below 0V. (Note- the slight change in shape between the signals in figure 3 and 4 is dues to changes in my voice between the two pics, it has nothing to do with the circuit). The signal in fig 4 is ready to go to an Arduino analog input pin.
Step 16: Batteries
Two nine volt batteries will be needed to power the TL082. The double pole double throw (DPDT) switch will act as a power switch to both batteries. DPDT switches actually have two separate switches in them, but they are controlled by the same toggle mechanism (fig 1). Wire the red ends of two battery snaps to one side (the same side) of each switch (figs 3 and 4). Solder red wires to the middle leads of each switch (figs 5 and 6). Use hot glue to secure the solder joints if necessary (fig 7).
Step 17: Amplifier Socket and Power
Solder an 8 pin socket onto the protoboard (fig 1). As shown in the pin diagram for the TL082, +V connects to pin 8 and -V connects to pin 4. Connect on of the red wires from the middle lead of the DPDT switch to pin 8. Let's call the battery snap that is attached to this red lead snap #1. Solder the black lead from snap #2 to pin 4 of the socket (figs 2 and 3). Solder the black lead from snap #1 and the remaining red lead from the center pin of switch #2 together on the protoboard (figs 3 and 4), this is the center tap (0v) between the +9/-9V supply. Solder this connection to arduino ground (fig 8).
Step 18: Microphone Input
Unscrew the plastic case from the 1/4" jack. If you have a mono microphone, unclip the right lead (fig 2). I also trimmed some of the metal from the larger lead- the ground lead (figs 5 and 6). Solder a black wire to the ground lead and a green wire to the other lead. Cover the leads of the jack with hot glue to prevent short circuiting or breakage.
Step 19: Non-inverting Amplifier: Part 1
Solder the wires from the 1/4" jack to the protoboard. Solder the black wire to arduino ground and the green wire to pin 5 of the 8 pin socket.
Step 20: Non-inverting Amplifier: Part 1
Solder a 100K resistor between pins 6 and 7 of the 8 pin socket.
Step 21: Non-inverting Amplifier: Part 2
Solder two leads onto a potentiomer (shown in fig 1) so that it acts as a variable resistor. Solder one side (doesn't matter which) to ground and the other side to pin 6 of the socket. This pot will control the amplitude of the incoming microphone signal.
Step 22: DC Offset: Part 1
The DC offset circuit is comprised of two capacitors and a voltage divider. Solder a 10uF electrolytic capacitor so that the + lead connects to pin 7 of the socket.
Step 23: DC Offset: Part 2
Solder a 47nF capacitor to the - end of the 10uF capacitor. Connect the other side of the 47nF cap to ground.
Step 24: DC Offset: Part 3
Create a voltage divider between Arduino +5V and ground by wiring two 100kOhm resistors in series between 5V and ground. Connect the middle junction of the voltage divider to the junction between the two capacitors of the DC offset circuit. This will add 2.5V to the amplified microphone signal.
Step 25: Connect to Analog Input
Connect analog input 0 to the junction between the two capacitors in the DC offset circuit.
Step 26: Simple Audio Out
Step 27:
In the code below I triggered the output to the DAC via the ADC interrupt. This interrupt is similar to other Arduino timer interrupts, but it only executed when a new ADC value has been reached (in this case at a rate of ~38.5kHz, or every 26us). The output of the code below is exactly the same as the code above, but it will be more convenient to use the interrupt code moving forward.
Step 28: Half Frequency Playback
Step 29: RC Potentiometers
Since the ADC is busy converting the incoming audio from A0 to digital, the three control pots on the effects box (wet/dry, pitch, and grain size) will have to be monitored using one of the digital pins. This can be down using an RC circuit. This circuit uses a digital pin on the Arduino to measure the amount of time it takes to discharge a capacitor. This time is related to the resistance in the circuit which is set by a potentiometer. This way, we can indirectly measure the resistance of the potentiometer.
Solder a row to header pins to digital pins 9-13. Solder a 10kOhm resistor and 0.1uF capacitor in series to pins 10-12. Solder the free end of the 0.1uF capacitors together and connect to Arduino +5V. Connect the outside pin of two 1mOhm linear taper pots to the junction between the resistor and capacitor attached to digital pins 11 and 12. Connect the outside pin of a 1mOhm logarithmic taper pot to the junction between the resistor and capacitor attached to digital pin 10. Solder the middle pins of each pot to ground.
I you'd like you can increase the resolution of any of these controls by increasing the capacitance of the 0.1uF cap to 1uF or 10uF. This change will have to be accounted for in the final firmware as well.
Step 30: Switch
This switch allows reverse playback of recorded samples. Solder a 10kOhm resistor to one of the leads from the switch. Solder a red wire to the other end of the resistor and connect to ground. Solder a wire to the junction between the resistor and the switch and connect to Arduino digital pin 9. solder a black wire to the remaining pin from the switch and connect to ground.
Step 31: Indicator LEDs
Solder 100ohm resistors to the anodes of two white indicator LEDs. Connect the cathodes of both indicator LEDs to ground. Connect the anode of one of the LEDs to digital pin 13- this is the clipping indicator. The other indicator LED will be connected to a switch in the next step.
Step 32: Output Switch
this switch will turn on an indicator LED to show that the output is on. Solder two wires to the back of the 10kOhm pot. Connect one wire to Arduino 5V and the other to the anode of the indicator LED. The other end of the indicator LED connects to ground.
Step 33: Enclosure
I designed a triangular enclosure in corel draw and cut it from 1/4" plywood on a laser cutter. Two sides have holes for the input and outputs controls (jack, indicator LED, and gain potentiometer). The front panel has holes for the rest of the controls (on/off switch, reverse switch, wet/dry mixer, pitch pot, grain size pot). The bottom has a hole for easy access to the arduino's usb port.
I coated the plywood in three coats of polycrylic and glued the sides together with wood glue. I glued three small triangular pieces into the corners of the enclosure so that I could screw the back panel on with wood screws (fig 3).
Attach the Arduino to the header pins on the protoboard and begin installing the components in the enclosure. I started by attaching the pots and switches to the front panel and then added the jacks, LED indicators, and pots to the sides. Finally I pushed the arduino's usb port through the square hole on the bottom of the enclosure. My arduino sat firmly in place, you could screw it to the back panel for an extra secure fit.
I've attaches the corel file for the enclosure that I built.
Step 34: Batteries
Secure batteries in the corners of the enclosure with a battery clip or a piece of velcro. Screw on back panel of enclosure.
Step 35: Knobs
Attach knobs to potentiometers and secure with a set screw.
Step 36: Final Firmware
DIY Audio
